problem in cofiguring bridge domain
**Hamid**
I have configured a bridge domain between two ports of router (Gi 0/1 and Gi 0/2) and also i have configured a BDI interface and assigned an IP address (192.168.1.1/24) to it. In the picture below, you can see my topology.
my problem is, the two router in below could not ping the BDI interface IP address.
Thank you so much for your help
20 Replies 20
do you config BVI interface ?
interface GigabitEthernet 0/1
no ip address
negotiation auto
service instance 100 ethernet
encapsulation untagged
bridge-domain 100
interface GigabitEthernet 0/2
no ip address
negotiation auto
service instance 200 ethernet
bridge-domain 200
Interface Bdi 2
no shut
you use two bridge-domain number it must be one
bridge-domain 100
and interface must be
interface bdi 100
i have corrected it but still i can not ping the ip address of 192.168.1.1 from the two below router.
i do not know the way that i have configured the bridge domain is right or not?
share the config
MHM
interface GigabitEthernet0/0/1
no ip address
media-type rj45
negotiation auto
bridge-domain 100
interface GigabitEthernet0/0/2
no ip address
media-type sfp
negotiation auto
cdp enable
bridge-domain 100
interface BDI100
show ip interface brief
GigabitEthernet0/0/0 unassigned YES NVRAM up up
GigabitEthernet0/0/1 unassigned YES NVRAM up up
GigabitEthernet0/0/2 unassigned YES NVRAM up up
GigabitEthernet0/0/3 unassigned YES NVRAM up up
Te0/0/4 unassigned YES NVRAM down down
Te0/0/5 unassigned YES NVRAM down down
Te0/0/6 unassigned YES NVRAM down down
Te0/0/7 unassigned YES NVRAM down down
GigabitEthernet0 unassigned YES NVRAM administratively down down
BDI100 192.168.1.1 YES manual up up
check @Blue_Bird  notes it for IOS and you have IOS XE but let see result.
if not work then can you share the config of both other routers?
note:- regarding @Blue_Bird  note add the three command not only one.
MHM
there is a vrf in the below routers, i mean the ip address of 192.168.1.2 and 192.168.1.3 are in vrf 5.
i've tried to ping vrf 5 192.168.1.1 from the below routers, but i could not ping the 192.168.1.1 ip address
DanielP211
Hello!
Could you paste the configuration? Which device are you using? If the ports are switch ports, why not use vlans?
BR
****Kindly rate all useful posts*****
how can i use VLAN in my current configuration?
the device that i have configured BDI is N520-4G4Z-A
and the two routers below are C8300-1N1S-6T
