Cisco 881G with 3G modem in France
david.malaure
I try to make working a 881G router with integrated 3G router (cellular 0) with Bouygues or Orange, but I don't found any working configuration. In the ppp debug I just see the CONFREQ message that are sended but without any answer ! Does someboby have such a working configuration (with French provider) exemple to share ?
Thanks for your hep.
paolo bevilacqua
Which exact IOS are you using ?
mavespig
Level 3
Level 3
Hi David,
Bouygues should use ebouygtel.com or b2bouygtel.com as APN, with no credentials.
Orange should have APN orange.fr, with username and password orange.
You can confirm these parameters directly with your Mobile provider.
Acccording to Cisco documentation, Orange is a Wireless Carrier Partner:
http://www.cisco.com/en/US/prod/routers/networking_solutions_products_genericcontent0900aecd80601f7e.html#~europe
Minimum IOS requirement is 15.1(1)T for HWIC-3G-HSPA-G (firmware K2.0.7.19) and 15.1(1)T & 15.0(1)M for HWIC-3G-HSPA (firmware K1.0.2.18 & K2.0.7.19)
Can you paste here a few outputs:
- show cellular x/x/x all
- show cellular x/x/x radio history all
- show run
You can also enable the following debugs, then attempt to bring up the line:
- deb chat
- deb dialer
- deb ppp nego
thanks
Marco
