06-09-2011 12:40 AM - edited 03-04-2019 12:39 PM
I am facing a issue on Cisco 3845 router, IOS is :c3845-adventerprisek9-mz.124-22.YB8.bin
I have changed the IOS as well as the Hardware but again the router is restarting. I have put the show tech-support and crash-info in Output interpreter, result is below:
Kindly advise:
ERROR MESSAGE NOTIFICATIONS (if any) %PAR-1-FATAL (x): [chars] Explanation: A parity error has occurred. The problem might be caused either by a motherboard that has failed or motherboard settings that are incorrectly set. Recommended Action: Copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Also perform a search of the Bug Toolkit http://www.cisco.com/pcgi-bin/Support/Bugtool/home.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet http://tools.cisco.com/ServiceRequestTool/create, or contact your Cisco technical support representative and provide the representative with the gathered information. Attach the following to your case in non-zipped, plain-text (.txt) format: the output of the show logging and show tech-support commands and your pertinent troubleshooting logs. PARSER Messages The following are parser messages.
%PAR-1-FATAL (x0): [chars] Explanation: A parity error has occurred. The problem might be caused either by a motherboard that has failed or motherboard settings that are incorrectly set. Recommended Action: Copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Also perform a search of the Bug Toolkit http://www.cisco.com/pcgi-bin/Support/Bugtool/home.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet http://tools.cisco.com/ServiceRequestTool/create, or contact your Cisco technical support representative and provide the representative with the gathered information. Attach the following to your case in non-zipped, plain-text (.txt) format: the output of the show logging and show tech-support commands and your pertinent troubleshooting logs. PARSER Messages The following are parser messages.
%CSM-1-NO_CHANNEL (x): [chars] Explanation: No Signalling channels are available; all the channels are allocated Recommended Action: This is a notification message. If the modems are not functional or this message appears frequently, copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://tools.cisco.com/ServiceRequestTool/create/, or contact your Cisco technical support representative and provide the representative with the gathered information.
%CSM-1-NO_CHANNEL (x0): [chars] Explanation: No Signalling channels are available; all the channels are allocated Recommended Action: This is a notification message. If the modems are not functional or this message appears frequently, copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://tools.cisco.com/ServiceRequestTool/create/, or contact your Cisco technical support representative and provide the representative with the gathered information.
%ALIGN-1-FATAL (x2): [chars] Explanation: An alignment error has occurred. Alignment errors are caused by misaligned reads and writes. For example, a two-byte read of a memory address that is not a multiple of two bytes is an alignment error. Alignment errors are caused by internal software failures. The system will be reloaded, often with a bus error. Recommended Action: This message is caused by a software failure. To take advantage of recent fixes, upgrade your system to the latest Cisco IOS software release in your release train. If this message recurs, copy the error message text exactly as it appears on the console or in the system log, enter the show log, show alignment and show tech-support commands, contact your Cisco technical support representative, and provide the representative with the gathered information.
%ALIGN-1-FATAL (x0): Illegal access to a low address Explanation: An alignment error has occurred. Alignment errors are caused by misaligned reads and writes. For example, a two-byte read of a memory address that is not a multiple of two bytes is an alignment error. Alignment errors are c aused by internal software failures. The system will be reloaded, often with a bus error. Recommended Action: This message is caused by a software failure. To take advantage of recent fixes, upgrade your system to the latest Cisco IOS software release in your release train. If this message recurs, copy the error message text exactly as it appears on the console or in the system log, enter the show log, show alignment and show tech-support commands, contact your Cisco technical support representative, and provide the representative with the gathered information.
%ALIGN-1-FATAL (x0): [chars] Explanation: An alignment error has occurred. Alignment errors are caused by misaligned reads and writes. For example, a two-byte read of a memory address that is not a multiple of two bytes is an alignment error. Alignment errors are caused by internal software failures. The system will be reloaded, often with a bus error. Recommended Action: This message is caused by a software failure. To take advantage of recent fixes, upgrade your system to the latest Cisco IOS software release in your release train. If this message recurs, copy the error message text exactly as it appears on the console or in the system log, enter the show log, show alignment and show tech-support commands, contact your Cisco technical support representative, and provide the representative with the gathered information.
