Cisco 857 (12.4(6)T6) %NAT: Error activating CNBAR on the interface ATM0.1?
johnelliot
Standard config we use on 857's now produces:
As soon as "ip nat outside" is enabled on the ATM0.1 Interface with the above IOS version.
FNN1610412230(config)#interface ATM0.1 point-to-point
FNN1610412230(config-subif)# bandwidth 6144
FNN1610412230(config-subif)# ip address xxx.xxx.xxx.xxx 255.255.255.252
FNN1610412230(config-subif)# ip nat outside
Is this a potential bug?(As this config works without issue on earlier IOS versions)
purohit_810
Level 5
Level 5
Yes that is Bug and you can resolve it by upgrading your IOS version 12.4(7.14)T.
Dharmesh Purohit
purohit_810
Level 5
Level 5
Dharmesh Purohit
