Cisco ISR 1111-8P reboots randomly
MarkusD
Hi there,
about 6 month ago I bought a Cisco C1111-8P ISR router with IOS XE Version 16.12.04.
It is working as an edge router for DSL dialup. So no really special configuration. (Ok, source based routing for direct IPv6 and tunneled HE-Uplink; both static IPs).
So far it is working fine. But last month I experienced 2 unexpected reboots of the router.
The syslog (remote logging server) stays empty. No SSH login that time or any error message.
In
bootflash:/tracelogs/ I found 3 files named shutdown_cc0.log, shutdown_fp0.log and shutdown_rp0.log
I attached them to this post.
In every file I could find a line like see
pvp pvp_0-0.17986_0.20220217042043.bin
log for how shutdown got started on this FRU
I could find that file gzip-compressed and decompressed it. Unfortunately it is not a text file.
Do you have idea, how I can investigate those reloads?
Is it save to attach that bin log or are there any sensitive information included?
Thanks a lot for any help.
@MarkusD wrote:
Sorry, there is a lot of sensitive information in this file. I have to delete it again here.
No, it does not.  It was a CORE DUMP from the QFP.  Only TAC would have access to read it.
Need sleep.
I'll have a look at this tomorrow.
In regards to unable to download software because there is no maintenance contract, keep an eye out on the Cisco Security Bulletin.
In the next few weeks, there will be PSIRT/software vulnerability announcement and will affects all IOS-XE from 17.3.4 and earlier.  The fix will be in 16.12.7 and 17.3.5 (not sure about the rest).
When this happens, read the Security Bulletin very carefully.  Each Security Bulletin should have a section called "Customers Without Service Contracts" and it should read:
Customers who purchase directly from Cisco but do not hold a Cisco service contract and customers who make purchases through third-party vendors but are unsuccessful in obtaining fixed software through their point of sale should obtain upgrades by contacting the Cisco TAC.
Customers should have the product serial number available and be prepared to provide the URL of this advisory as evidence of entitlement to a free upgrade.
Read it.  Understand it.
Hope this helps.
10 Replies 10
balaji.bandi
Looks for me some bug, how long this version running on this Router, If you get chance upgrade to latest stable  and check or contact TAC.
BB
MarkusD
The router was shipped with this firmware.
I do not have a Smartnet Contract for this router. Therefore I can't contact TAC, I suppose.
Is there any way to display the pvp binlog in a human readable way?
marce1000
                                       >...Do you have idea, how I can investigate those reloads?
- Connect to the ISR (SSH) with https://cway.cisco.com/cli  , at the top right  , press or run
Crashdump Analyzer
, as stated  already , consider upgrade to latest advisory release : https://software.cisco.com/download/home/286321996/type/282046477/release/Amsterdam-17.3.4a
 M.
Leo Laohoo
Post the complete output to the following commands:
  1. sh version
  2. dir
  3. dir bootflash:core
Thanks a lot for your replies.
Here are the outputs of the mentioned commands:
sh version
Cisco IOS XE Software, Version 16.12.04 Cisco IOS Software [Gibraltar], ISR Software (ARMV8EL_LINUX_IOSD-UNIVERSALK9-M), Version 16.12.4, RELEASE SOFTWARE (fc5) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2020 by Cisco Systems, Inc. Compiled Thu 09-Jul-20 20:16 by mcpre Cisco IOS-XE software, Copyright (c) 2005-2020 by cisco Systems, Inc. All rights reserved. Certain components of Cisco IOS-XE software are licensed under the GNU General Public License ("GPL") Version 2.0. The software code licensed under GPL Version 2.0 is free software that comes with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such GPL code under the terms of GPL Version 2.0. For more details, see the documentation or "License Notice" file accompanying the IOS-XE software, or the applicable URL provided on the flyer accompanying the IOS-XE software. ROM: 16.12(2r) Router uptime is 1 day, 4 hours, 38 minutes Uptime for this control processor is 1 day, 4 hours, 40 minutes System returned to ROM by LocalSoft at 20:58:12 CET Sun Nov 7 2021 System restarted at 07:02:28 CET Tue Mar 1 2022 System image file is "bootflash:c1100-universalk9.16.12.04.SPA.bin" Last reload reason: LocalSoft This product contains cryptographic features and is subject to United States and local country laws governing import, export, transfer and use. Delivery of Cisco cryptographic products does not imply third-party authority to import, export, distribute or use encryption. Importers, exporters, distributors and users