%XCPA-3-OUTHUNG (x): [chars] - output stuck - [chars] Explanation: The channnel port adapter's transmit queue(s) contained packets that have been queued for an excessive period of time. A command will be sent to the port adapter requesting dump information. After that, the port adapter will be reset. Recommended Action: Copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://tools.cisco.com/ServiceRequestTool/create/, or contact your Cisco technical support representative and provide the representative with the gathered information.
%XCPA-3-OUTHUNG (x0): [chars] - output stuck - [chars] Explanation: The channnel port adapter's transmit queue(s) contained packets that have been queued for an excessive period of time. A command will be sent to the port adapter requesting dump information. After that, the port adapter will be reset. Recommended Action: Copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://tools.cisco.com/ServiceRequestTool/create/, or contact your Cisco technical support representative and provide the representative with the gathered information.
%XCPA-3-RXQ (x): [chars] - consistency error - [chars] ([hex],[dec]) Explanation: Consistency check failed receiving packets from the channel port adapter. The packet is being dropped. Recommended Action: Copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://tools.cisco.com/ServiceRequestTool/create/, or contact your Cisco technical support representative and provide the representative with the gathered information.
%XCPA-3-RXQ (x0): [chars] - consistency error - [chars] ([hex],[dec]) Explanation: Consistency check failed receiving packets from the channel port adapter. The packet is being dropped. Recommended Action: Copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://tools.cisco.com/ServiceRequestTool/create/, or contact your Cisco technical support representative and provide the representative with the gathered information.
%XCPA-3-UCODEHDR (x): bay [[dec]] skip=[hex] hdr_ver=[hex] fw_rev=[hex] req_hw_ver=[hex] hw_type=[hex] description = [chars] Explanation: The header information in the downloadable microcode file contains incorrect information. Other messages in the log specify what information is incorrect. Recommended Action: Copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://tools.cisco.com/ServiceRequestTool/create/, or contact your Cisco technical support representative and provide the representative with the gathered information.
%XCPA-3-UCODEHDR (x0): bay [[dec]] skip=[hex] hdr_ver=[hex] fw_rev=[hex] req_hw_ver=[hex] hw_type=[hex] description = [chars] Explanation: The header information in the downloadable microcode file contains incorrect information. Other messages in the log specify what information is incorrect. Recommended Action: Copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://tools.cisco.com/ServiceRequestTool/create/, or contact your Cisco technical support representative and provide the representative with the gathered information.
%XCPA-3-UCODESEC (x): bay [[dec]] wcs=[hex] addr=[hex] len=[hex] ep=[hex] compr=[hex] sec_type=[hex] ver=[hex] Explanation: The header information in a section of the downloadable microcode file contains incorrect information. Other messages in the log specify what information is incorrect. Recommended Action: Copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://tools.cisco.com/ServiceRequestTool/create/, or contact your Cisco technical support representative and provide the representative with the gathered information.
%XCPA-3-UCODESEC (x0): bay [[dec]] wcs=[hex] addr=[hex] len=[hex] ep=[hex] compr=[hex] sec_type=[hex] ver=[hex] Explanation: The header information in a section of the downloadable microcode file contains incorrect information. Other messages in the log specify what information is incorrect. Recommended Action: Copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://tools.cisco.com/ServiceRequestTool/create/, or contact your Cisco technical support representative and provide the representative with the gathered information.
%XCPA-3-UNEXPECTEDINT (x): cause_lo=[hex], cause_hi=[hex], mask=[hex], addr_dec_err=[hex], bus_err=[hex], ch0_ctrl=[hex] Explanation: An unexpected interrupt occurred. Recommended Action: Copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://tools.cisco.com/ServiceRequestTool/create/, or contact your Cisco technical support representative and provide the representative with the gathered information.
