Cisco ISR 4331 not booting normally and not configured
razeev rohilla
Hi All,
when i tried configure Cisco ISR 4331 Router it hanged 2 twice and i restart it, after restart, Router Booting with image ISR Software (X86_64_LINUX_IOSD-UCMK9-M), Version 16.9.2, RELEASE SOFTWARE (fc1). Instead of ISR Software (X86_64_LINUX_IOSD-UNIVERSLAK9-M), Version 16.6.6 image. below is the outcome. Please help me to understand
tunnel Open a tunnel connection
ucse UCSE server
udptn Open an udptn connection
undebug Disable debugging functions (see also 'debug')
upgrade Upgrade commands
utd Unified Threat Defense commands
verify Verify a file
voice Voice Commands
vtp Configure global VTP state
where List active connections
which-route Do OSI route table lookup and display results
who who
write Write running configuration to memory, network, or
terminal
xconnect Xconnect EXEC commands
xprofile Profile operations
xremote Enter XRemote mode
Router# reload
Proceed with reload? [confirm]
*Jun 5 14:39:45.687: %SYS-5-RELOAD: Reload requested by console. Reload Reason: Reload Command.Jun 5 14:40:16.971: %PMA
Initializing Hardware ...
Checking for PCIe device presence...done
System integrity status: 0x610
Rom image verified correctly
System Bootstrap, Version 16.7(3r), RELEASE SOFTWARE
Copyright (c) 1994-2017 by cisco Systems, Inc.
Current image running: Boot ROM0
Last reset cause: LocalSoft
ISR4331/K9 platform with 8388608 Kbytes of main memory
no valid BOOT image found
Final autoboot attempt from default boot device...
Located isr4300-ucmk9.16.9.2.SPA.bin
Package header rev 1 structure detected
IsoSize = 421446537
Calculating SHA-1 hash...Validate package: SHA-1 hash:
calculated CFE7CA01:1CCB97D4:03D19C9A:FBD47C48:0FBFF2D7
expected CFE7CA01:1CCB97D4:03D19C9A:FBD47C48:0FBFF2D7
RSA Signed RELEASE Image Signature Verification Successful.
Image validated
DCUBE_SUBSYS Initialized
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
Cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software [], ISR Software (X86_64_LINUX_IOSD-UCMK9-M), Version 16.9.2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Sat 08-Sep-18 02:36 by cedge-sw-dev
PLEASE READ THE FOLLOWING TERMS CAREFULLY. INSTALLING THE LICENSE OR
LICENSE KEY PROVIDED FOR ANY CISCO SOFTWARE PRODUCT, PRODUCT FEATURE,
AND/OR SUBSEQUENTLY PROVIDED SOFTWARE FEATURES (COLLECTIVELY, THE
"SOFTWARE"), AND/OR USING SUCH SOFTWARE CONSTITUTES YOUR FULL
ACCEPTANCE OF THE FOLLOWING TERMS. YOU MUST NOT PROCEED FURTHER IF YOU
ARE NOT WILLING TO BE BOUND BY ALL THE TERMS SET FORTH HEREIN.
Your use of the Software is subject to the Cisco End User License Agreement
(EULA) and any relevant supplemental terms (SEULA) found at
http://www.cisco.com/c/en/us/about/legal/cloud-and-software/software-terms.html.
You hereby acknowledge and agree that certain Software and/or features are
licensed for a particular term, that the license to such Software and/or
features is valid only for the applicable term and that such Software and/or
features may be shut down or otherwise terminated by Cisco after expiration
of the applicable license term (e.g., 90-day trial period). Cisco reserves
the right to terminate any such Software feature electronically or by any
other means available. While Cisco may provide alerts, it is your sole
responsibility to monitor your usage of any such term Software feature to
ensure that your systems and networks are prepared for a shutdown of the
Software feature.
% Failed to initialize nvram
% Failed to initialize backup nvram
cisco ISR4331/K9 (1RU) processor with 3836304K/6147K bytes of memory.
Processor board ID FDO2304A1TA
3 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
8388608K bytes of physical memory.
6598655K bytes of flash memory at bootflash:.
Press RETURN to get started!
*Jun 5 14:45:35.912: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Jun 5 14:45:35.982: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = esg Next reboot level = ipbasek9 and License = No valid license found
*Jun 5 14:45:36.267: %ISR_THROUGHPUT-6-LEVEL: Throughput level has been set to 100000 kbps
*Jun 5 14:45:37.253: %IOSXE_RP_NV-3-NV_ACCESS_FAIL: Initial read of NVRAM contents failed
*Jun 5 14:45:38.183: %IOSXE_RP_NV-3-BACKUP_NV_ACCESS_FAIL: Initial read of backup NVRAM contents failed
*Jun 5 14:45:39.100: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Jun 5 14:45:39.124: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Jun 5 14:45:45.426: %GENERIC_SUBBLOCK-2-LATE_REGISTER: Late registration of GSB type pbr_color_sb, with id -9223277123741588776
*Jun 5 14:45:50.102: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Jun 5 14:45:50.616: in NSH init
*Jun 5 14:45:50.684: %VOICE_HA-7-STATUS: CUBE HA-supported platform detected.
*Jun 5 14:45:51.779: %LINK-3-UPDOWN: Interface Lsmpi0, changed state to up
*Jun 5 14:45:51.796: %LINK-3-UPDOWN: Interface EOBC0, changed state to up
*Jun 5 14:45:51.797: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0, changed state to up
*Jun 5 14:45:51.811: %LINEPROTO-5-UPDOWN: Line protocol on Interface LI-Null0, changed state to up
*Jun 5 14:45:51.812: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to down
*Jun 5 14:45:52.342: %LINK-3-UPDOWN: Interface LIIN0, changed state to up
*Jun 5 14:45:52.801: %LINEPROTO-5-UPDOWN: Line protocol on Interface Lsmpi0, changed state to up
*Jun 5 14:45:52.801: %LINEPROTO-5-UPDOWN: Line protocol on Interface EOBC0, changed state to up
*Jun 5 14:45:53.877: %IOSXE_MGMTVRF-6-CREATE_SUCCESS_INFO: Management vrf Mgmt-intf created with ID 1, ipv4 table-id 0x1, ipv6 table-id 0x1E000001
*Jun 5 14:45:53.932: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Jun 5 14:45:53.932: %LINEPROTO-5-UPDOWN: Line protocol on Interface LIIN0, changed state to up
*Jun 5 14:42:45.074: %IOSXE-3-PLATFORM: R0/0: kernel: dmi: Firmware registration failed.
*Jun 5 14:45:39.459: %CMLIB-3-THROUGHPUT_VALUE_SETUP_FAILED: R0/0: cmand: Throughput license found, throughput set to 14700000 kbps. Error: Invalid argument
*Jun 5 14:45:57.707: %SYS-6-STARTUP_CONFIG_IGNORED: System startup configuration is ignored based on the configuration register setting.
*Jun 5 14:45:57.720: %IOSXE_OIR-6-REMSPA: SPA removed from subslot 0/0, interfaces disabled
*Jun 5 14:45:57.734: %SPA_OIR-6-OFFLINECARD: SPA (ISR4331-3x1GE) offline in subslot 0/0
*Jun 5 14:45:57.739: %IOSXE_OIR-6-INSCARD: Card (fp) inserted in slot F0
*Jun 5 14:45:57.739: %IOSXE_OIR-6-ONLINECARD: Card (fp) online in slot F0
*Jun 5 14:45:57.777: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 0
*Jun 5 14:45:57.777: %IOSXE_OIR-6-ONLINECARD: Card (cc) online in slot 0
*Jun 5 14:45:57.781: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 1
*Jun 5 14:45:57.781: %IOSXE_OIR-6-ONLINECARD: Card (cc) online in slot 1
*Jun 5 14:45:57.847: %IOSXE_OIR-6-INSSPA: SPA inserted in subslot 0/0
*Jun 5 14:45:58.024: SDWAN INFO: Interface = GigabitEthernet0 mgmt
*Jun 5 14:45:58.024: SDWAN INFO: SDWAN system init done
*Jun 5 14:45:58.135: yang-infra: Auto enable netconf-yang
*Jun 5 14:45:58.172: %ONEP_BASE-6-SS_ENABLED: ONEP: Service set Base was enabled by Default
*Jun 5 14:45:58.673: yang-infra: netconf-yang server has been notified to start
*Jun 5 14:46:00.990: %SYS-5-RESTART: System restarted --
*Jun 5 14:46:04.409: %SYS-6-BOOTTIME: Time taken to reboot after reload = 379 seconds
*Jun 5 14:46:09.373: %Cisco-SDWAN-Router-SYSMGR-5-NTCE-200050: R0/0: SYSMGR: System status blinking green (reason: Coming up)
*Jun 5 14:46:09.382: %Cisco-SDWAN-Router-SYSMGR-5-NTCE-200042: R0/0: SYSMGR: Created shared memory vconfd_shared_region
CRYPTO_PKI: setting trustpoint policy for TP-self-signed-2482764321 to specify TP-self-signed-2482764321 keypair usage% Generating 2048 bit RSA keys, keys will be non-exportable...
*Jun 5 14:46:10.773: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Jun 5 14:46:10.773: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
*Jun 5 14:46:09.621: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon confd @ pid 3405 in vpn 65534
*Jun 5 14:46:11.615: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named CISCO_IDEVID_SUDI has been generated or imported
*Jun 5 14:46:11.664: %PKI-2-NON_AUTHORITATIVE_CLOCK: PKI timers have not been initialized due to non-authoritative system clock. Ensure system clock is configured/updated.
[OK] (elapsed time was 3 seconds)
*Jun 5 14:46:14.426: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named TP-self-signed-2482764321 has been generated or imported
*Jun 5 14:46:14.428: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Jun 5 14:46:14.492: yang-infra: ERROR: Failed to create a new self-signed trustpoint
*Jun 5 14:46:14.671: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named TP-self-signed-2482764321.server has been generated or imported
*Jun 5 14:46:28.806: %ONEP_BASE-6-SS_ENABLED: ONEP: Service set Vty was enabled by Platform
*Jun 5 14:46:29.215: %ONEP_BASE-6-CONNECT: [Element]: ONEP session Application:com.cisco.syncfd Host:Router ID:8021 User:a has connected.
*Jun 5 14:46:32.978: AUTH-FEAT-BC-EVENT: [Gi0/0/0] Nothing to convert
*Jun 5 14:46:33.090: AUTH-FEAT-BC-EVENT: [Gi0/0/1] Nothing to convert
*Jun 5 14:46:33.108: AUTH-FEAT-BC-EVENT: [Gi0/0/2] Nothing to convert
*Jun 5 14:46:33.117: %SPA_OIR-6-ONLINECARD: SPA (ISR4331-3x1GE) online in subslot 0/0
*Jun 5 14:46:34.967: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to down
*Jun 5 14:46:35.080: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/1, changed state to down
*Jun 5 14:46:35.098: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/2, changed state to down
*Jun 5 14:46:35.316: %ONEP_BASE-6-CONNECT: [Element]: ONEP session Application:com.cisco.nesd Host:Router ID:3663 User:NETCONF has connected.
