Bookmark
Subscribe
1854
Cisco C6807-XL core switch VSS configuration with redundant sup
sofonias.ie
I have two Cisco C6807-XL core switches with redundant sup engine (C6800-SUP6T-XL). I want to configure VSS between this switches using both sup's. Is there additional commands needed in addition to the normal VSS configuration? If there is please give me a guide line.
With regards.
There shouldn't be any thing additional to VSS Config.
Refer below doc as reference:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/15-3SY/config_guide/sup6T/15_3_sy_swcg_6T/virtual_switching_systems.pdf
Thank you, I will check it.