%XCPA-3-UNEXPECTEDINT (x0): cause_lo=[hex], cause_hi=[hex], mask=[hex], addr_dec_err=[hex], bus_err=[hex], ch0_ctrl=[hex] Explanation: An unexpected interrupt occurred. Recommended Action: Copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://tools.cisco.com/ServiceRequestTool/create/, or contact your Cisco technical support representative and provide the representative with the gathered information.
%XCPA-3-XCPADRIVERKILL (x): Unexpected request to terminate: XCPA driver process ([chars]) Explanation: Unexpected termination of the xcpa driver process. Recommended Action: Copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://tools.cisco.com/ServiceRequestTool/create/, or contact your Cisco technical support representative and provide the representative with the gathered information. XDR Messages
%XCPA-3-XCPADRIVERKILL (x0): Unexpected request to terminate: XCPA driver process ([chars]) Explanation: Unexpected termination of the xcpa driver process. Recommended Action: Copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://tools.cisco.com/ServiceRequestTool/create/, or contact your Cisco technical support representative and provide the representative with the gathered information. XDR Messages
%FPGA_GE-3-RBD_ERROR (x): Interface [chars]: FPGA_GE unexpected RBD error Explanation: The FPGA GE driver did not encounter EOF flag in Rx buffer descriptor (RBD) ring. Recommended Action: If this message recurs, copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://tools.cisco.com/ServiceRequestTool/create/, or contact your Cisco technical support representative and provide the representative with the gathered information.
%FPGA_GE-3-RBD_ERROR (x0): Interface [chars]: FPGA_GE unexpected RBD error Explanation: The FPGA GE driver did not encounter EOF flag in Rx buffer descriptor (RBD) ring. Recommended Action: If this message recurs, copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://tools.cisco.com/ServiceRequestTool/create/, or contact your Cisco technical support representative and provide the representative with the gathered information.
%FPGA_GE-3-RX_INIT_FAIL (x): Interface [chars]: FPGA_GE Rx Init Failure error: [chars] Explanation: The FPGA GE driver could not complete the RX init successfully. Recommended Action: If this message recurs, copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://tools.cisco.com/ServiceRequestTool/create/, or contact your Cisco technical support representative and provide the representative with the gathered information. FPM Messages The following are the Flexible Packet Matching (FPM) messages.
%FPGA_GE-3-RX_INIT_FAIL (x0): Interface [chars]: FPGA_GE Rx Init Failure error: [chars] Explanation: The FPGA GE driver could not complete the RX init successfully. Recommended Action: If this message recurs, copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://tools.cisco.com/ServiceRequestTool/create/, or contact your Cisco technical support representative and provide the representative with the gathered information. FPM Messages The following are the Flexible Packet Matching (FPM) messages.
%CSM-3-TGRM_UPDATE_FAILURE (x): The trunk group resource manager failed to update channel status to [chars] for channel [chars]:[dec]:[dec] Explanation: The Trunk Group Resource Management subsystem reported an internal software error after a channel status update was sent to it by CSM. Recommended Action: If this message recurs, copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://tools.cisco.com/ServiceRequestTool/create/, or contact your Cisco technical support representative and provide the representative with the gathered information. CSM_TGRM Messages The following are Call Switching ModuleTGRM messages.
%CSM-3-TGRM_UPDATE_FAILURE (x0): The trunk group resource manager failed to update channel status to [chars] for channel [chars]:[dec]:[dec] Explanation: The Trunk Group Resource Management subsystem reported an internal software error after a channel status update was sent to it by CSM. Recommended Action: If this message recurs, copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://tools.cisco.com/ServiceRequestTool/create/, or contact your Cisco technical support representative and provide the representative with the gathered information. CSM_TGRM Messages The following are Call Switching ModuleTGRM messages.
