Cisco 887VA - "Controller VDSL 0 is DOWN"
michael.ludvig
I'm trying to configure Cisco 887VA as an ADSL router but can't even get past the first post - the modem / controller is stuck in DOWN state and I don't get "showtime". I triple-checked the physical connectivity, replaced the phone cable, upgraded the firmware but got nowhere.
Here is a couple of outputs:
wlgrt1#show interface ATM 0
ATM0 is down, line protocol is down
Hardware is MPC/AOE ATMSAR, address is 188b.9d40.ab68 (bia 188b.9d40.ab68)
MTU 1600 bytes, sub MTU 1600, BW 4608 Kbit/sec, DLY 80 usec,
Encapsulation ATM, loopback not set
Keepalive not supported
Encapsulation(s): AAL5
4 maximum active VCs, 1024 VCs per VP, 0 current VCCs
VC Auto Creation Disabled.
VC idle disconnect time: 300 seconds
Last input never, output never, output hang never
Queueing strategy: Per VC Queueing
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
wlgrt1#show interface ATM0.1
ATM0.1 is down, line protocol is down
Description: DSL
MTU 1600 bytes, BW 4608 Kbit/sec, DLY 80 usec,
Encapsulation ATM
0 OAM cells input, 0 OAM cells output
AAL5 CRC errors : 0
AAL5 SAR Timeouts : 0
AAL5 Oversized SDUs : 0
Total Number of VC(s): 1
Total Number of OAM VC(s): 0
Total Number of VP Datavc(s): 0
wlgrt1#show controller VDSL 0
Daemon Status: Establishing Link
XTU-R (DS) XTU-C (US)
Chip Vendor ID: 'BDCM' ' '
Chip Vendor Specific: 0x0000 0x0000
Chip Vendor Country: 0xB500 0x0000
Modem Vendor ID: 'CSCO' ' '
Modem Vendor Specific: 0x4602 0x0000
Modem Vendor Country: 0xB500 0x0000
Serial Number Near: FGL1930xxxx C887VA-K 15.3(3)M5
Serial Number Far:
Modem Version Near: 15.3(3)M5
Modem Version Far:
Modem Status: Idle
DSL Config Mode: AUTO
Trained Mode:
TC Mode: UNKNOWN
Selftest Result: 0x00
DELT configuration: disabled
DELT state: not running
Trellis: OFF OFF
SRA: disabled disabled
SRA count: 0 0
Bit swap: enabled enabled
Full inits: 0
Failed full inits: 0
Short inits: 0
Failed short inits: 0
Firmware Source File Name (version)
VDSL user config flash:VA_A_39d_B_38h3_24h_1.bin (10)
Modem FW Version: 151222_0037-4.02L.03.A2pv6C039d.d24h
Modem PHY Version: A2pv6C039d.d24h
Vendor Version: Ap6v39d.24h 68
Training Log : Stopped
Training Log Filename : flash:vdsllog.bin
Here is my config:
wlgrt1#show running-config
Building configuration...
Current configuration : 4284 bytes
! Last configuration change at 14:10:50 NZDT Tue Feb 23 2016 by admin
version 15.3
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service password-encryption
hostname wlgrt1
boot-start-marker
boot-end-marker
aqm-register-fnf
enable secret 5 xxxx
aaa new-model
aaa authentication login default local
aaa session-id common
vlan ifdescr detail
no ip source-route
no ip gratuitous-arps
no ip bootp server
ip cef
no ipv6 cef
license udi pid C887VA-K9 sn FGL1930xxxx
username admin privilege 15 secret 5 xxxx
controller VDSL 0
firmware filename flash:VA_A_39d_B_38h3_24h_1.bin
ip ssh version 2
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no atm ilmi-keepalive
interface ATM0.1 point-to-point
description DSL
pvc 0/100
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface Ethernet0
no ip address
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
no ip address
interface Dialer0
ip address negotiated
ip access-group INTERNET-IN in
no ip redirects
no ip unreachables
ip mtu 1492
ip nat outside
ip virtual-reassembly in
encapsulation ppp
dialer pool 1
ppp authentication chap optional
ppp chap hostname xxxx@orcon.net.nz
ppp chap password 7 xxxx
ppp pap sent-username xxxx@orcon.net.nz password 7 xxxx
ppp ipcp route default
no cdp enable
ip forward-protocol nd
ip dns server
ip access-list extended INTERNET-IN
deny igmp any any
permit ip any any
ip prefix-list VDSL-DEFROUTE seq 5 permit 0.0.0.0/0
dialer-list 1 protocol ip permit
dialer-list 10 protocol ip permit
no cdp run
route-map OSPF-VDSL permit 10
match ip address prefix-list VDSL-DEFROUTE
access-list 101 permit ip any any
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
session-timeout 180
privilege level 15
no modem enable
line vty 0 4
session-timeout 180
privilege level 15
transport input ssh
scheduler allocate 20000 1000
ntp server nz.pool.ntp.org
end
Whatever I do all I get is "Controller VDSL 0 is DOWN" and "Modem Status: Idle". The modem used to work in our other office on a VDSL link (this office only has ADSL).
Any idea what to do?
Thanks!
Michael
6 Replies 6
Philip D'Ath
It is not detecting any xDSL signal.  How confident are you that the circuit has xDSL turned on?  Can you test it with another device to confirm it?
It used to work with ISP provided modem but never with this Cisco box. I will try to put the old modem back in tomorrow. Thanks for the suggestion.
Did you ever find a solution to this?
Giuseppe Larosa
Hello Michael,
ADSL and VDSL are different transmission standards, I don't think you can connect a VDSL CPE to an ADSL line unless backward compatibiity is supported and configured.
ADSL2+ is backward compatible with ADSL.
But VDSL is a different matter.
see
https://www.broadband-forum.org/downloads/About_DSL.pdf
try under controller vdsl 0
operating mode auto
Hope to help
Giuseppe
The 887VA can do both VDSL and ADSL (that's what the "VA" in its product code stands for).
darthtrainer
Hi, i assume your PVC is correct for your country, under the ATM interface. Have you run any debug's on the ATM line to see if any errors crop up when it tries to synch? Phil
