CISCO GSR 12000
omar_maiah
I have a question about the GSR RP active and standby selection procedure.
As i know the default behaviour is when the GSR boots it selects the RP in the lower slot as active and the other one will be standby.
Can this behaviour be changed ? how can i specify which RP i want to active once the GSR boots regardless of the slot number.
Mahesh Gohil
Level 7
Level 7
Yes you can with
#redundancy prefer slot ?
  <0-7>  Slot number of preferred active location
above command
Mahesh
Thanks for your response, but this works for GRP not for PRP
HI Omar,
This command should work with PRP as well. Did you try it ?
Laurent.