%CSM_TGRM-3-UNEXPEVT (x): An Unexpected event was reported by the CSM-TGRM Interface service Explanation: The system detected an internal software error. The interface service between the Call Switching Modules and Trunk group Resource Manager received an event that is not valid. Recommended Action: Copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://tools.cisco.com/ServiceRequestTool/create/, or contact your Cisco technical support representative and provide the representative with the gathered information. CSM_TRUNK_MGR Messages The following are Call Switching Module Trunk Manager messages.
%CSM_TGRM-3-UNEXPEVT (x0): An Unexpected event was reported by the CSM-TGRM Interface service Explanation: The system detected an internal software error. The interface service between the Call Switching Modules and Trunk group Resource Manager received an event that is not valid. Recommended Action: Copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://tools.cisco.com/ServiceRequestTool/create/, or contact your Cisco technical support representative and provide the representative with the gathered information. CSM_TRUNK_MGR Messages The following are Call Switching Module Trunk Manager messages.
%PXF_QOS-3-WS_QOS_L2C_TOO_MANY_L2_LKP_TBLS (x): Too many possible PXF QoS layer 2 lookup tables. (reached [int] tables). Can not add more. PXF QoS layer 2 classification will not function correctly. Explanation: The PXF QoS Layer 2 Classification does not function correctly because the number of PXF QoS Layer 2 lookup tables that result from the classification exceeds the system limitation. Recommended Action: Copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Also perform a search of the Bug Toolkit at http://www.cisco.com/pcgi-bin/Support/Bugtool/home.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://tools.cisco.com/ServiceRequestTool/create, or contact your Cisco technical support representative and provide the representative with the gathered information.
%CSM_TRUNK_MGR-3-TRUNK_VALIDITY_FAILURE (x): [chars] Explanation: A trunk validity failure has occurred. This generally indicates a memory corruption or uninitialisation issue. Recommended Action: Copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://tools.cisco.com/ServiceRequestTool/create/, or contact your Cisco technical support representative and provide the representative with the gathered information. CSM_VOICE Messages The following are Call Switching ModuleVoice call messages.
%CSM_TRUNK_MGR-3-TRUNK_VALIDITY_FAILURE (x0): [chars] Explanation: A trunk validity failure has occurred. This generally indicates a memory corruption or uninitialisation issue. Recommended Action: Copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://tools.cisco.com/ServiceRequestTool/create/, or contact your Cisco technical support representative and provide the representative with the gathered information. CSM_VOICE Messages The following are Call Switching ModuleVoice call messages.
%FREDDO_E1T1-3-CHANNEL_GROUP (x): [chars] Explanation: Channel group configuration specific error. Recommended Action: Copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://tools.cisco.com/ServiceRequestTool/create/, or contact your Cisco technical support representative and provide the representative with the gathered information.
%FREDDO_E1T1-3-CHANNEL_GROUP (x0): [chars] Explanation: Channel group configuration specific error. Recommended Action: Copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://tools.cisco.com/ServiceRequestTool/create/, or contact your Cisco technical support representative and provide the representative with the gathered information.
%FREDDO_E1T1-3-CLOCK_MODE (x): At least one [chars] was configured already for [chars]. Please remove it before changing timing mode. Explanation: If ds0-group or pri-group are already configured, timing mode cannot be changed without removing them. Recommended Action: Copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://tools.cisco.com/ServiceRequestTool/create/, or contact your Cisco technical support representative and provide the representative with the gathered information.
%FREDDO_E1T1-3-CLOCK_MODE (x0): At least one [chars] was configured already for [chars]. Please remove it before changing timing mode. Explanation: If ds0-group or pri-group are already configured, timing mode cannot be changed without removing them. Recommended Action: Copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://tools.cisco.com/ServiceRequestTool/create/, or contact your Cisco technical support representative and provide the representative with the gathered information.
%FREDDO_E1T1-3-CNTR_TYPE_CHG (x): You need to reload the router for this configuration change to be effective. Explanation: If the controller type is set to T1 or E1 and if the opposite controller is put on freddo system, the system needs to be rebooted to change the controller type. Recommended Action: Copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://tools.cisco.com/ServiceRequestTool/create/, or contact your Cisco technical support representative and provide the representative with the gathered information.
