Cisco ios 12.4 power inline time range
Yordi Mahieu
                   Hello i have a ip-cam that is connect with power inline on my cisco router,
i want to scheduler a reboot daily, of this ip-cam is there a posibility to use a daily time (time-range) to shutdown the interface and back up, or shutdown de inline power on this interface and back up ? i have ios version 12.4
890?  I have alot of these in my network and EnergyWise is supported.
So you want your IP Camera to reboot every night?  Let's say midnight, OK?
!  Global
energywise domain security shared-secret
energywise importance 60
!  Time Range
time-range ON
absolute start 00:00 01 February 2013
periodic daily 0:01 to 23:59
time-range OFF
periodic daily 0:0 to 0:01
!  Interface
interface GigabitEthernet0/1
energywise level 10 recurrence importance 70 time-range ON
energywise level  0 recurrence importance 70 time-range OFF
Leo Laohoo
Errr ... A router which provides PoE?  You either have a switch module or a switch.
You would need to be more specific than that.
I am not even sure if your switch/router can support EnergyWise if you don't provide specific information.
Can you post the output to the command "sh version"?
Cisco IOS Software, C890 Software (C890-UNIVERSALK9-M), Version 15.2(3)T, RELEAS        E SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Sat 24-Mar-12 02:02 by prod_rel_team
ROM: System Bootstrap, Version 12.4(22r)YB3, RELEASE SOFTWARE (fc1)
spui uptime is 2 weeks, 2 days, 14 hours, 7 minutes
System returned to ROM by reload at 19:48:20 CEST Sun Jan 20 2013
System restarted at 19:48:56 CEST Sun Jan 20 2013
System image file is "flash:c890-universalk9-mz.152-3.T.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 892 (MPC8300) processor (revision 1.0) with 498688K/25600K bytes of memory.
Processor board ID FCZ16319166
9 FastEthernet interfaces
1 Gigabit Ethernet interface
1 ISDN Basic Rate interface
1 Virtual Private Network (VPN) Module
256K bytes of non-volatile configuration memory.
250880K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO892-K9           FCZ16319166
License Information for 'c890'
    License Level: advipservices   Type: Permanent
    Next reboot license Level: advipservices
spui#show energywise version
EnergyWise is Disabled
It is 1 Router with custumor, NO Energywise domaine, or software.... this one router has 3 IP-cam with poe, that i want to let reboot every day so --> shutdown interface or shutdown POE for 1 minute a day.
!  Global
!  Time Range
time-range ON
time-range OFF
!  Interface
Thanks for the ratings.