*Jun 5 14:46:37.004: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon cfgmgr @ pid 8878 in vpn 0
*Jun 5 14:46:37.006: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon fpmd @ pid 8879 in vpn 0
*Jun 5 14:46:37.008: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon ftmd @ pid 8880 in vpn 0
*Jun 5 14:46:37.012: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon ompd @ pid 8881 in vpn 0
*Jun 5 14:46:37.014: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon ttmd @ pid 8882 in vpn 0
*Jun 5 14:46:37.017: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon vdaemon @ pid 8883 in vpn 0
*Jun 5 14:46:37.431: %Cisco-SDWAN-Router-FPMD-6-INFO-1100001: R0/0: FPMD: Starting
*Jun 5 14:46:37.673: %Cisco-SDWAN-Router-TTMD-6-INFO-1200001: R0/0: TTMD: Starting
*Jun 5 14:46:37.805: %Cisco-SDWAN-Router-OMPD-5-NTCE-400001: R0/0: OMPD: Starting
*Jun 5 14:46:37.834: %Cisco-SDWAN-Router-CFGMGR-6-INFO-300001: R0/0: CFGMGR: Starting
*Jun 5 14:46:38.172: %Cisco-SDWAN-Router-FTMD-6-INFO-1000020: R0/0: FTMD: SLA class '__all_tunnels__' added at index '0': loss = 128%, latency = 2147483647 ms
*Jun 5 14:46:38.814: %Cisco-SDWAN-Router-FTMD-4-WARN-1000007: R0/0: FTMD: Connection to TTM came up. p_msgq 0x7f107d235500 p_ftm 0x9296f0
*Jun 5 14:46:39.778: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Jun 5 14:46:39.784: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
*Jun 5 14:46:41.775: SDWAN INFO: application database sync to FPM: record-count 1426 error 76
*Jun 5 14:46:53.337: %NDBMAN-5-ACTIVE: R0/0: ndbmand: All data providers active.
*Jun 5 14:46:57.737: %DMI-5-ACTIVE: R0/0: dmiauthd: process is in steady state.
*Jun 5 14:47:11.051: %MODULE_STATE-6-ALL_MODULES_UP: All modules are now on-line.
*Jun 5 14:47:06.985: %DMI-5-INITIALIZED: R0/0: syncfd: process has initialized.
*Jun 5 14:47:15.017: %DMI-3-NETCONF_SSH_ERROR: R0/0: ncsshd_bp: NETCONF/SSH: error: Trustpoint does not have a cert
*Jun 5 14:47:22.401: %SYS-5-LOG_CONFIG_CHANGE: Buffer logging: level debugging, xml disabled, filtering disabled, size (262144)
*Jun 5 14:47:22.669: SDWAN INFO: PNP start, status: success
*Jun 5 14:47:22.581: %DMI-5-CONFIG_I: R0/0: nesd: Configured from NETCONF/RESTCONF by nesd, transaction-id -1
*Jun 5 14:47:22.664: %DMI-5-ACTIVE: R0/0: nesd: process is in steady state.
User Access Verification
Username:
% Username: timeout expired!
Username: neteng
Password:
% Login invalid
Username:
Router con0 is now available
Press RETURN to get started.
Username:
Username:
Last reset cause: PowerOn
Failed to find bootable image on device bootflash:
autoboot: boot failed, restarting...
Resetting .......
rommon 1 > ?
alias set and display aliases command
boot boot up an external process
confreg configuration register utility
dev list the device table
dir list files in file system
help monitor builtin command help
history monitor command history
meminfo main memory information
repeat repeat a monitor command
reset system reset
set display the monitor variables
showmon display currently selected ROM monitor
sync write monitor environment to NVRAM
token display board's unique token identifier
unalias unset an alias
unset unset a monitor variable
rommon 2 > confreg 0x2142
rommon 3 > reset
Resetting .......
IsoSize = 421446537
Image validated
Cisco Systems, Inc.
Software feature.
*Jun 5 15:08:00.860: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Jun 5 15:08:00.931: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = esg Next reboot level = ipbasek9 and License = No valid license found
*Jun 5 15:08:01.216: %ISR_THROUGHPUT-6-LEVEL: Throughput level has been set to 100000 kbps
*Jun 5 15:08:02.200: %IOSXE_RP_NV-3-NV_ACCESS_FAIL: Initial read of NVRAM contents failed
*Jun 5 15:08:03.131: %IOSXE_RP_NV-3-BACKUP_NV_ACCESS_FAIL: Initial read of backup NVRAM contents failed
*Jun 5 15:08:04.050: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Jun 5 15:08:04.074: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Jun 5 15:08:10.602: %GENERIC_SUBBLOCK-2-LATE_REGISTER: Late registration of GSB type pbr_color_sb, with id -9223277165542067496
*Jun 5 15:08:15.282: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Jun 5 15:08:15.790: in NSH init
*Jun 5 15:08:15.851: %VOICE_HA-7-STATUS: CUBE HA-supported platform detected.
*Jun 5 15:08:16.947: %LINK-3-UPDOWN: Interface Lsmpi0, changed state to up
*Jun 5 15:08:16.964: %LINK-3-UPDOWN: Interface EOBC0, changed state to up
*Jun 5 15:08:16.965: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0, changed state to up
*Jun 5 15:08:16.979: %LINEPROTO-5-UPDOWN: Line protocol on Interface LI-Null0, changed state to up
*Jun 5 15:08:16.980: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to down
*Jun 5 15:08:17.508: %LINK-3-UPDOWN: Interface LIIN0, changed state to up
*Jun 5 15:08:17.990: %LINEPROTO-5-UPDOWN: Line protocol on Interface Lsmpi0, changed state to up
*Jun 5 15:08:17.990: %LINEPROTO-5-UPDOWN: Line protocol on Interface EOBC0, changed state to up
*Jun 5 15:08:17.991: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Jun 5 15:08:19.059: %IOSXE_MGMTVRF-6-CREATE_SUCCESS_INFO: Management vrf Mgmt-intf created with ID 1, ipv4 table-id 0x1, ipv6 table- id 0x1E000001
*Jun 5 15:08:19.116: %LINEPROTO-5-UPDOWN: Line protocol on Interface LIIN0, changed state to up
*Jun 5 15:05:07.085: %IOSXE-3-PLATFORM: R0/0: kernel: dmi: Firmware registration failed.
*Jun 5 15:05:51.551: %IOSXE-3-PLATFORM: R0/0: kernel: dash_c2w_op_done: I2C Master time out: status register - 0x0
*Jun 5 15:05:51.551: %IOSXE-3-PLATFORM: R0/0: kernel: dash_i2c_xfer: I2C Master Error master=10 addr=0x50 status=0x0
*Jun 5 15:05:51.609: %IOSXE-3-PLATFORM: R0/0: kernel: dash_c2w_op_done: I2C Master time out: status register - 0x0
*Jun 5 15:05:51.609: %IOSXE-3-PLATFORM: R0/0: kernel: dash_i2c_xfer: I2C Master Error master=11 addr=0x50 status=0x0
*Jun 5 15:05:51.667: %IOSXE-3-PLATFORM: R0/0: kernel: dash_c2w_op_done: I2C Master time out: status register - 0x0
*Jun 5 15:05:51.667: %IOSXE-3-PLATFORM: R0/0: kernel: dash_i2c_xfer: I2C Master Error master=12 addr=0x50 status=0x0
*Jun 5 15:05:51.725: %IOSXE-3-PLATFORM: R0/0: kernel: dash_c2w_op_done: I2C Master time out: status register - 0x0
*Jun 5 15:05:51.725: %IOSXE-3-PLATFORM: R0/0: kernel: dash_i2c_xfer: I2C Master Error master=13 addr=0x50 status=0x0
*Jun 5 15:05:51.782: %IOSXE-3-PLATFORM: R0/0: kernel: dash_c2w_op_done: I2C Master time out: status register - 0x0
*Jun 5 15:05:51.782: %IOSXE-3-PLATFORM: R0/0: kernel: dash_i2c_xfer: I2C Master Error master=14 addr=0x50 status=0x0
*Jun 5 15:08:04.915: %CMLIB-3-THROUGHPUT_VALUE_SETUP_FAILED: R0/0: cmand: Throughput license found, throughput set to 14700000 kbps. Error: Invalid argument
*Jun 5 15:08:22.319: %SYS-6-STARTUP_CONFIG_IGNORED: System startup configuration is ignored based on the configuration register setti ng.
*Jun 5 15:08:22.333: %IOSXE_OIR-6-REMSPA: SPA removed from subslot 0/0, interfaces disabled
*Jun 5 15:08:22.348: %SPA_OIR-6-OFFLINECARD: SPA (ISR4331-3x1GE) offline in subslot 0/0
*Jun 5 15:08:22.353: %IOSXE_OIR-6-INSCARD: Card (fp) inserted in slot F0
*Jun 5 15:08:22.353: %IOSXE_OIR-6-ONLINECARD: Card (fp) online in slot F0
*Jun 5 15:08:22.389: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 0
*Jun 5 15:08:22.389: %IOSXE_OIR-6-ONLINECARD: Card (cc) online in slot 0
*Jun 5 15:08:22.393: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 1
*Jun 5 15:08:22.393: %IOSXE_OIR-6-ONLINECARD: Card (cc) online in slot 1
*Jun 5 15:08:22.457: %IOSXE_OIR-6-INSSPA: SPA inserted in subslot 0/0
*Jun 5 15:08:22.642: SDWAN INFO: Interface = GigabitEthernet0 mgmt
*Jun 5 15:08:22.642: SDWAN INFO: SDWAN system init done
*Jun 5 15:08:22.755: yang-infra: Auto enable netconf-yang
*Jun 5 15:08:22.799: %ONEP_BASE-6-SS_ENABLED: ONEP: Service set Base was enabled by Default
*Jun 5 15:08:23.301: yang-infra: netconf-yang server has been notified to start
*Jun 5 15:08:24.861: %Cisco-SDWAN-Router-SYSMGR-5-NTCE-200050: R0/0: SYSMGR: System status blinking green (reason: Coming up)
*Jun 5 15:08:24.869: %Cisco-SDWAN-Router-SYSMGR-5-NTCE-200042: R0/0: SYSMGR: Created shared memory vconfd_shared_region
*Jun 5 15:08:26.319: %SYS-5-RESTART: System restarted --
*Jun 5 15:08:25.427: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon confd @ pid 372 in vpn 65534
CRYPTO_PKI: setting trustpoint policy for TP-self-signed-2482764321 to specify TP-self-signed-2482764321 keypair usage% Generating 204 8 bit RSA keys, keys will be non-exportable...