are responsible for compliance with U.S. and local country laws. By using this product you agree to comply with applicable laws and regulations. If you are unable to comply with U.S. and local laws, return this product immediately. A summary of U.S. laws governing Cisco cryptographic products may be found at: http://www.cisco.com/wwl/export/crypto/tool/stqrg.html If you require further assistance please contact us by sending email to export@cisco.com. Suite License Information for Module:'esg' -------------------------------------------------------------------------------- Suite Suite Current Type Suite Next reboot -------------------------------------------------------------------------------- FoundationSuiteK9 None Smart License None securityk9 appxk9 Technology Package License Information: ----------------------------------------------------------------- Technology Technology-package Technology-package Current Type Next reboot ------------------------------------------------------------------ appxk9 None Smart License None uck9 None Smart License None securityk9 None Smart License None ipbase ipbasek9 Smart License ipbasek9 The current throughput level is unthrottled Smart Licensing Status: UNREGISTERED/No Licenses in Use cisco C1111-8P (1RU) processor with 1398091K/6147K bytes of memory. Processor board ID FCZ2530R27V 2 Virtual Ethernet interfaces 10 Gigabit Ethernet interfaces 32768K bytes of non-volatile configuration memory. 4194304K bytes of physical memory. 2863103K bytes of flash memory at bootflash:. 0K bytes of WebUI ODM Files at webui:. Configuration register is 0x2102
dir
Directory of bootflash:/ 11 drwx 16384 Jul 20 2021 08:49:31 +01:00 lost+found 138721 drwx 4096 Nov 7 2021 21:01:10 +01:00 .prst_sync 12 -rw- 35 Aug 14 2021 11:58:04 +01:00 pnp-tech-time 13 -rw- 79731 Aug 14 2021 11:58:13 +01:00 pnp-tech-discovery-summary 14 -rw- 542525852 Jul 20 2021 08:52:04 +01:00 c1100-universalk9.16.12.04.SPA.bin 97921 drwx 4096 Mar 1 2022 07:01:49 +01:00 .installer 89761 drwx 4096 Mar 1 2022 06:59:51 +01:00 core 122401 drwx 4096 Jul 20 2021 08:57:12 +01:00 .rollback_timer 114241 drwx 4096 Jul 20 2021 08:57:13 +01:00 gs_script 15 -rw- 132108 Mar 1 2022 07:02:26 +01:00 memleak.tcl 40801 drwx 4096 Jul 20 2021 08:57:23 +01:00 virtual-instance 48961 drwx 4096 Aug 14 2021 12:06:57 +01:00 .dbpersist 57121 drwx 53248 Mar 2 2022 11:32:25 +01:00 tracelogs 65281 drwx 4096 Jul 20 2021 08:57:45 +01:00 .attrib 16 -rw- 30 Mar 1 2022 07:02:42 +01:00 throughput_monitor_params 73441 drwx 4096 Jul 20 2021 08:57:50 +01:00 onep 146881 drwx 4096 Mar 1 2022 07:02:49 +01:00 license_evlog 17 -rw- 656 Aug 14 2021 12:35:52 +01:00 vlan.dat 18 -rw- 11318 Aug 14 2021 21:18:38 +01:00 running_210814.txt 21 -rw- 274 Oct 30 2021 21:11:41 +01:00 btdecode_err 19 -rw- 8325 Aug 22 2021 14:28:06 +01:00 startup_210822.txt 20 -rw- 12429 Aug 22 2021 15:13:03 +01:00 shaping-test_210822.txt 22 -rw- 2672640 Oct 16 2021 12:13:52 +01:00 nbar2_http_default.tar 171361 drwx 4096 Oct 16 2021 12:13:54 +01:00 nbar2 106081 drwx 4096 Oct 16 2021 12:20:50 +01:00 guest-share 36 -rw- 9757 Nov 9 2021 16:12:04 +01:00 startup_211109.txt 2908606464 bytes total (2112970752 bytes free)
dir bootflash:core
Directory of bootflash:/core/ 97923 drwx 4096 Jul 20 2021 08:57:11 +01:00 modules 89762 -rw- 1 Mar 2 2022 11:32:56 +01:00 .callhome 89763 -rw- 15232975 Aug 14 2021 20:54:21 +01:00 Router_RP_0_qfp-ucode-tsn-le_17679_20210814-205402-CET.core.gz 89764 -rw- 19512780 Nov 1 2021 16:26:20 +01:00 Router_RP_0_qfp-ucode-tsn-le_17657_20211101-162559-CET.core.gz 89765 -rw- 19655984 Feb 17 2022 01:19:36 +01:00 Router_RP_0_qfp-ucode-tsn-le_17692_20220217-011914-CET.core.gz 89766 -rw- 18477992 Feb 17 2022 05:18:10 +01:00 Router_RP_0_qfp-ucode-tsn-le_17891_20220217-051749-CET.core.gz 89767 -rw- 16080432 Mar 1 2022 06:59:51 +01:00 Router_RP_0_qfp-ucode-tsn-le_17734_20220301-065931-CET.core.gz 2908606464 bytes total (2112905216 bytes free)
And another reload again. This time the PPPoE tunnel of the Dialer interface got reconnected first.
The following happened according to my logs:
Mar  2 10:57:22.987: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access2, changed state to down
Mar 2 10:58:18.832: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access2, changed state to up
And at 11:04 the router rebooted again.
Upload this file.
Alternatively, raise a TAC Case and get them to verify if this is CSCvy57684.
Requested file is attached.
I had to zip it again, since gz extension is not allowed here.
Nevertheless, thanks a lot for your help.
Need sleep.
Hope this helps.
 - Strong advise to upgrade https://software.cisco.com/download/home/286321996/type/282046477/release/Amsterdam-17.3.4a
 M.
