02-13-2007 01:10 AM - edited 03-03-2019 03:43 PM
Hello all,
I need your help concerning the configuration of a cisco 876W.
Is there an example/how to for configuring this router ?
I?ve searched the net but it does not helped me out.
I want to configure this router for ADSL, ISDN Backup and for a vpn connection.
For the ADSL I did not get the information from the ISP yet.
Is it possible to establish a connection via ISDN and then establish a vpn connection to a cisco 3005 vpn concentrator ?
At last I need also an advice how to configure the WLAN. The GUI is easy to use but I am not sure if it covers all the things I need.
I know there are a lot of questions.
If anybody knows something about I would be greatful
best regards
Kai
02-19-2007 06:44 AM
The following link gives the configuration example of ADSL and SHDSL.
02-19-2007 11:47 PM