*Jun 5 15:08:35.883: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Jun 5 15:08:35.883: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
*Jun 5 15:08:36.707: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named CISCO_IDEVID_SUDI has been generated or imported
*Jun 5 15:08:36.796: %PKI-2-NON_AUTHORITATIVE_CLOCK: PKI timers have not been initialized due to non-authoritative system clock. Ensu re system clock is configured/updated.
*Jun 5 15:08:39.756: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named TP-self-signed-2482764321 has been generated or imported
*Jun 5 15:08:39.758: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Jun 5 15:08:39.844: yang-infra: ERROR: Failed to create a new self-signed trustpoint
*Jun 5 15:08:40.001: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named TP-self-signed-2482764321.server has been generated or imported
*Jun 5 15:08:56.297: %ONEP_BASE-6-SS_ENABLED: ONEP: Service set Vty was enabled by Platform
*Jun 5 15:08:56.501: %ONEP_BASE-6-CONNECT: [Element]: ONEP session Application:com.cisco.syncfd Host:Router ID:2026 User:a has connec ted.
*Jun 5 15:08:57.254: AUTH-FEAT-BC-EVENT: [Gi0/0/0] Nothing to convert
*Jun 5 15:08:56.548: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon cfgmgr @ pid 7206 in vpn 0
*Jun 5 15:08:56.550: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon fpmd @ pid 7207 in vpn 0
*Jun 5 15:08:56.552: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon ftmd @ pid 7208 in vpn 0
*Jun 5 15:08:56.554: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon ompd @ pid 7210 in vpn 0
*Jun 5 15:08:56.556: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon ttmd @ pid 7211 in vpn 0
*Jun 5 15:08:56.558: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon vdaemon @ pid 7213 in vpn 0
*Jun 5 15:08:57.183: %Cisco-SDWAN-Router-TTMD-6-INFO-1200001: R0/0: TTMD: Starting
*Jun 5 15:08:57.211: %Cisco-SDWAN-Router-CFGMGR-6-INFO-300001: R0/0: CFGMGR: Starting
*Jun 5 15:08:57.288: %Cisco-SDWAN-Router-FPMD-6-INFO-1100001: R0/0: FPMD: Starting
*Jun 5 15:08:57.440: %Cisco-SDWAN-Router-OMPD-5-NTCE-400001: R0/0: OMPD: Starting
*Jun 5 15:08:57.709: %Cisco-SDWAN-Router-FTMD-6-INFO-1000020: R0/0: FTMD: SLA class '__all_tunnels__' added at index '0': loss = 128% , latency = 2147483647 ms
*Jun 5 15:08:58.078: AUTH-FEAT-BC-EVENT: [Gi0/0/1] Nothing to convert
*Jun 5 15:08:58.342: AUTH-FEAT-BC-EVENT: [Gi0/0/2] Nothing to convert
*Jun 5 15:08:58.415: %SPA_OIR-6-ONLINECARD: SPA (ISR4331-3x1GE) online in subslot 0/0
*Jun 5 15:08:58.341: %Cisco-SDWAN-Router-FTMD-4-WARN-1000007: R0/0: FTMD: Connection to TTM came up. p_msgq 0x7f8fdae35500 p_ftm 0x92 96f0
*Jun 5 15:08:59.304: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to down
*Jun 5 15:08:59.489: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Jun 5 15:08:59.492: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
*Jun 5 15:08:59.751: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/1, changed state to down
*Jun 5 15:09:00.448: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/2, changed state to down
*Jun 5 15:09:01.579: SDWAN INFO: application database sync to FPM: record-count 1426 error 76
*Jun 5 15:09:06.010: %ONEP_BASE-6-CONNECT: [Element]: ONEP session Application:com.cisco.nesd Host:Router ID:5544 User:NETCONF has co nnected.
*Jun 5 15:09:22.417: %NDBMAN-5-ACTIVE: R0/0: ndbmand: All data providers active.
*Jun 5 15:09:23.108: %DMI-5-ACTIVE: R0/0: dmiauthd: process is in steady state.
*Jun 5 15:09:28.993: %DMI-3-CDB_START_FAIL: R0/0: syncfd: Could not start session to read configuration from the DMI data store locke d (10): Could not acquire lock.
*Jun 5 15:09:29.188: %DMI-5-INITIALIZED: R0/0: syncfd: process has initialized.
*Jun 5 15:09:34.396: %MODULE_STATE-6-ALL_MODULES_UP: All modules are now on-line.
*Jun 5 15:09:39.265: %DMI-3-NETCONF_SSH_ERROR: R0/0: ncsshd_bp: NETCONF/SSH: error: Trustpoint does not have a cert
*Jun 5 15:09:45.391: %SYS-5-LOG_CONFIG_CHANGE: Buffer logging: level debugging, xml disabled, filtering disabled, size (262144)
*Jun 5 15:09:45.512: SDWAN INFO: PNP start, status: success
*Jun 5 15:09:45.490: %DMI-5-CONFIG_I: R0/0: nesd: Configured from NETCONF/RESTCONF by nesd, transaction-id -1
*Jun 5 15:09:45.505: %DMI-5-ACTIVE: R0/0: nesd: process is in steady state.
Username: Cisco
Password:
% Login invalid
Username: neteng
Password:
% Login invalid
Username: Cisco
Password:
% Login invalid
Username: cisco
Password:
% Login invalid
Username: cisco
Password:
% Login invalid
Username: Cisco
Password:
% Login invalid
Username: NETCONG
Password:
% Login invalid
Username:
Resetting .......
rommon 1 > ?
reset system reset
rommon 2 > confreg 0x2102
You must reset or power cycle for new config to take effect
rommon 3 > confreg 0x2142
rommon 4 > unset
usage: unset [name=value]
rommon 5 > boot ?
unable to open ? (14)
rommon 6 > boot
IsoSize = 421446537
Image validated
Cisco Systems, Inc.
Software feature.
*Jun 5 15:29:12.582: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Jun 5 15:29:12.652: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = esg Next reboot level = ipbasek9 and License = No valid license found
*Jun 5 15:29:12.713: %ISR_THROUGHPUT-6-LEVEL: Throughput level has been set to 100000 kbps
*Jun 5 15:29:13.698: %IOSXE_RP_NV-3-NV_ACCESS_FAIL: Initial read of NVRAM contents failed
*Jun 5 15:29:14.629: %IOSXE_RP_NV-3-BACKUP_NV_ACCESS_FAIL: Initial read of backup NVRAM contents failed
*Jun 5 15:29:15.545: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Jun 5 15:29:15.571: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Jun 5 15:29:22.080: %GENERIC_SUBBLOCK-2-LATE_REGISTER: Late registration of GSB type pbr_color_sb, with id -9223277978913439016
*Jun 5 15:29:26.762: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Jun 5 15:29:27.284: in NSH init
*Jun 5 15:29:27.346: %VOICE_HA-7-STATUS: CUBE HA-supported platform detected.
*Jun 5 15:29:28.444: %LINK-3-UPDOWN: Interface Lsmpi0, changed state to up
*Jun 5 15:29:28.461: %LINK-3-UPDOWN: Interface EOBC0, changed state to up
*Jun 5 15:29:28.462: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0, changed state to up
*Jun 5 15:29:28.476: %LINEPROTO-5-UPDOWN: Line protocol on Interface LI-Null0, changed state to up
*Jun 5 15:29:28.477: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to down
*Jun 5 15:29:29.010: %LINK-3-UPDOWN: Interface LIIN0, changed state to up
*Jun 5 15:29:29.520: %LINEPROTO-5-UPDOWN: Line protocol on Interface Lsmpi0, changed state to up
*Jun 5 15:29:29.521: %LINEPROTO-5-UPDOWN: Line protocol on Interface EOBC0, changed state to up
*Jun 5 15:29:29.521: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Jun 5 15:29:30.688: %IOSXE_MGMTVRF-6-CREATE_SUCCESS_INFO: Management vrf Mgmt-intf created with ID 1, ipv4 table-id 0x1, ipv6 table-id 0x1E000001
*Jun 5 15:29:30.746: %LINEPROTO-5-UPDOWN: Line protocol on Interface LIIN0, changed state to up
*Jun 5 15:26:19.075: %IOSXE-3-PLATFORM: R0/0: kernel: dmi: Firmware registration failed.
*Jun 5 15:27:03.760: %IOSXE-3-PLATFORM: R0/0: kernel: dash_c2w_op_done: I2C Master time out: status register - 0x0
*Jun 5 15:27:03.760: %IOSXE-3-PLATFORM: R0/0: kernel: dash_i2c_xfer: I2C Master Error master=10 addr=0x50 status=0x0
*Jun 5 15:27:03.817: %IOSXE-3-PLATFORM: R0/0: kernel: dash_c2w_op_done: I2C Master time out: status register - 0x0
*Jun 5 15:27:03.817: %IOSXE-3-PLATFORM: R0/0: kernel: dash_i2c_xfer: I2C Master Error master=11 addr=0x50 status=0x0
*Jun 5 15:27:03.875: %IOSXE-3-PLATFORM: R0/0: kernel: dash_c2w_op_done: I2C Master time out: status register - 0x0
*Jun 5 15:27:03.875: %IOSXE-3-PLATFORM: R0/0: kernel: dash_i2c_xfer: I2C Master Error master=12 addr=0x50 status=0x0
*Jun 5 15:27:03.933: %IOSXE-3-PLATFORM: R0/0: kernel: dash_c2w_op_done: I2C Master time out: status register - 0x0
*Jun 5 15:27:03.933: %IOSXE-3-PLATFORM: R0/0: kernel: dash_i2c_xfer: I2C Master Error master=13 addr=0x50 status=0x0
*Jun 5 15:27:03.991: %IOSXE-3-PLATFORM: R0/0: kernel: dash_c2w_op_done: I2C Master time out: status register - 0x0
*Jun 5 15:27:03.991: %IOSXE-3-PLATFORM: R0/0: kernel: dash_i2c_xfer: I2C Master Error master=14 addr=0x50 status=0x0
*Jun 5 15:29:16.536: %CMLIB-3-THROUGHPUT_VALUE_SETUP_FAILED: R0/0: cmand: Throughput license found, throughput set to 14700000 kbps. Error: Invalid argument
*Jun 5 15:29:33.683: %SYS-6-STARTUP_CONFIG_IGNORED: System startup configuration is ignored based on the configuration register setting.
