Cisco 881 inter VLAN routing via trunk port
Hello my fellow network specialists an experts
I need your help
I have tried to configure inter VLAN routing on Cisco 881, but I failed.
Vlans were connected via trunk port which is connected with a switch.
Configuring Vlan interfaces doesn't work, because they are in down state as no cables are directly connected to the router.
Then I tried to configure sub interfaces on a trunk port, but there is no such option in command line.
In final, I made a conclusion that this router model does not support inter vlan routing with trunk port.
Am I right? Or there are other ways to accomplish it?
Thank you in advance.
paolo bevilacqua
Yes it can, create the vlan and when it comes up it will route.
mfurnival
Level 4
Level 4
It would look something like this:
SWITCH:
interface F1/0/1
switchport mode trunk
VLAN1
VLAN2
etc.
ROUTER:
interface F0/0.1
encapsulation dot1q 1
ip address 10.0.0.1 255.255.255.0
interface F0/0.2
encapsulation dot1q 2
ip address 10.0.2.1 255.255.255.0
SWITCH:
interface F1/0/1
VLAN1
VLAN2
etc.
ROUTER:
interface F0/0.1
interface F0/0.2
This assumes the router uses a Layer 3 interface for connecting the switch. But if it connects using a switch port, the only vlan interfaces ae configred, not subinterfaces.
Thank you guys for your answers!
I found the solution:
In the configuration of VLAN interface it is required to add
no autostate
This will enable VLAN interface even if there are no ports in it, and you can ping it.