%FREDDO_E1T1-3-CNTR_TYPE_CHG (x0): You need to reload the router for this configuration change to be effective. Explanation: If the controller type is set to T1 or E1 and if the opposite controller is put on freddo system, the system needs to be rebooted to change the controller type. Recommended Action: Copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://tools.cisco.com/ServiceRequestTool/create/, or contact your Cisco technical support representative and provide the representative with the gathered information.
%CSM-4-HWIDB_ALREADY_IN_USE (x): hwidb is already in use by another call Explanation: A call is already using this HWIDB. This new call will be rejected. Recommended Action: Copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://tools.cisco.com/ServiceRequestTool/create/, or contact your Cisco technical support representative and provide the representative with the gathered information.
%CSM-4-HWIDB_ALREADY_IN_USE (x0): hwidb is already in use by another call Explanation: A call is already using this HWIDB. This new call will be rejected. Recommended Action: Copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://tools.cisco.com/ServiceRequestTool/create/, or contact your Cisco technical support representative and provide the representative with the gathered information.
%OSPF-5-ADJCHG (x5): Process [dec], Nbr [IP_address] on [chars] from [chars] to [chars], [chars] Explanation: An OSPF neighbor has changed state. The message describes the change and the reason for it. This message appears only if the log-adjacency-changes command is configured for the OSPF process. Recommended Action: No action is required.
%OSPF-5-ADJCHG (x0): Process %d, Nbr %i on %s from %s to %s, %s Explanation: An OSPF neighbor has changed state. The message describes the change and the reason for it. This message appears only if the log-adjacency-changes command is configured for the OSPF process. Recommended Action: No action is required.
%SEC-6-IPACCESSLOGNP (x223): list [chars] [chars] [dec] [IP_address] [chars]-> [IP_address], [dec] packet[chars] Explanation: A packet matching the log criteria for the given access list has been detected. Recommended Action: No action is required.
%SEC-6-IPACCESSLOGNP (x0): list [chars] [chars] [dec] [IP_address] [chars]-> [IP_address], [dec] packet[chars] [chars] Explanation: A packet matching the log criteria for the given access list was detected. Recommended Action: No action is required.
%SEC-6-IPACCESSLOGNP (x0): list [chars] [chars] [dec] [IP_address] [chars]-> [IP_address], [dec] packet[chars] [chars] [chars] Explanation: A packet matching the log criteria for the given access list was detected. Recommended Action: Informational message only. No action is required.
%SEC-6-IPACCESSLOGP (x7): list [chars] [chars] [chars] [IP_address]([dec]) [chars]-> [IP_address]([dec]), [dec] packet[chars] Explanation: A packet matching the log criteria for the given access list has been detected. Recommended Action: No action is required.
%SEC-6-IPACCESSLOGP (x0): list [chars] [chars] [chars] [IP_address]([dec]) [chars]-> [IP_address]([dec]), [dec] packet[chars] [chars] Explanation: A packet matching the log criteria for the given access list was detected. Recommended Action: No action is required.
%SEC-6-IPACCESSLOGP (x0): list [chars] [chars] [chars] [IP_address]([dec]) [chars]-> [IP_address]([dec]), [dec] packet[chars] [chars] [chars] Explanation: A packet matching the log criteria for the given access list was detected. Recommended Action: Informational message only. No action is required.
%SEC-6-IPACCESSLOGRP (x12): list [chars] [chars] [chars] [IP_address] [chars]-> [IP_address], [dec] packet[chars] Explanation: A packet matching the log criteria for the given access list has been detected. Recommended Action: No action is required.
%SEC-6-IPACCESSLOGRP (x0): list [chars] [chars] [chars] [IP_address] [chars]-> [IP_address], [dec] packet[chars] [chars] Explanation: A packet matching the log criteria for the given access list was detected. Recommended Action: No action is required.
