Cisco 3925 Router not routing IP traffic between two GB interfaces.
john.evans.ggs
We currently installed a 100Mbps fiber line with Ethernet hand-off.  I  purchased a Cisco 3925 ISR to be the gateway for this connection.  I am  not going to use it for any security purposes.  I have an ASA5520 that  will do that work.  Right now I am currently just trying to get the  router online.
I know the following
Laptop <--->GB 0/1((()))GB0/0<---->Ethern
et handoff from ISP.
I  can ping and SSH to the outside interface of the router from outside  the network.  I can also ping and SSH to the router from the laptop that  is directly attached to the routers GB0/1 port.  From the Router's CLI I  can ping IP addresses on the internet. From the laptop I can not.
I can not access the internet through the router though.
Here is my config.
Building configuration...
Current configuration : 3724 bytes
! Last configuration change at 02:17:03 UTC Tue Jan 15 2013 by ggsis
! NVRAM config last updated at 02:09:33 UTC Tue Jan 15 2013 by ggsis
version 15.1
hostname XXXNAMEXXX
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 4 XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
no aaa new-model
memory-size iomem 20
no ipv6 cef
ip source-route
ip cef
no ip domain lookup
ip domain name XXXXXXXXXXXXXXDomainXXXXXXXXXXX
crypto pki trustpoint TP-self-signed-XXXXXXXXXXXXXXXX
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-XXXXXXXXXXXXX
revocation-check none
rsakeypair TP-self-signed-XXXXXXXXXXXXXX
crypto pki certificate chain TP-self-signed-XXXXXXXXXXXXXX
certificate self-signed 01
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
        quit
license udi pid C3900-SPE100/K9 sn FOC16140N3N
username XXXXX privilege 15 secret 4 XXXXXXXXXXXXXXXXXXXXXXXXX
ip ssh time-out 60
ip ssh version 2
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description ISP Side of Router$ES_WAN$$ETH-WAN$
ip address 50.XXX.XX.XXX 255.255.255.252
no ip redirects
no ip proxy-arp
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
description My Side of Router$ES_LAN$$ETH-LAN$
ip address 50.YYY.YY.YYY 255.255.255.0
no ip redirects
no ip proxy-arp
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 50.XXX.XX.NextHop
ip route 50.YYY.YY.0 255.255.255.0 GigabitEthernet0/1
control-plane
line con 0
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
end
10 Replies 10
Marcel Zehnder
Hi John
Is the default gateway on your laptop correctly configured (IP-address of gig0/1)?
Marcel,
It sure is...thanks!
John
Sorry for the stupid question ;-)
Maybe your local subnet (50.YYY.YY.YYY 255.255.255.0) is not routed on your ISPs router? Could you try to ping to the internet from the router with the src-ip of your gig 0/1 interface? If this fails you have to configure NAT from your internal to your external interface.
I just did a ping 4.2.2.2 source gigab 0/1 and it failed.  Looks like you are onto something.
They are the ones who gave me the IP block for that side of the router.
Are you supposed to be using a routing protocol with them? They'll either need to route for the subnet they assigned you with static routing or you'll need to have a routing protocol configured with the ISP.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
I suggest you talk to your ISP. In the meanwhile you can try to setup NAT:
ip nat inside
interface gig0/0
ip nat outside
ip access-list NAT-SOURCE
deny ip 50.YYY.YY.YYY 0.0.0.255 50.YYY.YY.YYY 0.0.0.255
permit ip 50.YYY.YY.YYY 0.0.0.255 any
ip nat inside source list NAT-SOURCE interface gig0/0 overload
May not fix anything but, why have a staic route to your 50.yyy.yyy.yyy/24 network? Isn't it connected toy your G0/1?
Ali Muazzam
Dear John
This is just due to the fact that no NAT service is configured on the router. Either you have to enable NAT on the router or the other case can be advertising your LAN subnet via your ISP to the internet which is least possible as in such case you would have to run protocol with your ISP. If the ISP has provided you the /24 subnet to use in your LAN then the ISP would have to route the subnet to your Point-to-point IP to make it work. In this case contact your ISP/
Marcel is right with the NAT configurations. Go with it and it shall probably solve the problem
BR
Muazzam
synbureau
Adding NAT will just allow outbound internet connection but will kill the idea of having public IP range. Ask the ISP to add static route on their router for 50.YYY.YY.0 255.255.255.0 pointing to your router (50.XXX.XX.XXX 255.255.255.252).
On another note, why do you have "ip route 50.YYY.YY.0 255.255.255.0 GigabitEthernet0/1"? That network is local to the router.
