Cisco 887VA FTTC/VDSL configuration
Darkglasses
Hi folks,
I am currently working on obtaining my Routing and Switching qualification and thought I would replace my existing router with a Cisco 887VA. All was going well when the expected IP address was showing on the dialer interface and able to ping IP and URL. Then no web.
All LAN ports are in the default VLAN and my laptop is connectd to Fa0 via a straight Ethernet cable. My laptop obtains the correct IP and default gateway but the LAN card shows "Unidentified" which means no traffic. I specified an IP address and ran windows NETSH resets/reinstalled my NIC for the issue t remain. As I have no issues with other routers/switches, I am thinking it is my Cisco 887.
Anyone able to see if I have missed something in my running config or kindly provide a little advice as using these dialer interfaces has thrown me a little
Router#show run
Building configuration...
Current configuration : 1981 bytes
! No configuration change since last restart
version 15.1
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 10
ip source-route
ip dhcp excluded-address 192.168.1.150 192.168.1.254
ip dhcp pool LAN-POOL
network 192.168.1.0 255.255.255.0
default-router 192.168.1.250
ip cef
ip name-server 8.8.8.8
no ipv6 cef
license udi pid CISCO887VA-K9 sn FCZ1608C23Q
username admin privilege 15 secret 5 $1$dDgF$4GuJN1/LLTYzSqCUAV.HM.
controller VDSL 0
interface Ethernet0
no ip address
interface Ethernet0.101
encapsulation dot1Q 101
pppoe-client dial-pool-number 1
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
shutdown
interface FastEthernet2
no ip address
shutdown
interface FastEthernet3
no ip address
shutdown
interface Vlan1
description VLAN1
ip address 192.168.1.150 255.255.255.0
ip nat inside
ip virtual-reassembly in
interface Dialer0
description Dialer for VDSL
mtu 1492
ip address negotiated
encapsulation ppp
dialer pool 1
ppp authentication pap chap ms-chap callin
ppp chap hostname test@btbroadband.com
ppp chap password 0 VDSL
ppp ipcp address accept
no cdp enable
interface Dialer1
no ip address
ip nat outside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat pool LAN-NET 192.168.1.1 192.168.1.254 netmask 255.255.255.0
ip nat inside source list 1 pool LAN-NET overload
ip nat inside source list LAN-POOL interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 1 permit 192.168.1.0 0.0.0.255
line con 0
line aux 0
line vty 0 4
login local
transport input all
end
Router#
Thanks for the feedback. Your ISP should provide you with his DNS server access and that should be configured under the "ip dhcp pool LAN-POOL" using "dns-server" command, not Google DNS.
But what you are experiencing is almost certainly the MTU issue. My view is that you should configure "ip mtu 1492" not "mtu 1492" under the Dialer0 interface. Also will you please try to add the "ip tcp adjust-mss 1452" under the same interface.
Will you please let me know if there is any progress.
Thanks & Regards,
Antonin
6 Replies 6
amikat
These are my observations:
1) The default router under "ip dhcp pool LAN-POOL" should be configured as "default-router 192.168.1.150" (ie. your int Vlan1 address).
2) The "ip nat outside" should be configured under "interface Dialer0" (I do not understand why you would need Dialer1 at all).
3) The "ip nat inside source ..." should be configured (only) as follows: "ip nat inside source list 1 interface Dialer0 overload").
4) The default route should be configured as "ip route 0.0.0.0 0.0.0.0 Dialer0".
Will you please try to modify and let me know the result.
Thanks & Regards,
Antonin
Thanks Antonin
I really appreciate the help as the router is online with my laptop no longer showing unidentified and can ping IP address. I specified Google DNS on my NIC and now able to get web pages, all be it a little limited as Google searches return results but clicking a URL gives a spinning timer.
I changed my MTU to 1500 (from 1492) as this is the default on my ISP provided router but getting the same issue.
Next step is to setup the router to provide DNS servers and troubleshoot if that doesn't work
To answer your questions. I was following different guides online where Dialer1 was used a lot. I assume Dialer0 contained their ADSL config which was left in place and shutdown with ATM0. I had not changed my default route back for this reason and got a little twisted for my NAT.
A little further work is needed but progress, thanks for setting me straight.
Router#sh run
Current configuration : 1997 bytes
! Last configuration change at 10:09:57 UTC Tue Apr 3 2018
! NVRAM config last updated at 10:11:17 UTC Tue Apr 3 2018
version 15.1
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
no ipv6 cef
controller VDSL 0
interface Ethernet0
no ip address
interface ATM0
no ip address
shutdown
no ip address
no ip address
no ip address
shutdown
no ip address
shutdown
interface Vlan1
description VLAN1
ip nat inside
interface Dialer0
ip nat outside
encapsulation ppp
dialer pool 1
no cdp enable
interface Dialer1
no ip address
shutdown
no ip http server
line con 0
line aux 0
line vty 0 4
access-class 1 in
login local
transport input ssh
end
I have made a few minor adjustments to your configuration (marked in bold), add those and check if that makes a difference:
version 15.1
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
dns-server 8.8.8.8 8.8.4.4
ip cef
no ipv6 cef
controller VDSL 0
interface Ethernet0
no ip address
interface ATM0
no ip address
shutdown
no ip address
no ip address
no ip address
shutdown
no ip address
shutdown
interface Vlan1
description VLAN1
ip nat inside
interface Dialer0
ip mtu 1460
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1420
dialer pool 1
dialer-group 1
no cdp enable
no ip http server
dialer-list 1 protocol ip permit
line con 0
line aux 0
line vty 0 4
access-class 1 in
login local
transport input ssh
end
Thanks & Regards,
Antonin
Folks, Victory!