%SEC-6-IPACCESSLOGRP (x0): list [chars] [chars] [chars] [IP_address] [chars]-> [IP_address], [dec] packet[chars] [chars] [chars] Explanation: A packet matching the log criteria for the given access list was detected. Recommended Action: Informational message only. No action is required.
%SEC-6-IPACCESSLOGRL (x5): access-list logging rate-limited or missed [dec] packet[chars] Explanation: Some packet-matching logs were missed because the access list log messages were rate limited, or no access list log buffers were available. Recommended Action: No action is required.
%SEC-6-IPACCESSLOGRL (x0): access-list logging rate-limited or missed [dec] packet[chars] [chars] Explanation: Some packet matching logs were missed because the access list log messages were rate-limited or no access list log buffers were available. Recommended Action: No action is required.
%ENTITY_ALARM-6-INFO (x): [chars] [chars] [chars] [chars] [chars] Explanation: Alarm assertion or deassertion information. Recommended Action: No action is required. ENVM Messages The following are Environmental Monitor messages.
%ENTITY_ALARM-6-INFO (x0): [chars] [chars] [chars] [chars] [chars] Explanation: Alarm assertion or deassertion information. Recommended Action: No action is required. ENVM Messages The following are Environmental Monitor messages.
No information on error code 034777 No information on error code 034823 No information on error code 034808 No information on error code 034739 No information on error code 034700 No information on error code 034681 No information on error code 034792 No information on error code 034610 No information on error code 034707 No information on error code 034674 No information on error code 034668 No information on error code 034624 No information on error code 034740 No information on error code 034727 No information on error code 034787 No information on error code 034759 No information on error code 034614 No information on error code 034705 No information on error code 034651 No information on error code 034671 No information on error code 034646 No information on error code 034812 No information on error code 034619 No information on error code 034781 No information on error code 034835 No information on error code 034749 No information on error code 034780 No information on error code 034719 No information on error code 034609 No information on error code 034733 No information on error code 034664 No information on error code 034620 No information on error code 034678 No information on error code 034635 No information on error code 034776 No information on error code 034737 No information on error code 034726 No information on error code 034587 No information on error code 034638 No information on error code 034771 No information on error code 034744 No information on error code 034650 No information on error code 034657 No information on error code 034768 No information on error code 034687 No information on error code 034813 No information on error code 034691 No information on error code 034793 No information on error code 034804 No information on error code 034819 No information on error code 034704 No information on error code 034752 No information on error code 034706 No information on error code 034588 No information on error code 034765 No information on error code 034730 No information on error code 034630 No information on error code 034829 No information on error code 034615 No information on error code 034720 No information on error code 034834 No information on error code 034592 No information on error code 034686 No information on error code 034699 No information on error code 034783 No information on error code 034596 No information on error code 034755 No information on error code 034728 No information on error code 034677 No information on error code 034605 No information on error code 034618 No information on error code 034828 No information on error code 034816 No information on error code 034710 No information on error code 034654 No information on error code 034831 No information on error code 034716 No information on error code 034669 No information on error code 034736 No information on error code 034613 No information on error code 034824 No information on error code 034616 No information on error code 034627 No information on error code 034773 No information on error code 034690 No information on error code 034714 No information on error code 034807 No information on error code 034682 No information on error code 034743 No information on error code 034810 No information on error code 034832 No information on error code 034586 No information on error code 034658 No information on error code 034648 No information on error code 034741 No information on error code 034825 No information on error code 034753 No information