Cisco ASA Nat question
maniac79
I have an asa 5510 that I want to have two ports forwarded to an IP that is set as an object
I have
object network test-server
 nat (inside,outside) static interface service tcp 3399 3399
I also want the same object to forward port 1411 to that address but it won't let me add both, how can I do this?
maniac79
Ended up just adding another network object with the same local IP and that did the trick. I'm sure there is a better way though.
You can group them if you like to simplify the objects.
BB