*Jun 5 15:29:33.699: %IOSXE_OIR-6-REMSPA: SPA removed from subslot 0/0, interfaces disabled
*Jun 5 15:29:33.714: %SPA_OIR-6-OFFLINECARD: SPA (ISR4331-3x1GE) offline in subslot 0/0
*Jun 5 15:29:33.719: %IOSXE_OIR-6-INSCARD: Card (fp) inserted in slot F0
*Jun 5 15:29:33.719: %IOSXE_OIR-6-ONLINECARD: Card (fp) online in slot F0
*Jun 5 15:29:33.756: %IOSXE_OIR-6-INSCARD: Card (cc) inser
Router>
Router>
Router>
Router>
Router>ted in slot 0
*Jun 5 15:29:33.756: %IOSXE_OIR-6-ONLINECARD: Card (cc) online in slot 0
*Jun 5 15:29:33.759: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 1
*Jun 5 15:29:33.759: %IOSXE_OIR-6-ONLINECARD: Card (cc) online in slot 1
*Jun 5 15:29:33.827: %IOSXE_OIR-6-INSSPA: SPA inserted in subslot 0/0
*Jun 5 15:29:34.024: SDWAN INFO: Interface = GigabitEthernet0 mgmt
*Jun 5 15:29:34.024: SDWAN INFO: SDWAN system init done
*Jun 5 15:29:34.119: yang-infra: Auto enable netconf-yang
*Jun 5 15:29:34.154: %ONEP_BASE-6-SS_ENABLED: ONEP: Service set Base was enabled by Default
*Jun 5 15:29:34.677: yang-infra: netconf-yang server has been notified to start
*Jun 5 15:29:35.922: %Cisco-SDWAN-Router-SYSMGR-5-NTCE-200050: R0/0: SYSMGR: System status blinking green (reason: Coming up)
*Jun 5 15:29:35.929: %Cisco-SDWAN-Router-SYSMGR-5-NTCE-200042: R0/0: SYSMGR: Created shared memory vconfd_shared_region
*Jun 5 15:29:35.966: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon confd @ pid 32524 in vpn 65534
*Jun 5 15:29:39.100: %SYS-5-RESTART: System restarted --
Router>
Router>
*Jun 5 15:29:47.443: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Jun 5 15:29:47.443: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
*Jun 5 15:29:48.400: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named CISCO_IDEVID_SUDI has been generated or imported
*Jun 5 15:29:48.450: %PKI-2-NON_AUTHORITATIVE_CLOCK: PKI timers have not been initialized due to non-authoritative system clock. Ensure system clock is configured/updated.
Router>
Router>
[OK] (elapsed time was 8 seconds)
*Jun 5 15:29:56.289: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named TP-self-signed-2482764321 has been generated or imported
*Jun 5 15:29:56.290: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Jun 5 15:29:56.390: yang-infra: ERROR: Failed to create a new self-signed trustpointen
*Jun 5 15:29:56.592: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named TP-self-signed-2482764321.server has been generated or imported
Router#?
Exec commands:
access-profile Apply user-profile to interface
alps ALPS exec commands
app-hosting Application hosting
appnav IOS Wide Area Application Services
archive manage archive files
attach Connect to a module's console
audio-prompt load ivr prompt
authentication Authentication options for eEdge
auto Exec level Automation
beep Blocks Extensible Exchange Protocol commands
bfe For manual emergency modes setting
bulkstat Bulkstat exec commands
call Voice call
call-home Call-Home commands
ccm-manager Call Manager Application exec commands
cd Change current directory
clear Reset functions
clock Manage the system clock
cns CNS agents
config-transaction config transaction
configure Enter configuration mode
connect Open a terminal connection
copy Copy from one file to another
credential load the credential info from file system
crypto Encryption related commands.
cts Cisco Trusted Security Exec Commands
debug Debugging functions (see also 'undebug')
delete Delete a file
diagnostic Diagnostic commands
dir List files on a filesystem
disable Turn off privileged commands
disconnect Disconnect an existing network connection
do-exec Mode-independent "do-exec" prefix support
dot1x IEEE 802.1X Exec Commands
eap EAP Exec Commands
emadmin Extension Mobility Commands
enable Turn on privileged commands
erase Erase a filesystem
ethernet Ethernet parameters
event Event related commands
exit Exit from the EXEC
factory-reset Factory Reset command
file-acct File mode accounting exec command
flush File mode accounting flush options
format Format a filesystem
--More--
*Jun 5 15:30:07.006: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon cfgmgr @ pid 5941 in vpn 0
*Jun 5 15:30:07.008: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon fpmd @ pid 5943 in vpn 0
*Jun 5 15:30:07.011: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon ftmd @ pid 5944 in vpn 0
*Jun 5 15:30:07.013: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon ompd @ pid 5946 in vpn 0
*Jun 5 15:30:07.015: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon ttmd @ pid 594 fsck Filesystem check
--More--
*Jun 5 15:30:07.018: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon vdaemon @ pid 5948 in vpn 0
*Jun 5 15:30:07.536: %Cisco-SDWAN-Router-TTMD-6-INFO-1200001: R0/0: TTMD: Starting
*Jun 5 15:30:07.602: %Cisco-SDWAN-Router-CFGMGR-6-INFO-300001: R0/0: CFGMGR: Starting
*Jun 5 15:30:07.679: %Cisco-SDWAN-Router-FPMD-6-INFO-1100001: R0/0: FPMD: Starting
*Jun 5 15:30:07.757: %Cisco-SDWAN-Router-OMPD-5-NTCE-400001: R0/0: OMPD: Starting
*Jun 5 15:30:08.204: %Cisco-SDWAN-Router-FTMD-6-INFO-1000020: R0/0: FTMD: SLA class '__all_tunnels__' added at index '0': loss = 128%, latency = 2147483647 ms
*Jun 5 15:30:09.242: AUTH-FEAT-BC-EVENT: [Gi0/0/0] Nothing to convert
*Jun 5 15:30:08.939: %Cisco-SDWAN-Router-FTMD-4-WARN-1000007: R0/0: FTMD: Connection to TTM came up. p_msgq 0x7f2315c35500 p_ftm 0x9296f0
*Jun 5 15:30:09.872: AUTH-FEAT-BC-EVENT: [Gi0/0/1] Nothing to convert
*Jun 5 15:30:10.081: AUTH-FEAT-BC-EVENT: [Gi0/0/2] Nothing help Description of the interactive help system
hunt-group hunt group exec command
--More--
*Jun 5 15:30:10.099: %SPA_OIR-6-ONLINECARD: SPA (ISR4331-3x1GE) online in subslot 0/0
*Jun 5 15:30:10.170: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Jun 5 15:30:10.171: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
*Jun 5 15:30:11.229: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to down
*Jun 5 15:30:11.991: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/1, changed state to down
*Jun 5 15:30:12.120: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/2, changed sta hw-module Apply command to specific hardware component
if-mgr IF-MGR operations
--More--
*Jun 5 15:30:12.311: SDWAN INFO: application database sync to FPM: record-count 142 install Install command
ip IP SLA Exec Command
isdn Run an ISDN EXEC command on an ISDN interface
issu issu commands
l2vpn Layer2 VPN commands
lat Open a lat connection
license License information
lig LISP Internet Groper
lock Lock the terminal
logging Handles logging operations
login Log in as a particular user
logout Exit from the EXEC
maintenance Maintenance mode
microcode microcode commands
mkdir Create new directory
mlacp mLACP EXEC commands
monitor Monitoring different system events
more Display the contents of a file
mpls MPLS commands
mrinfo Request neighbor and version information from a multicast
router
mrm IP Multicast Routing Monitor Test
mstat Show statistics after multiple multicast traceroutes
mtrace Trace reverse multicast path from destination to source
name-connection Name an existing network connection
ncia Start/Stop NCIA Server
network-clock Network clock
no Disable debugging functions
pad Open a X.29 PAD connection
partition Partition disk
ping Send echo messages
pnpa PnP agent
ppp Start IETF Point-to-Point Protocol (PPP)
pwd Display current working directory
redundancy Redundancy Facility (RF) exec commands
release Release a resource
reload Halt and perform a cold restart
rename Rename a file
renew Renew a resource
request Request an action
restart Restart Connection/Interface
resume Resume an active network connection
rlogin Open an rlogin connection
rmdir Remove existing directory
routing-context Routing Context
rsh Execute a remote command
sbc Session Border Controller
sdlc Send SDLC test frames
send Send a message to other tty lines
service IOS integrated service enablement
set Set system parameter (not config)
setup Run the SETUP command facility
sga-internal Cisco Trusted Security Exec Commands
show Show running system information
slip Start Serial-line IP (SLIP)
snmp snmp commands
spec-file format spec file commands
ssh Open a secure shell client connection
start-chat Start a chat-script on a line
systat Display information about terminal lines
tarp TARP (Target ID Resolution Protocol) commands
tclquit Quit Tool Command Language shell
tclsh Tool Command Language shell
telnet Open a telnet connection
terminal Set terminal line parameters
test Test subsystems, memory, and interfaces
tn3270 Open a tn3270 connection
traceroute Trace route to destination
ucse UCSE server
--More--
*Jun 5 15:30:16.635: %ONEP_BASE-6-SS_ENABLED: ONEP: Service set Vty was enabled by Platform
*Jun 5 15:30:16.844: %ONEP_BASE-6-CONNECT: [Element]: ONEP session Application:com.cisco.syncfd Host:Router ID:8411 User:a has who who
terminal
x28 Become an X.28 PAD
x3 Set X.3 parameters on PAD
Router#
Router#
Router#
*Jun 5 15:30:22.265: %ONEP_BASE-6-CONNECT: [Element]: ONEP session Application:com.cisco.nesd Host:Router ID:6533 User:NETCONF has connected.conf t
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#
Router(config)#
Router(config)#
Router(config)#
Router(config)#
*Jun 5 15:30:36.073: %NDBMAN-5-ACTIVE: R0/0: ndbmand: All data providers active.
*Jun 5 15:30:36.125: %DMI-5-ACTIVE: R0/0: dmiauthd: process is in steady state.
*Jun 5 15:30:46.103: %MODULE_STATE-6-ALL_MODULES_UP: All modules are now on-line.
*Jun 5 15:30:41.975: %DMI-5-INITIALIZED: R0/0: syncfd: process has initialized.