on error code 034633 No information on error code 034782 No information on error code 034748 No information on error code 034665 No information on error code 034593 No information on error code 034731 No information on error code 034590 No information on error code 034799 No information on error code 034659 No information on error code 034623 No information on error code 034769 No information on error code 034693 No information on error code 034601 No information on error code 034798 No information on error code 034694 No information on error code 034806 No information on error code 034634 No information on error code 034701 No information on error code 034772 No information on error code 034723 No information on error code 034803 No information on error code 034597 No information on error code 034721 No information on error code 034786 No information on error code 034688 No information on error code 034698 No information on error code 034734 No information on error code 034644 No information on error code 034794 No information on error code 034756 No information on error code 034760 No information on error code 034660 No information on error code 034802 No information on error code 034747 No information on error code 034628 No information on error code 034604 No information on error code 034695 No information on error code 034639 No information on error code 034790 No information on error code 034821 No information on error code 034762 No information on error code 034789 No information on error code 034612 No information on error code 034836 No information on error code 034637 No information on error code 034742 No information on error code 034603 No information on error code 034702 No information on error code 034595 No information on error code 034626 No information on error code 034640 No information on error code 034666 No information on error code 034754 No information on error code 034709 No information on error code 034724 No information on error code 034713 No information on error code 034826 No information on error code 034712 No information on error code 034717 No information on error code 034683 No information on error code 034820 No information on error code 034622 No information on error code 034594 No information on error code 034833 No information on error code 034817 No information on error code 034673 No information on error code 034641 No information on error code 034800 No information on error code 034652 No information on error code 034732 No information on error code 034617 No information on error code 034655 No information on error code 034766 No information on error code 034608 No information on error code 034636 No information on error code 034645 No information on error code 034679 No information on error code 034757 No information on error code 034735 No information on error code 034788 No information on error code 034599 No information on error code 034598 No information on error code 034689 No information on error code 034811 No information on error code 034795 No information on error code 034697 No information on error code 034672 No information on error code 034647 No information on error code 034814 No information on error code 034746 No information on error code 034750 No information on error code 034763 No information on error code 034661 No information on error code 034606 No information on error code 034643 No information on error code 034805 No information on error code 034632 No information on error code 034675 No information on error code 034629 No information on error code 034667 No information on error code 034785 No information on error code 034809 No information on error code 034600 No information on error code 034708 No information on error code 034725 No information on error code 034718 No information on error code 034621 No information on error code 034822 No information on error code 034778 No information on error code 034801 No information on error code 034738 No information on error code 034663 No information on error code 034649 No information on error code 034791 No information on error code 034711 No information on error code 034827 No information on error code 034602 No information on error code 034670 No information on error code 034758 No information on error code 034684 No information on error code 034722 No information on error code 034761 No information on error code 034685 No information on error code 034642 No information on error code 034830 No information on error code 034770 No information on error code 034767 No information on error code 034745 No information on error code 034764 No information on error code 034797 No information on error code 034784 No information on error code 034631 No information on error code 034775 No information on error code 034818 No information on error code 