Cisco 877 Max VLAN and QoS Bugs??
stevep
Hi All,
Sorry for the double post but I need to get this issue resolved ASAP.
I am currently configuring a Cisco 877 router and I believe that I have run into a software bug with the 877.
The unit shipped with IOS 124-4.T2, I was able to configure 4 additional VLANs to the default VLAN through the VLAN database as expected and everything was working fine until I tried to apply my QoS service-policy to the Dialer Interface. Unexpectedly the router suffered a software forced reload and dumped it's output to flash. When the unit came up again I tried to apply the service-policy, same story the unit crashed.
I then downloaded 124-6.T1 and proceeded to recreate my VLANS, the VLAN.dat file copied successfully back to flash but the VLANS were not visible? (yet another bug??) When trying to recreate my VLANS as I added the fifth VLAN the following error occured.
*****UKBURL877-001(vlan)#vlan 5 name Guest*****
*****Vlan can not be added. Maximum number of 4 vlan(s) in the database.*****
I have now just upgraded to 124-6.T2 (release date 18/05) and when adding in the fifth VLAN the same error as above occurs.
I didn't even bother trying to add the service-policy after the IOS upgrades as my project requires 5 VLANs in total.
Anbody else running into the same bug?????
When my Smartnet comes through i'm going to open up a TAC on this but until then I was hoping that somebody out there might have an answer. ; )
TIA
Steve.
mounir.mohamed
Level 7
Level 7
Dear Steve,
I found it for you
Q)How many 802.1q VLANs can be configured on the inbuilt 4 port switch (Fastethernet 0-3) ?
A. Maximum of 4 VLANs are supported on Cisco 870 series with the plus feature set(Advanced IP services/Advanced Enterprise Services). Cisco 850 series does not support 802.1q VLANs.
For more info refare to
http://www.cisco.com/en/US/products/hw/routers/ps380/products_qanda_item0900aecd8028a982.shtml
Please rate helpful posts.
Best Regards,
Mounir Mohamed
Mounir,
With respect, I am fully aware that the 877 supports 4 802.1q VLANS in addition to the default VLAN, VLAN 1. When upgrading to the most current IOS (124-6.T2)the 877 now only supports 4 VLANS including the default VLAN.
Plus i'm guessing my QoS service-policy when applied to the dialer interface is still going to crash the router.
rrlewis
Just hit the same VLAN bug on an 878 with 12.4(6)T3. Same problem - only four VLANs *including* the default VLAN. Did you get a TAC up on this because if not I have one going in tomorrow?
Cheers,
Richard