*Jun 5 15:30:52.550: %DMI-3-NETCONF_SSH_ERROR: R0/0: ncsshd_bp: NETCONF/SSH: error: Trustpoint does not have a cert
*Jun 5 15:30:54.658: %SYS-5-LOG_CONFIG_CHANGE: Buffer logging: level debugging, xml disabled, filtering disabled, size (262144)
*Jun 5 15:30:54.943: SDWAN INFO: PNP start, status: success
*Jun 5 15:30:54.866: %DMI-5-CONFIG_I: R0/0: nesd: Configured from NETCONF/RESTCONF by nesd, transaction-id -1
Router(config)#
Router(config)#
Router(config)#
Router(config)#
Router(config)#
Router(config)#
*Jun 5 15:30:54.943: %DMI-5-ACTIVE: R0/0: nesd: process is in steady state.
Router(config)#hostname r-a.s04811.in
r-a.s04811.in(config)#username neteng secret cisco@123
r-a.s04811.in(config)#enable secre
r-a.s04811.in(config)#enable secret cisco@123
r-a.s04811.in(config)#do wr
This command is not supported
r-a.s04811.in#
r-a.s04811.in(config)#^Z
r-a.s04811.in#
r-a.s04811.in#
r-a.s04811.in#
r-a.s04811.in#
r-a.s04811.in#
r-a.s04811.in#
*Jun 5 15:32:12.354: %SYS-5-CONFIG_I: Configured from console by consolewr
r-a.s04811.in#
r-a.s04811.in#wr
r-a.s04811.in#
r-a.s04811.in#conf t
r-a.s04811.in#
r-a.s04811.in#
r-a.s04811.in#
r-a.s04811.in#
r-a.s04811.in#
r-a.s04811.in#
r-a.s04811.in#
r-a.s04811.in#
r-a.s04811.in#
r-a.s04811.in#
r-a.s04811.in#
r-a.s04811.in#?
Exec commands:
call Voice call
cns CNS agents
issu issu commands
mpls MPLS commands
router
pnpa PnP agent
snmp snmp commands
ucse UCSE server
who who
terminal
r-a.s04811.in#conf
r-a.s04811.in#configur
r-a.s04811.in#configure ter
r-a.s04811.in#configure terminal
r-a.s04811.in#
r-a.s04811.in#
r-a.s04811.in#
r-a.s04811.in#
r-a.s04811.in#?
Exec commands:
call Voice call
cns CNS agents
issu issu commands
mpls MPLS commands
router
pnpa PnP agent
snmp snmp commands
ucse UCSE server
who who
terminal
r-a.s04811.in#$
r-a.s04811.in#
r-a.s04811.in#
r-a.s04811.in#
r-a.s04811.in#
r-a.s04811.in#
r-a.s04811.in#fa
r-a.s04811.in#factory-reset ?
all All factory reset operations
r-a.s04811.in#factory-reset all
The factory reset operation is irreversible for all operations. Are you sure? [confirm]
This operation may take 20 minutes or more. Please do not power cycle.
*Jun 5 15:35:57.224: %SYS-5-RELOAD: Reload requested by Exec. Reload Reason: Factory Reset.Jun 5 15:36:26.961: %PMAN
Both copies of Nvram are corrupted.
Warning: monitor Nvram area is corrupt ... using default values
Confreg is corrupted, using default 8000
Key Sectors:(Primary, GOOD),(Backup,GOOD),(Revocation,GOOD)
Size of Primary = 2288 Backup = 2288 Revocation = 288
RSA Self Test Passed
Expected hash:
DDAF35A193617ABACC417349AE204131
12E6FA4E89A97EA20A9EEEE64B55D39A
2192992A274FC1A836BA3C23A3FEEBBD
454D4423643CE80E2A9AC94FA54CA49F
Obtained hash:
Sha512 Self Test Passed
rommon 1 > ?
reset system reset
rommon 3 > reset
Resetting .......
IsoSize = 421446537
Image validated
Cisco Systems, Inc.
Software feature.
*Jun 5 15:47:56.881: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Jun 5 15:47:56.978: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = esg Next reboot level = ipbasek9 and License = No valid license found
*Jun 5 15:47:57.263: %ISR_THROUGHPUT-6-LEVEL: Throughput level has been set to 100000 kbps
*Jun 5 15:47:58.247: %IOSXE_RP_NV-3-NV_ACCESS_FAIL: Initial read of NVRAM contents failed
*Jun 5 15:47:59.178: %IOSXE_RP_NV-3-BACKUP_NV_ACCESS_FAIL: Initial read of backup NVRAM contents failed
*Jun 5 15:48:00.320: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Jun 5 15:48:00.342: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Jun 5 15:48:06.749: %GENERIC_SUBBLOCK-2-LATE_REGISTER: Late registration of GSB type pbr_color_sb, with id -9223278127895043368
*Jun 5 15:48:11.453: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Jun 5 15:48:11.971: in NSH init
*Jun 5 15:48:12.033: %VOICE_HA-7-STATUS: CUBE HA-supported platform detected.
*Jun 5 15:48:13.361: %LINK-3-UPDOWN: Interface Lsmpi0, changed state to up
*Jun 5 15:48:13.378: %LINK-3-UPDOWN: Interface EOBC0, changed state to up
*Jun 5 15:48:13.379: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0, changed state to up
*Jun 5 15:48:13.396: %LINEPROTO-5-UPDOWN: Line protocol on Interface LI-Null0, changed state to up
*Jun 5 15:48:13.396: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to down
*Jun 5 15:48:13.915: %LINK-3-UPDOWN: Interface LIIN0, changed state to up
*Jun 5 15:48:14.395: %LINEPROTO-5-UPDOWN: Line protocol on Interface Lsmpi0, changed state to up
*Jun 5 15:48:14.395: %LINEPROTO-5-UPDOWN: Line protocol on Interface EOBC0, changed state to up
*Jun 5 15:48:14.396: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Jun 5 15:48:15.456: %IOSXE_MGMTVRF-6-CREATE_SUCCESS_INFO: Management vrf Mgmt-intf created with ID 1, ipv4 table-id 0x1, ipv6 table-id 0x1E000001
*Jun 5 15:48:15.516: %LINEPROTO-5-UPDOWN: Line protocol on Interface LIIN0, changed state to up
*Jun 5 15:45:05.079: %IOSXE-3-PLATFORM: R0/0: kernel: dmi: Firmware registration failed.
*Jun 5 15:45:55.130: %IOSXE-3-PLATFORM: R0/0: kernel: EXT2-fs (sda7): error: can't find an ext2 filesystem on dev sda7.
*Jun 5 15:45:55.348: %IOSXE-3-PLATFORM: R0/0: kernel: EXT2-fs (sda8): error: can't find an ext2 filesystem on dev sda8.
*Jun 5 15:45:55.578: %IOSXE-3-PLATFORM: R0/0: kernel: EXT2-fs (sda9): error: can't find an ext2 filesystem on dev sda9.
*Jun 5 15:45:55.855: %IOSXE-3-PLATFORM: R0/0: kernel: EXT2-fs (sda10): error: can't find an ext2 filesystem on dev sda10.
*Jun 5 15:45:56.097: %IOSXE-3-PLATFORM: R0/0: kernel: EXT2-fs (sda6): error: can't find an ext2 filesystem on dev sda6.
*Jun 5 15:48:00.795: %CMLIB-3-THROUGHPUT_VALUE_SETUP_FAILED: R0/0: cmand: Throughput license found, throughput set to 14700000 kbps. Error: Invalid argument
*Jun 5 15:48:18.729: %SYS-6-STARTUP_CONFIG_IGNORED: System startup configuration is ignored based on the configuration register setting.
*Jun 5 15:48:18.744: %IOSXE_OIR-6-REMSPA: SPA removed from subslot 0/0, interfaces disabled
*Jun 5 15:48:18.745: %SPA_OIR-6-OFFLINECARD: SPA (ISR4331-3x1GE) offline in subslot 0/0
*Jun 5 15:48:18.749: %IOSXE_OIR-6-INSCARD: Card (fp) inserted in slot F0
*Jun 5 15:48:18.749: %IOSXE_OIR-6-ONLINECARD: Card (fp) online in slot F0
*Jun 5 15:48:18.784: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 0
*Jun 5 15:48:18.785: %IOSXE_OIR-6-ONLINECARD: Card (cc) online in slot 0
*Jun 5 15:48:18.789: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 1
*Jun 5 15:48:18.789: %IOSXE_OIR-6-ONLINECARD: Card (cc) online in slot 1
*Jun 5 15:48:18.849: %IOSXE_OIR-6-INSSPA: SPA inserted in subslot 0/0
*Jun 5 15:48:19.029: SDWAN INFO: Interface = GigabitEthernet0 mgmt
*Jun 5 15:48:19.029: SDWAN INFO: SDWAN system init done
*Jun 5 15:48:19.139: yang-infra: Auto enable netconf-yang
*Jun 5 15:48:19.230: %ONEP_BASE-6-SS_ENABLED: ONEP: Service set Base
Router>
Router>
Router>was enabled by Default
*Jun 5 15:48:19.732: yang-infra: netconf-yang server has been notified to start
*Jun 5 15:48:22.063: %SYS-5-RESTART: System restarted --
*Jun 5 15:48:31.419: %Cisco-SDWAN-Router-SYSMGR-5-NTCE-200050: R0/0: SYSMGR: System status blinking green (reason: Coming up)
*Jun 5 15:48:31.427: %Cisco-SDWAN-Router-SYSMGR-5-NTCE-200042: R0/0: SYSMGR: Created shared memory vconfd_shared_region
*Jun 5 15:48:31.428: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon confd @ pid 3533 in vpn 65534
*Jun 5 15:48:32.051: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Jun 5 15:48:32.051: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
*Jun 5 15:48:33.046: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named CISCO_IDEVID_SUDI has been generated or imported
*Jun 5 15:48:33.095: %PKI-2-NON_AUTHORITATIVE_CLOCK: PKI timers have not been initialized due to non-authoritative system clock. Ensure system clock is configured/updated.
