Does the C-SM-16P4M2X support 100M?
newbieregarded
Couldn't find any pages about this module.
marce1000
 - FYI https://www.cisco.com/c/en/us/td/docs/routers/cloud_edge/c8300/Interface_Module_SCG/C-SMX16G4M2X-book.html#id_115004
 M.
I did catch that part in the output of that page, but can anybody confirm if this output with their own C8300 and C-SM-16P4M2X?
balaji.bandi
C-SM-16P4M2X
100M - Speed or distance.
As per Ethernet concern do support 100Meg connection speed.
If you looking distance -
This is only Line card - does support Various SFP
Depends on the SFP Module installed - will be covering the distance.you looking to establish the links
If you using Ethernet CAt5/6 - that is the Limitation of Category cable you using - that should cover 100M.
BB
