Cisco 887VA GUI search
Slurp
Hi there - I've inherited a Cisco 887VA router and have successfully factory reset it to 10.10.10.1. I can browse to it, using the default cisco/cisco credentials, but there seems to be no GUI - only a list of commands. Does such a GUI exist, or is there a configuration tool that can be downloaded ?
Thanks in advance.
11 Replies 11
pieterh
as the release notes mention a bug for this series it suggests there is a GUI f
CSCvv08356
AP 860VAE-W GUI does not reflect changes in WLAN Configuration
what do you mean with only a list of commands ? is this when accessing the router over http(s)?
did you configure an account/password first to login into the gui?
if you accessed from the cli check if the running config contains (default)
no ip http server
no ip http secure-server
 you can use
   configure terminal
      ip http server
   end
   write (or copy running-config startup-config
Yes, it's when I access it via https. I've not created any usernames or passwords - just went in as cisco/cisco. It sounds as though I have to jump through a couple of hoops before I can access a GUI. All advice gratefully received. Apologies for my ignorance, I come from a far simpler (Draytek) background !
Cheers, Steve
Pieterh,
Many thanks for this - I'll give it a go. Do I need to set up a username and password to access the GUI as well, or will the default cisco/cisco suffice ?
Regards, Steve
Pieterh,
I was hoping to avoid having to go down the CCA route, as they seem to want money for it ! I've managed to create my own username and password, with level 15 privileges, but am still getting the command list, rather than a GUI. Do I need to configure an IP address for one of the ports, rather than rely on the VLAN 10.10.10.1 ? I'm currently in Fast Internet Port 0.
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface Ethernet0
no ip address
shutdown
interface FastEthernet0
no ip address
spanning-tree portfast
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$CVO$
ip address 10.10.10.1 255.255.255.248
ip access-group 100 in
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1452
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
Again - thanks for your help with this. Steve
pieterh
Hi there,
some older GUI's only offer a web-interface to construct the CLI commands, not a  "real" GUI
if this is not what you are looking for, then stick to the command line using console-port or telnet/SSH
yes, normally you need an account attached to a service contract to download software,
did you try logging in with the same account you use for this forum ?
no you do not need to add another  ip-address, the current address is sufficient for now.
   ip http access-class 23  ->> check if an corresponding "access-list 23 "exists in the configuration
Pieterh,
Ah - that explains it. Yes, I'm getting the interface to construct commands. In a way, that's a relief. At least I'm not doing anything wrong. I'm just used to pointy-clicky configs.
Unfortunately I don't have a service contract with Cisco, as I only inherited this unit and am playing with it to see if it's worth setting up. I think I'll persist with it - just need to put it into a test environment where I can really get to grips with the fine tuning.
Thanks you so much for your time and patience on this - I'm genuinely grateful for your help in pointing me in the right direction.
Regards, Steve
you're welcome
balaji.bandi
can you post show version installed on the device.
if you have right image , you need create local user to access GUI :
username balaji privilege 15 xxxxxxxxxx xxxxxxxxxxxxx
BB
Balaji, it's version 15.5. I have a local username in place and the ip http settings all look correct. I suspect it's as Piterh says, it's not a true GUI - just a command builder.
Thanks for picking this up - I'm really grateful for the community support here.
post show version (full here) and dir flash:
BB