[OK] (elapsed time was 2 seconds)
*Jun 5 15:48:35.031: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named TP-self-signed-2482764321 has been generated or imported
*Jun 5 15:48:35.033: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Jun 5 15:48:35.153: yang-infra: ERROR: Failed to create a new self-signed trustpoint
*Jun 5 15:48:35.325: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named TP-self-signed-2482764321.server has been generated or imported
Router>en
Router#c
*Jun 5 15:48:46.639: %ONEP_BASE-6-SS_ENABLED: ONEP: Service set Vty was enabled by Platform
*Jun 5 15:48:47.043: %ONEP_BASE-6-CONNECT: [Element]: ONEP session Application:com.cisco.syncfd Host:Router ID:2268 User:a has connected.onf t
Router(config)#
*Jun 5 15:48:53.501: new extended attributes received from iomd(slot 0 bay 0 board 0)do sh
*Jun 5 15:48:53.778: %SPA_OIR-6-ONLINECARD: SPA (ISR4331-3x1GE) online in subslot 0/0
*Jun 5 15:48:53.780: %IOSXE_OIR-6-SOFT_RELOADSPA: SPA(ISR4331-3x1GE) reloaded on subslot 0/0
*Jun 5 15:48:53.780: %SPA_OIR-6-OFFLINECARD: SPA (ISR4331-3x1GE) offline in subslot 0/0
*Jun 5 15:48:54.903: %ONEP_BASE-6-CONNECT: [Element]: ONEP session Application:com.cisco.nesd Host:Router ID:5752 User:NETCONF has connected.ver
Cisco IOS XE Software, Version 16.9.2
Cisco IOS-XE software, Copyright (c) 2005-2018 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
Router uptime is 1 minute
Uptime for this control processor is 3 minutes
System returned to ROM by reload
System image file is "bootflash:isr4300-ucmk9.16.9.2.SPA.bin"
Last reload reason: Unknown reason
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
--More--
*Jun 5 15:48:59.007: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon cfgmgr @ pid 9552 in vpn 0
*Jun 5 15:48:59.009: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon fpmd @ pid 9553 in vpn 0
*Jun 5 15:48:59.012: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon ftmd @ pid 9555 in vpn 0
*Jun 5 15:48:59.015: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon ompd @ pid 9556 in vpn 0
*Jun 5 15:48:59.017: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon ttmd @ pid 9557 in vpn 0
*Jun 5 15:48:59.020: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon vdaemon @ pid 9558 in vpn 0
*Jun 5 15:48:59.556: %Cisco-SDWAN-Router-TTMD-6-INFO-1200001: R0/0: TTMD: Starting
*Jun 5 15:48:59.747: %Cisco-SDWAN-Router-OMPD-5-NTCE-400001: R0/0: OMPD: Starting
*Jun 5 15:48:59.787: %Cisco-SDWAN-Router-CFGMGR-6-INFO-300001: R0/0: CFGMGR: Starting
*Jun 5 15:48:59.788: %Cisco-SDWAN-Router-FPMD-6-INFO-1100001: R0/0: FPMD: Starting
*Jun 5 15:49:00.341: %Cisco-SDWAN-Router-FTMD-6-INFO-1000020: R0/0: FTMD: SLA class '__all_tunnels__' added at index '0': loss = 128%, latency = 2147483647 ms
*Jun 5 15:49:01.116: %Cisco-SDWAN-Router-FTMD-4-WARN-1000007: R0/0: FTMD: Connection to TTM came up. p_msgq 0x7f6a53835500 p_ftm 0x9296f0
*Jun 5 15:49:02.304: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Jun 5 15:49:02.305: %CRYPTO-6-GDOI_ON_OFF: GSuite License Information for Module:'esg'
Suite Suite Current Type Suite Next reboot
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 None ipbasek9
Configuration register is 0x2142
Router(config)#
*Jun 5 15:49:05.524: SDWAN INFO: application database sync to FPM: record-count 1426 error 76
*Jun 5 15:49:07.491: %SPA_OIR-6-ONLINECARD: SPA (ISR4331-3x1GE) online in subslot 0/0
Router(config)#
Router(config)#
Router(config)#
Router(config)#
Router(config)#
Router(config)#
Router(config)#
Router(config)#
Router(config)#
Router(config)#
Router(config)#
Router(config)#
Router(config)#
*Jun 5 15:49:14.981: %NDBMAN-5-ACTIVE: R0/0: ndbmand: All data providers active.
*Jun 5 15:49:18.583: %DMI-5-ACTIVE: R0/0: dmiauthd: process is in steady state.
*Jun 5 15:49:32.983: %MODULE_STATE-6-ALL_MODULES_UP: All modules are now on-line.
*Jun 5 15:49:28.927: %DMI-5-INITIALIZED: R0/0: syncfd: process has initialized.
*Jun 5 15:49:36.518: %DMI-3-NETCONF_SSH_ERROR: R0/0: ncsshd_bp: NETCONF/SSH: error: Trustpoint does not have a cert
*Jun 5 15:49:41.228: %SYS-5-LOG_CONFIG_CHANGE: Buffer logging: level debugging, xml disabled, filtering disabled, size (262144)
*Jun 5 15:49:41.462: SDWAN INFO: PNP start, status: success
Router(config)#
Router(config)#
*Jun 5 15:49:41.403: %DMI-5-CONFIG_I: R0/0: nesd: Configured from NETCONF/RESTCONF by nesd, transaction-id -1
*Jun 5 15:49:41.462: %DMI-5-ACTIVE: R0/0: nesd: process is in steady state.
Router(config)#
Router(config)#
Router(config)#
Router(config)#
Router(config)#con
Router(config)#confi
Router(config)#config-
Router(config)#config-register 0x2102
Router(config)#do sh ver
software.
ROM: IOS-XE ROMMON
Router uptime is 2 minutes
Uptime for this control processor is 4 minutes
export@cisco.com.
Configuration register is 0x2142 (will be 0x2102 at next reload)
Router(config)#username neteng
Router(config)#username neteng secre
Router(config)#username neteng secret cisco@123
Router(config)#ena
Router(config)#enable secre
Router(config)#enable secret cisco@123
Router(config)#ip ssh
Router(config)#ip ssh ver
Router(config)#ip ssh version 2
Router(config)#line
Router(config)#line vty
Router(config)#line vty 0 4
Router(config-line)#go
Router(config-line)#log
Router(config-line)#logi
Router(config-line)#login loc
Router(config-line)#login local
Router(config-line)#tra
Router(config-line)#transport inp
Router(config-line)#transport input ssh
Router(config-line)#^Z
Router#
Router#
Router#
Router#
Router#
*Jun 5 15:52:17.107: %SYS-5-CONFIG_I: Configured from console by console
Router#
Router#
Router#
Router#
Router#
Router#conf t
Router#
Router#conf
Router#configu
Router#configure ?
confirm Confirm replacement of running-config with a new config
file
memory Configure from NV memory
network Configure from a TFTP network host
overwrite-network Overwrite NV memory from TFTP network host
replace Replace the running-config with a new config file
revert Parameters for reverting the configuration
terminal Configure from the terminal
<cr> <cr>
Router#configure ter
Router#configure terminal ?
lock Lock the configuration mode
<cr> <cr>
Router#
Router#configure terminal lo
Router#configure terminal lock
Router#
Router#con
Router#confi
Router#config
27 Replies 27
@razeev rohilla wrote:
can it is use with: set controller-mode disable
No, that is an invalid command.
so how can i user this command.
razeev rohilla
i have run this command on ROMMON mode, no msg seen after run this command and reset it. boot as same as previous.
rommon 1 > set DEVICE_MANAGED_MODE=autonomous
razeev rohilla
rommon 2 > controller-mode disable
monitor: command "controller-mode" not found
rommon 3 > set controller-mode disable
usage: set
rommon 4 > set DEVICE_MANAGED_MODE=autonomous
rommon 5 > reset
Resetting .......
IsoSize = 421446537
Image validated
Cisco Systems, Inc.
Software feature.
%INIT: waited 0 seconds for NVRAM to be available
--- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]:
% Please answer 'yes' or 'no'.
Would you like to enter the initial configuration dialog? [yes/no]: no
Would you like to terminate autoinstall? [yes]: yes
*Jun 7 12:27:43.372: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Jun 7 12:27:43.443: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = esg Next reboot level = ipbasek9 and License = No valid license found
*Jun 7 12:27:43.729: %ISR_THROUGHPUT-6-LEVEL: Throughput level has been set to 100000 kbps
*Jun 7 12:27:44.714: %IOSXE_RP_NV-3-NV_ACCESS_FAIL: Initial read of NVRAM contents failed
*Jun 7 12:27:45.645: %IOSXE_RP_NV-3-BACKUP_NV_ACCESS_FAIL: Initial read of backup NVRAM contents failed
*Jun 7 12:27:46.581: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Jun 7 12:27:46.605: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Jun 7 12:27:52.918: %GENERIC_SUBBLOCK-2-LATE_REGISTER: Late registration of GSB type pbr_color_sb, with id -9223277272776232232
*Jun 7 12:27:57.627: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Jun 7 12:27:58.145: in NSH init
*Jun 7 12:27:58.206: %VOICE_HA-7-STATUS: CUBE HA-supported platform detected.
*Jun 7 12:27:59.295: %LINK-3-UPDOWN: Interface Lsmpi0, changed state to up
*Jun 7 12:27:59.312: %LINK-3-UPDOWN: Interface EOBC0, changed state to up
*Jun 7 12:27:59.313: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0, changed state to up
*Jun 7 12:27:59.327: %LINEPROTO-5-UPDOWN: Line protocol on Interface LI-Null0, changed state to up
*Jun 7 12:27:59.328: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to down
*Jun 7 12:27:59.883: %LINK-3-UPDOWN: Interface LIIN0, changed state to up
*Jun 7 12:28:00.373: %LINEPROTO-5-UPDOWN: Line protocol on Interface Lsmpi0, changed state to up
*Jun 7 12:28:00.374: %LINEPROTO-5-UPDOWN: Line protocol on Interface EOBC0, changed state to up
*Jun 7 12:28:00.374: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Jun 7 12:28:01.439: %IOSXE_MGMTVRF-6-CREATE_SUCCESS_INFO: Management vrf Mgmt-intf created with ID 1, ipv4 table-id 0x1, ipv6 table-id 0x1E000001
*Jun 7 12:28:01.494: %LINEPROTO-5-UPDOWN: Line protocol on Interface LIIN0, changed state to up
*Jun 7 12:24:50.103: %IOSXE-3-PLATFORM: R0/0: kernel: dmi: Firmware registration failed.
