OSPF problems
Hello All.
does OSPF only work on point-to-point links? i have OSPF configured on some links which are not on point-to-point links but OSPF is not forming neighbor relations but with routers on point-to-point links OSPF is working fine. what is it?
Nagendra Kumar Nainar
With right configuration, OSPF will work on any link (P2P or broadcast). Can you share the cofiguration?.
-Nagendra
lucentmoon
By default ospf running over point-to-point links use multicast hellos to form the neighbor relationship.  My guess is that you need a neighbor statement under the ospf process.  As some link types by default dont send the multicast hellos
The configuration needed depends on the network type of the links.  Here is a quick break down of the different network types and requirements.
http://www.ccietalk.com/2008/07/14/ospf-network-types
turnera
Are you using the following command in your point to multipoint link configurations?
ip ospf network point-to-multipoint
This will need to be entered at every link location.
This may help with your current problem.
HI,
Opsf can be defined with different types which can be configured with the default hello times for neighbor establishment.
                                           Dr/BDR election -   dyanmic discovery of neighbour    multiple routers in subnet
Broadcast networks ( ethernet)      yes                     yes                               yes   10 sec hello / 40 sec dead
NBMA networks ( frame-relay)       yes                    n/a                         yes  30 sec hello / 120 sec dead
Point -to-point                         n/a                yes                            n/a   10 sec hello / 40 sec dead
Point-to-multipoint                        n/a                    yes                               yes   30 sec hello / 120 sec dead
Point-to-multipoint non-broadcast   n/a                  n/a                      yes   30 sec hello / 120 sec dead
Virtual link                                   n/a                           n/a                                n/a
Also these are compatible
Point -to-Point & Point-to-Multipoint
Point -to-Point & Point-to-Multipoint non-broadcast
( required to change hello value to same)
Broadcast & non-broadcast
Also all the above fit into one of two network types:
Transit networks have two or more attached router - packets that pass through "transit"
Stub network have a single attached router - packets have source or destination addresses belong to it.
res
Paul
Kind Regards
Paul