034607 No information on error code 034796 No information on error code 034676 No information on error code 034653 No information on error code 034815 No information on error code 034656 No information on error code 034692 No information on error code 034611 No information on error code 034779 No information on error code 034591 No information on error code 034703 No information on error code 034662 No information on error code 034729 No information on error code 034751 No information on error code 034625 No information on error code 034715 No information on error code 034680 No information on error code 034774 No information on error code 034589 No information on error code 034696 STACK DECODE NOTIFICATIONS (if any) ERROR: This device has recorded 'Spurious Access', which is caused by a Cisco IOS software bug. A spurious access occurs when a process attempts to read from the lowest 16 KB region of memory. This portion of memory is reserved, and should never be accessed. A read operation to this region of memory is usually caused when a non-existing value is returned to a function in the software, when a null pointer is passed to a function. TRY THIS: Upgrade your device to the latest version of Cisco IOS software in your release train. Review Bug Toolkit for any potential bugs related to the loaded image. Paste the "show tech-support" command output into the Output Interpreter to display the potential issues and fixes. If the issue persists, consider opening a service request with Cisco using the TAC Service Request Tool. Include the "show alignment" and "show tech-support" command output for TAC analysis. REFERENCE: For more information on spurious access, see Troubleshooting Spurious Accesses, Alignment Errors, and Spurious Interrupts. Note: Understanding the 'Fixed In Version' field - Sometimes the fixed-in version specified may not be available for download from the Software Downloads. This is because, bug fixes are incorporated into software versions which have not been regression tested. These builds are called interim images and will have a "." in the build number found between the parenthesis, for example 12.3(8.1). The bug fix will be in the next available image, and all later images. So if a bug is fixed in 12.3(8.1), the bug fix is present in 12.3(9), 12.3(10), and so on. REFERENCE: For more information on how IOS images are named, see Cisco IOS Reference Guide. The failure was caused by a software defect. The stack trace decoded symbols are: oce_surrender_fwd_state_handle crypto_ceal_post_decrypt_cef crypto_ceal_post_decrypt_switch crypto_engine_packet_callback sfnt_callback sfnt_udm_callback udm_notify udm_isr_common_bottom udm_isr c3800_sysctlr_interrupt c3800_pm_slot0 scheduler oce_surrender_fwd_state_handle crypto_ceal_post_decrypt_cef crypto_ceal_post_decrypt_switch crypto_engine_packet_callback sfnt_callback sfnt_udm_callback udm_notify udm_isr_common_bottom udm_isr c3800_sysctlr_interrupt c3800_pm_slot0 scheduler r4k_level_table oce_surrender_fwd_state_handle oce_surrender_fwd_state_handle Possible bug matches are listed below. Bugs with a score of .90 or more are the most likely candidates:
Score | Bugid | Status | Fixed In | Duplicate | Title |
0.85 | CSCse62295 | R | 12.4(16.13)PI7a 12.2(32.8.11)SR14 12.2(32.8.99a)SR133 12.4(16.14)T1 12.4(21.14.9)PIC1 12.2(33)SRC | None | Traffic shaping rework to use new CEF infrastructure. |
0.85 | CSCsk65460 | R | 12.4(21.3)T 12.2(32.8.11)SR142 12.4(19.18)T5 12.2(32.8.11)SX184 12.2(32.8.20)REC137 12.2(32.0)DPI 12.2(33)SXI 12.2(33)XNC | None | MVPN: mcast-FS fails on decapPE |
0.85 | CSCsq36269 | R | 12.4(21.14)T 12.4(21.13)PI9 12.4(21.14.1)PIC1 12.4(21.14.9)PIC1 12.4(15)T8 12.4(22.3.4)PIC1 12.4(20)T2 | None | IPSEC on 7200: increments TTL when U turning packets |
0.85 | CSCsr21842 | R | 12.4(23.1)T 12.4(23.1)PI10 12.2(32.8.5)REC154 12.2(32.8.2)YCA172.24 12.4(21.14.6)PIC1 12.4(22.3.9)PIX11 12.4(23.5.2)PIX11 15.1(1)SG3.90 15.1(1)SG1.3 | None | GRE+ipsec, tunnel inbound ACL, not process switched from cef punt |
0.85 | CSCsx51103 | R | 12.4(24.5)T 12.4(23.15)T6 12.4(24.5.2)PIC1 12.4(20)T3 12.2(33.1.8)MCP5 12.2(33.0.9)XND 12.4(22)T2 | None | Router crash at OCE function after post-decrypt + %ALIGN-1-FATAL: |
0.74 | CSCsk29999 | V | 12.4(19.12)PI8 12.4(15)XZ 12.4(15)XY3 12.4(19.18)T1 12.4(21.14.9)PIC1 12.4(24.5.1)PIX11 | None | AIM-IPS-K9:TCP intercept not entering aggressive mode |
0.58 | CSCtb05176 | A | None | IPSEC Performance Degradation observed 12.4(24.6)PI11n vs 12.4(23.5)PI10 |
SHOW MEMORY Partial NOTIFICATIONS (if any) INFO: It seems you are trying to interpret 'show memory' command output. Please paste the complete output of the show command into the Output interpreter tool for analysis.
06-09-2011 02:34 AM
Try replacing memory. If stiull trouble, HW is faulty and must be replaced.