*Jun 7 12:25:34.149: %IOSXE-3-PLATFORM: R0/0: kernel: dash_c2w_op_done: I2C Master time out: status register - 0x0
*Jun 7 12:25:34.149: %IOSXE-3-PLATFORM: R0/0: kernel: dash_i2c_xfer: I2C Master Error master=10 addr=0x50 status=0x0
*Jun 7 12:25:34.206: %IOSXE-3-PLATFORM: R0/0: kernel: dash_c2w_op_done: I2C Master time out: status register - 0x0
*Jun 7 12:25:34.207: %IOSXE-3-PLATFORM: R0/0: kernel: dash_i2c_xfer: I2C Master Error master=11 addr=0x50 status=0x0
*Jun 7 12:25:34.263: %IOSXE-3-PLATFORM: R0/0: kernel: dash_c2w_op_done: I2C Master time out: status register - 0x0
*Jun 7 12:25:34.264: %IOSXE-3-PLATFORM: R0/0: kernel: dash_i2c_xfer: I2C Master Error master=12 addr=0x50 status=0x0
*Jun 7 12:25:34.321: %IOSXE-3-PLATFORM: R0/0: kernel: dash_c2w_op_done: I2C Master time out: status register - 0x0
*Jun 7 12:25:34.322: %IOSXE-3-PLATFORM: R0/0: kernel: dash_i2c_xfer: I2C Master Error master=13 addr=0x50 status=0x0
*Jun 7 12:25:34.379: %IOSXE-3-PLATFORM: R0/0: kernel: dash_c2w_op_done: I2C Master time out: status register - 0x0
*Jun 7 12:25:34.380: %IOSXE-3-PLATFORM: R0/0: kernel: dash_i2c_xfer: I2C Master Error master=14 addr=0x50 status=0x0
*Jun 7 12:27:47.292: %CMLIB-3-THROUGHPUT_VALUE_SETUP_FAILED: R0/0: cmand: Throughput license found, throughput set to 14700000 kbps. Error: Invalid argument
*Jun 7 12:28:04.275: SDWAN INFO: Interface = GigabitEthernet0 mgmt
*Jun 7 12:28:04.276: SDWAN INFO: SDWAN system init done
*Jun 7 12:28:04.329: %IOSXE_OIR-6-REMSPA: SPA removed from subslot 0/0, interfaces disabled
*Jun 7 12:28:04.345: %SPA_OIR-6-OFFLINECARD: SPA (ISR4331-3x1GE) offline in subslot 0/0
*Jun 7 12:28:04.352: %IOSXE_OIR-6-INSCARD: Card (fp) inserted in slot F0
*Jun 7 12:28:04.352: %IOSXE_OIR-6-ONLINECARD: Card (fp) online in slot F0
*Jun 7 12:28:04.395: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 0
*Jun 7 12:28:04.395: %IOSXE_OIR-6-ONLINECARD: Card (cc) online in slot 0
*Jun 7 12:28:04.404: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 1
*Jun 7 12:28:04.404: %IOSXE_OIR-6-ONLINECARD: Card (cc) online in slot 1
*Jun 7 12:28:04.561: yang-infra: Auto enable netconf-yang
*Jun 7 12:28:04.583: %IOSXE_OIR-6-INSSPA: SPA inserted in subslot 0/0
*Jun 7 12:28:04.878: %ONEP_BASE-6-SS_ENABLED: ONEP: Service set Base was enabled by Default
*Jun 7 12:28:05.380: yang-infra: netconf-yang server has been notified to start
*Jun 7 12:28:05.771: %Cisco-SDWAN-Router-SYSMGR-5-NTCE-200050: R0/0: SYSMGR: System status blinking green (reason: Coming up)
*Jun 7 12:28:05.794: %Cisco-SDWAN-Router-SYSMGR-5-NTCE-200042: R0/0: SYSMGR: Created shared memory vconfd_shared_region
*Jun 7 12:28:06.201: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon confd @ pid 32278 in vpn 65534
*Jun 7 12:28:33.664: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon cfgmgr @ pid 6490 in vpn 0
*Jun 7 12:28:33.666: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon fpmd @ pid 6493 in vpn 0
*Jun 7 12:28:33.669: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon ftmd @ pid 6494 in vpn 0
*Jun 7 12:28:33.672: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon ompd @ pid 6495 in vpn 0
*Jun 7 12:28:33.674: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon ttmd @ pid 6496 in vpn 0
*Jun 7 12:28:33.678: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon vdaemon @ pid 6497 in vpn 0
*Jun 7 12:28:34.226: %Cisco-SDWAN-Router-TTMD-6-INFO-1200001: R0/0: TTMD: Starting
*Jun 7 12:28:34.348: %Cisco-SDWAN-Router-FPMD-6-INFO-1100001: R0/0: FPMD: Starting
*Jun 7 12:28:34.477: %Cisco-SDWAN-Router-CFGMGR-6-INFO-300001: R0/0: CFGMGR: Starting
*Jun 7 12:28:34.502: %Cisco-SDWAN-Router-OMPD-5-NTCE-400001: R0/0: OMPD: Starting
*Jun 7 12:28:34.851: %Cisco-SDWAN-Router-FTMD-6-INFO-1000020: R0/0: FTMD: SLA class '__all_tunnels__' added at index '0': loss = 128%, latency = 2147483647 ms
*Jun 7 12:28:35.445: %Cisco-SDWAN-Router-FTMD-4-WARN-1000007: R0/0: FTMD: Connection to TTM came up. p_msgq 0x7f479fa35500 p_ftm 0x9296f0
*Jun 7 12:28:38.719: %ONEP_BASE-6-SS_ENABLED: ONEP: Service set Vty was enabled by Platform
*Jun 7 12:28:38.927: %ONEP_BASE-6-CONNECT: [Element]: ONEP session Application:com.cisco.syncfd Host:Router ID:3748 User:a has connected.
*Jun 7 12:28:39.029: AUTH-FEAT-BC-EVENT: [Gi0/0/0] Nothing to convert
*Jun 7 12:28:39.108: AUTH-FEAT-BC-EVENT: [Gi0/0/1] Nothing to convert
*Jun 7 12:28:39.223: AUTH-FEAT-BC-EVENT: [Gi0/0/2] Nothing to convert
*Jun 7 12:28:39.257: %SPA_OIR-6-ONLINECARD: SPA (ISR4331-3x1GE) online in subslot 0/0
*Jun 7 12:28:41.018: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to down
*Jun 7 12:28:41.103: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/1, changed state to down
*Jun 7 12:28:41.206: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/2, changed state to down
*Jun 7 12:28:43.599: %ONEP_BASE-6-CONNECT: [Element]: ONEP session Application:com.cisco.nesd Host:Router ID:727 User:NETCONF has connected.
*Jun 7 12:28:47.388: %SYS-5-RESTART: System restarted --
*Jun 7 12:28:47.857: %LINK-5-CHANGED: Interface GigabitEthernet0/0/0, changed state to administratively down
*Jun 7 12:28:47.861: %LINK-5-CHANGED: Interface GigabitEthernet0/0/1, changed state to administratively down
*Jun 7 12:28:47.863: %LINK-5-CHANGED: Interface GigabitEthernet0/0/2, changed state to administratively down
*Jun 7 12:28:47.866: %LINK-5-CHANGED: Interface GigabitEthernet0, changed state to administratively down
*Jun 7 12:28:48.041: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Jun 7 12:28:48.041: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
*Jun 7 12:28:50.931: SDWAN INFO: application database sync to FPM: record-count 1426 error 76
*Jun 7 12:29:04.408: %AN-6-AN_ABORTED_BY_CONSOLE_INPUT: Autonomic disabled due to User intervention on console. configure 'autonomic' to enable it.
*Jun 7 12:29:04.274: %NDBMAN-5-ACTIVE: R0/0: ndbmand: All data providers active.
*Jun 7 12:29:04.304: %DMI-5-ACTIVE: R0/0: dmiauthd: process is in steady state.
CRYPTO_PKI: setting trustpoint policy for TP-self-signed-2482764321 to specify TP-self-signed-2482764321 keypair usage% Generating 2048 bit RSA keys, keys will be non-exportable...Failed to generate persistent self-signed certificate.
Secure server will use temporary self-signed certificate.
*Jun 7 12:29:07.791: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Jun 7 12:29:07.791: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
*Jun 7 12:29:08.812: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named CISCO_IDEVID_SUDI has been generated or imported
*Jun 7 12:29:08.860: %PKI-2-NON_AUTHORITATIVE_CLOCK: PKI timers have not been initialized due to non-authoritative system clock. Ensure system clock is configured/updated.
*Jun 7 12:29:08.867: CRYPTO_PKI: Error: Self signed certificate generation is already in progress. So, not honoring this request
*Jun 7 12:29:08.868: CRYPTO_PKI: Error: Self signed certificate generation is already in progress. So, not honoring this request
*Jun 7 12:29:11.966: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named TP-self-signed-2482764321 has been generated or imported
*Jun 7 12:29:11.968: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Jun 7 12:29:12.037: yang-infra: ERROR: Failed to create a new self-signed trustpoint
*Jun 7 12:29:12.220: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named TP-self-signed-2482764321.server has been generated or imported
*Jun 7 12:29:13.641: %DMI-5-INITIALIZED: R0/0: syncfd: process has initialized.
*Jun 7 12:29:18.298: %MODULE_STATE-6-ALL_MODULES_UP: All modules are now on-line.
*Jun 7 12:29:23.967: %DMI-3-NETCONF_SSH_ERROR: R0/0: ncsshd_bp: NETCONF/SSH: error: Trustpoint does not have a cert
*Jun 7 12:29:36.010: %SYS-5-LOG_CONFIG_CHANGE: Buffer logging: level debugging, xml disabled, filtering disabled, size (262144)
*Jun 7 12:29:36.281: SDWAN INFO: PNP start, status: success
*Jun 7 12:29:36.195: %DMI-5-CONFIG_I: R0/0: nesd: Configured from NETCONF/RESTCONF by nesd, transaction-id -1
*Jun 7 12:29:36.283: %DMI-5-ACTIVE: R0/0: nesd: process is in steady state.
Username:
Username: neteng
Password:
% Login invalid
Username:
Username:
Username:
Username:
Username:
razeev rohilla
please check and reply it still boot from  isr4300-ucmk9.16.9.2.SPA.bin image.
razeev rohilla
Router have no image:-
Router#dir flash:
Directory of bootflash:/
11 drwx 16384 Jun 5 2023 15:40:37 +00:00 lost+found
12 -rw- 421451453 Jun 5 2023 15:40:40 +00:00 isr4300-ucmk9.16.9.2.SPA.bin
364321 drwx 4096 Jun 7 2023 12:43:01 +00:00 .installer
48577 drwx 4096 Jun 5 2023 15:48:22 +00:00 core
105249 drwx 4096 Jun 5 2023 15:45:57 +00:00 .prst_sync
388609 drwx 4096 Jun 5 2023 15:46:03 +00:00 .rollback_timer
194305 drwx 16384 Jun 7 2023 12:47:08 +00:00 tracelogs
307649 drwx 4096 Jun 5 2023 15:48:03 +00:00 CRDU
13 -rw- 30 Jun 7 2023 12:45:25 +00:00 throughput_monitor_params
275265 drwx 4096 Jun 5 2023 15:48:19 +00:00 onep
97153 drwx 4096 Jun 5 2023 15:48:28 +00:00 sdwan
153825 drwx 4096 Jun 5 2023 15:48:31 +00:00 vmanage-admin
6703677440 bytes total (5869244416 bytes free)
To correct the boot variable string in IOS (not ROMMON):
conf t
 boot system flash bootflash:isr4300-ucmk9.16.9.2.SPA.bin
end
wr
in dir flash: it not showing normal image, which is ISR Software (X86_64_LINUX_IOSD-UNIVERSLAK9-M), Version 16.6.6 image
it showing only UCMK9 image not UNIVERSLAK9.
