Cisco IR829 software upgrade
Dear All,
How to set boot system parameter before reloading the router.
I have upload the bundle image via TFTP. I want to run this new image, but how to set the boot system parameter ?
Normal routers are easy to upgrade, here I can see hypervisor, Guest-OS which are a bit confusing.
Can anyone helps me with the procedure to upgrade the IR829 router to the latest OS as I am having facing issues, so just wanted to upgrade. Currently the router is shipped with the normal OS without bundle image. If I want to upgrade the software, I have to download the bundle image and push it to the router and install the new OS.
I am done with pushing the OS to the router, but seeking for an information to install the new software. Can anyone paste the line by line upgrade procedure after pushing the OS step, with the description of that procedure.
balaji.bandi
Supposing my new iOS name is ir800-universalk9-bundle.SPA.158-3.M6.bin
First copy tftp: flash:
Enter the remote ip of where the new iOS is located, make sure the tftp server is running as well.
after copying the new iOS to the flash drive of the ir829.
Enter in the privilege mode: bundle install flash:ir800-universalk9-bundle.SPA.158-3.M6.bin
Then wait for it to finish its installation.
Reload after completion.
