Cisco 2911 Voice and Data Vlans
j44mistry
Beginner
Beginner
I have an remote office with a flat /24 network.
Users / Servers connect to 2 x 3560 Cisco switches which are uplinked to 2 x Cisco 3925 routers for Internet connectivity and VPN.
We are planning to install VoIP in the office and would like to know how best to configure the Cisco 2911.
The Cisco 2911 will connect directly to the Cisco 3560 switch.     I need to create 2 vlans 1 x Voice and 1 x Data.
What is the best way to configure 2911 ?
Ideally I would like to have resiliency from the Voice Gateway so would like to have it connect to both Cisco 3560 switches.
What is the best way to route both vlans ?
Analog Phones --->Cisco 2911 (VG)---->Cisco 3560------Cisco 3925 -----> Internet
antonio.guirado
Participant
Participant
STP could be a good solution. The problem is the time converge (it can be 30-50 seconds), so better
RSTP (rapid STP). I have checked if your router can support this feature and it can not. But there is
another (Cisco propietary) solution to speed up convergence time on (slow) STP enviroment Uplink port fast.
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_tech_note09186a0080094641.shtml
Basically, is the same idea as RSTP, 2911 negotiates an alternative root port and uses it if the main port fails.
If you send me the exact IOS version I can check if you have this feature supported.
IOS Version :-
c2900-universalk9-mz.SPA.152-4.M2.bin
Does one of the interfaces have to be configured as backup ?
If I have trunk ports can I route same vlans across both trunks ?
thist is a configuration example:
bridge irb
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.10
encapsulation dot1Q 10
bridge-group 10
interface FastEthernet0/0.20
encapsulation dot1Q 20
bridge-group 20
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/1.10
bridge-group 10
interface FastEthernet0/1.20
bridge-group 20
interface BVI10
ip address 10.10.10.1 255.255.255.0
interface BVI20
ip address 20.10.10.1 255.255.255.0
bridge 1 protocol ieee
bridge 10 protocol ieee
bridge 20 protocol ieee
The idea is that both FastEthernet port works as a brigde and then run STP with your switches. A link
will be blocked. I can not tell you the commands in the 2911 to configure portfast uplink but your IOS version
support it. With the configuration everythink should wrok fine but you converge time will be 30-50 second (STP).
Hi Antonio,
Is it possible to have a point to point link with a backup interface using same network and would that be better ?
Recognize Your Peers
