Cisco Catalyst 3560-CX Factory Reset?
keithhampshire
I have searched the internet trying to find a way to do a factory reset on the
Catalyst 3560-CX switch
and I found NO luck.
I am consoled holding the "Mode" button down while switch boots and get to the "switch :" prompt. I type
flash_init
and all I get is this (see attached). Nothing workings. This all started when I configured a password for "line con 0" login local but no username. So, to test I logged out and now it asks me for a username. I never configured a username so I'm stuck-like-chuck.
How can I do a factory reset on these little switch?
Seb Rupik
Hi there,
After
flash_init
  what is the output if you type just
dir ?
Does it list flash as a drive, if so what is the output of:
dir flash:
cheers,
Seb.
8 Replies 8
Seb Rupik
Hi there,
After
flash_init
dir ?
dir flash:
cheers,
Seb.
May be on to something. Stay tuned.....
Looks good, that should prompt you for initial setup once it has booted.
That did work! Good to go. Thanks.
Hi here, i have the same problem and did the same thing you asked but the boot: command is not working. Can you help please? Here the screen
keithhampshire
Tried typing "reset" as well but failed and is still prompting for a username.
Uriel_Muruato
Alguien ya soluciono el como resetear el switch por completo?
EnricoSavazzi
I am using a C3650CX with firmware 15.2(4).E2. It required just minor changes to the procedure described above:
delete flash:/config.text
delete flash:/vlan.dat
reload
After reloading it attempted several times to download files from a TFTP server, which took some time, but eventually displayed the switch> prompt.