Thanks, my laptop is now connected via Ethernet to Fa0 and getting web pages with IP/DNS set to auto obtain from the router. The fix:
Antomin, I changed the MTU back to 1492 and used the "ip tcp adjust-mss 1452" within the dialer0 interface and got web pages straight away. This is something I have not done in Packet Tracer before (maybe yet!) when configuring switches and routers. I have covered the theory and understand the packet changes routing through different interfaces but thought the router would have handled this automatically. A little reading on my end before quizzing the lecturer :)
Georg Pauwen, you solved my DNS issue nicely. I was going to use my ISP DNS but wasn't sure how to set the router to obtain dynamically. So I thought I would set Google DNS but did it in the wrong place. This is what i need at the moment and will come back to your other highlighted changes when I connect my test lab.
The next step is connect my wireless AP and other devices to ensure all is working. Then sort out the SSH connection refused error and setup port forwarding for my Virtual Machine. After this, connect my Cisco test lab, 2 x 2801 and 2 x 2960 TTL, 1 x 1801 and a L3 switch when I have this setup.
Packet Tracer is good but doesn't beat bare metal. I appreciate the quality and speed of help here and will post my working config now, then my setup steps once I have sorted through my log.
Router#sh run
Current configuration : 2060 bytes
! Last configuration change at 13:38:20 UTC Tue Apr 3 2018
! NVRAM config last updated at 13:39:23 UTC Tue Apr 3 2018
version 15.1
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
no ipv6 cef
controller VDSL 0
interface Ethernet0
no ip address
interface ATM0
no ip address
shutdown
no ip address
no ip address
no ip address
shutdown
no ip address
shutdown
interface Vlan1
description VLAN1
ip nat inside
interface Dialer0
mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
no cdp enable
interface Dialer1
no ip address
shutdown
no ip http server
line con 0
line aux 0
line vty 0 4
access-class 1 in
login local
transport input ssh
end
Router#
adrian.popa
Hi all,
I am struggling to get my 887VAG to connect to vodafone UK VDSL2 network and I would really apreciate some help if anyone can spare the time. I have tried various configs but no joy so far. All I am getting is:
Bombur#sh control vDSL 0
Controller VDSL 0 is DOWN
Daemon Status: Establishing Link
XTU-R (DS) XTU-C (US)
Chip Vendor ID: 'BDCM' ' '
Chip Vendor Specific: 0x0000 0x0000
Chip Vendor Country: 0xB500 0x0000
Modem Vendor ID: 'CSCO' ' '
Modem Vendor Specific: 0x4602 0x0000
Modem Vendor Country: 0xB500 0x0000
Serial Number Near: FCZ161393GY C887VAG+ 15.2(4)M
Serial Number Far:
Modem Version Near: 15.2(4)M
Modem Version Far:
Modem Status: Idle
DSL Config Mode: VDSL2
Trained Mode:
TC Mode: UNKNOWN
Selftest Result: 0x00
DELT configuration: disabled
DELT state: not running
Trellis: OFF OFF
SRA: disabled disabled
SRA count: 0 0
Bit swap: enabled enabled
Full inits: 0
Failed full inits: 0
Short inits: 0
Failed short inits: 0
Firmware Source File Name (version)
VDSL embedded VDSL_LINUX_DEV_01212008 (1)
Modem FW Version: 130205_1433-4.02L.03.A2pv6C035j.d23j
Modem PHY Version: A2pv6C035j.d23j
Vendor Version: Ap6v35j.23j 68
Training Log : Stopped
Training Log Filename : flash:vdsllog.bin
My config is as follows:
version 15.2
no service pad
hostname Bombur
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone gmt -1 0
clock summer-time BST recurring last Sun Mar 2:00 last Sun Oct 3:00
ip cef
no ipv6 cef
license udi pid C887VAG+7-K9 sn FCZ161393GY
archive
log config
logging enable
logging size 500
vtp mode transparent
controller VDSL 0
operating mode vdsl2
modem customUKAnnexM
modem customUKAnnexA
modem UKfeature
controller Cellular 0
gsm gps mode standalone
vlan 10
name LAN:DATA
vlan 15
name LAN:VOICE
vlan 999
name NOT_USED
interface Ethernet0
no ip address
bandwidth 70000
pppoe enable group global
interface ATM0
no ip address
shutdown
description Livingroom-Hub
no ip address
duplex full
description Honeywell-Gateway
no ip address
duplex full
description Bedroom-TV
no ip address
duplex full
description Kids-Room
no ip address
duplex full
interface Cellular0
description BackupWAN
no ip address
ip nat outside
encapsulation slip
load-interval 30
shutdown
dialer in-band
dialer pool-member 1
no peer default ip address
async mode interactive
interface Vlan1
no ip address
interface Dialer0
bandwidth 70000
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer persistent
dialer-group 1
ppp chap hostname <xxxxx>@broadband.vodafone.co.uk
ppp chap password 0 <xxxxx>
ppp pap sent-username xxxxx password 0 xxxxx
ppp ipcp dns request accept
ppp ipcp wins request
ppp ipcp route default
no cdp enable
interface Dialer1
description Cellular
ip nat outside
encapsulation slip
shutdown
dialer pool 1
dialer persistent
dialer-group 1
no ip http server
ip dns server
control-plane
line con 0
no modem enable
line aux 0
line 3
no exec
line vty 0 4
login
transport input all
end
any help if greatly apreciated