Router(config)#boot system flash bootflash:isr4300-ucmk9.16.9.2.SPA.bin
Router(config)#do wr
Router#wr
Router#
Router#c
Router#co
Router#cop
Router#copy ru
Router#copy running-config st
Router#copy running-config startup-config ?
<cr> <cr>
razeev rohilla
it nor supported commands as well.
Router#conf t
Router#dir bootflash:
194305 drwx 16384 Jun 7 2023 13:00:26 +00:00 tracelogs
6703677440 bytes total (5868683264 bytes free)
please advice further.
razeev rohilla
i think router have no normal IOS image to boot:
Please check if i am right.
Router#sh flash:
-#- --length-- ---------date/time--------- path
1 4096 Jun 07 2023 13:07:17.0000000000 +00:00 /bootflash/
2 16384 Jun 05 2023 15:40:37.0000000000 +00:00 /bootflash/lost+found
3 421451453 Jun 05 2023 15:40:40.0000000000 +00:00 /bootflash/isr4300-ucmk9.16.9.2.SPA.bin
4 4096 Jun 07 2023 13:18:24.0000000000 +00:00 /bootflash/.installer
5 58 Jun 07 2023 13:21:03.0000000000 +00:00 /bootflash/.installer/bootactive
6 4096 Jun 05 2023 15:48:30.0000000000 +00:00 /bootflash/.installer/images
7 4096 Jun 05 2023 15:48:30.0000000000 +00:00 /bootflash/.installer/images/isr4300-ucmk9.16.9.2.SPA.bin
8 4096 Jun 05 2023 15:48:30.0000000000 +00:00 /bootflash/.installer/images/isr4300-ucmk9.16.9.2.SPA.bin/confd0
9 4096 Jun 07 2023 13:22:08.0000000000 +00:00 /bootflash/.installer/images/isr4300-ucmk9.16.9.2.SPA.bin/confd0/cdb
10 4 Jun 07 2023 13:21:18.0000000000 +00:00 /bootflash/.installer/images/isr4300-ucmk9.16.9.2.SPA.bin/confd0/cdb/O.cdb
11 17351 Jun 07 2023 13:22:08.0000000000 +00:00 /bootflash/.installer/images/isr4300-ucmk9.16.9.2.SPA.bin/confd0/cdb/A.cdb
12 72670134 Jun 07 2023 13:21:31.0000000000 +00:00 /bootflash/.installer/images/isr4300-ucmk9.16.9.2.SPA.bin/confd0/cdb/C.cdb
13 4096 Jun 05 2023 15:48:30.0000000000 +00:00 /bootflash/.installer/images/isr4300-ucmk9.16.9.2.SPA.bin/confd0/rollback
14 4096 Jun 07 2023 13:22:05.0000000000 +00:00 /bootflash/.installer/images/isr4300-ucmk9.16.9.2.SPA.bin/confd0/candidate
15 4 Jun 07 2023 13:22:05.0000000000 +00:00 /bootflash/.installer/images/isr4300-ucmk9.16.9.2.SPA.bin/confd0/candidate/candidate.db
16 4096 Jun 07 2023 13:22:04.0000000000 +00:00 /bootflash/.installer/images/isr4300-ucmk9.16.9.2.SPA.bin/confd0/replaystore
17 13 Jun 07 2023 13:22:04.0000000000 +00:00 /bootflash/.installer/images/isr4300-ucmk9.16.9.2.SPA.bin/confd0/replaystore/snmpevents.siz
18 56 Jun 07 2023 13:22:04.0000000000 +00:00 /bootflash/.installer/images/isr4300-ucmk9.16.9.2.SPA.bin/confd0/replaystore/snmpevents.1
19 18 Jun 07 2023 13:22:04.0000000000 +00:00 /bootflash/.installer/images/isr4300-ucmk9.16.9.2.SPA.bin/confd0/replaystore/snmpevents.idx
20 13 Jun 07 2023 13:22:05.0000000000 +00:00 /bootflash/.installer/images/isr4300-ucmk9.16.9.2.SPA.bin/confd0/replaystore/viptela.siz
21 52757 Jun 07 2023 13:27:39.0000000000 +00:00 /bootflash/.installer/images/isr4300-ucmk9.16.9.2.SPA.bin/confd0/replaystore/viptela.1
22 18 Jun 07 2023 13:22:04.0000000000 +00:00 /bootflash/.installer/images/isr4300-ucmk9.16.9.2.SPA.bin/confd0/replaystore/viptela.idx
23 4096 Jun 07 2023 13:22:04.0000000000 +00:00 /bootflash/.installer/images/isr4300-ucmk9.16.9.2.SPA.bin/confd0/state
24 32 Jun 07 2023 13:22:04.0000000000 +00:00 /bootflash/.installer/images/isr4300-ucmk9.16.9.2.SPA.bin/confd0/state/global.data
25 4096 Jun 05 2023 15:48:22.0000000000 +00:00 /bootflash/core
26 4096 Jun 05 2023 15:46:03.0000000000 +00:00 /bootflash/core/modules
27 1 Jun 07 2023 13:01:32.0000000000 +00:00 /bootflash/core/.callhome
28 4096 Jun 07 2023 13:20:47.0000000000 +00:00 /bootflash/.prst_sync
29 4096 Jun 05 2023 15:46:03.0000000000 +00:00 /bootflash/.rollback_timer
30 16384 Jun 07 2023 13:29:49.0000000000 +00:00 /bootflash/tracelogs
31 660 Jun 07 2023 12:43:35.0000000000 +00:00 /bootflash/tracelogs/install_engine_R0-0.2016_0.20230607124256.bin.gz
32 2192 Jun 07 2023 12:43:35.0000000000 +00:00 /bootflash/tracelogs/cmand_R0-0.6957_0.20230607124313.bin.gz
33 868 Jun 07 2023 12:43:36.0000000000 +00:00 /bootflash/tracelogs/tdl_boottime_R0-0.7570_0.20230607124316.bin.gz
34 373 Jun 07 2023 12:43:36.0000000000 +00:00 /bootflash/tracelogs/inst_publish_retrieve_sw_sets_R0-0.7754_0.20230607124317.bin.gz
35 840 Jun 07 2023 12:43:36.0000000000 +00:00 /bootflash/tracelogs/issu_boottime_R0-0.7560_3.20230607124321.bin.gz
36 509 Jun 07 2023 12:43:36.0000000000 +00:00 /bootflash/tracelogs/inst_issu_check_R0-0.10871_0.20230607124322.bin.gz
37 509 Jun 07 2023 12:43:36.0000000000 +00:00 /bootflash/tracelogs/inst_issu_check_R0-0.10947_0.20230607124323.bin.gz
38 373 Jun 07 2023 12:43:36.0000000000 +00:00 /bootflash/tracelogs/inst_rollback_timer_R0-0.11172_0.20230607124324.bin.gz
39 1155 Jun 07 2023 12:43:36.0000000000 +00:00 /bootflash/tracelogs/issu_boottime_R0-0.7560_2.20230607124321.bin.gz
40 853 Jun 07 2023 12:43:36.0000000000 +00:00 /bootflash/tracelogs/issu_boottime_R0-0.7560_1.20230607124321.bin.gz
41 1286 Jun 07 2023 12:43:36.0000000000 +00:00 /bootflash/tracelogs/issu_boottime_R0-0.7560_0.20230607124316.bin.gz
42 9977 Jun 07 2023 13:22:19.0000000000 +00:00 /bootflash/tracelogs/pvp_R0-0.13753_0.20230607131855.bin.gz
43 1776 Jun 07 2023 13:20:47.0000000000 +00:00 /bootflash/tracelogs/plogd_F0-0.21177_0.20230607131919.bin.gz
44 1851 Jun 07 2023 12:43:46.0000000000 +00:00 /bootflash/tracelogs/cman_fp_F0-0.7068_0.20230607124315.bin.gz
45 1288 Jun 07 2023 12:43:49.0000000000 +00:00 /bootflash/tracelogs/droputil_R0-0.7100_1.20230607124320.bin.gz
46 1511 Jun 07 2023 13:21:02.0000000000 +00:00 /bootflash/tracelogs/cfgwr_R0-0.32227_0.20230607132102.bin.gz
47 1924 Jun 07 2023 12:43:56.0000000000 +00:00 /bootflash/tracelogs/cmcc_0-0.7307_0.20230607124316.bin.gz
48 14001 Jun 07 2023 12:44:04.0000000000 +00:00 /bootflash/tracelogs/plogd_R0-0.19865_1.20230607124359.bin.gz
49 1102 Jun 07 2023 12:44:07.0000000000 +00:00 /bootflash/tracelogs/droputil_R0-0.7100_2.20230607124349.bin.gz
50 51630 Jun 07 2023 13:24:00.0000000000 +00:00 /bootflash/tracelogs/create_luid_file_db_R0-0.18881_0.20230607132357.bin.gz
51 1611 Jun 07 2023 13:20:47.0000000000 +00:00 /bootflash/tracelogs/plogd_pmanlog_F0-0.20653_0.20230607131915.bin.gz
52 1778 Jun 07 2023 13:20:47.0000000000 +00:00 /bootflash/tracelogs/qfp_ucode_utah_pmanlog_F0-0.21913_0.20230607131918.bin.gz
53 47076 Jun 07 2023 13:24:02.0000000000 +00:00 /bootflash/tracelogs/create_luid_file_db_R0-0.18881_1.20230607132400.bin.gz
54 1511 Jun 07 2023 13:21:02.0000000000 +00:00 /bootflash/tracelogs/cfgwr_R0-0.32231_0.20230607132102.bin.gz
55 42860 Jun 07 2023 13:24:09.0000000000 +00:00 /bootflash/tracelogs/create_luid_file_db_F0-0.18944_0.20230607132409.bin.gz
56 44646 Jun 07 2023 13:24:10.0000000000 +00:00 /bootflash/tracelogs/create_luid_file_db_F0-0.18944_1.20230607132409.bin.gz
57 1616 Jun 07 2023 13:24:18.0000000000 +00:00 /bootflash/tracelogs/plogd_pmanlog_0-0.24430_0.20230607131923.bin.gz
58 1617 Jun 07 2023 12:45:24.0000000000 +00:00 /bootflash/tracelogs/plogd_pmanlog_F0-0.20388_0.20230607124352.bin.gz
59 1787 Jun 07 2023 12:45:24.0000000000 +00:00 /bootflash/tracelogs/plogd_F0-0.20863_0.20230607124355.bin.gz
60 1776 Jun 07 2023 12:45:25.0000000000 +00:00 /bootflash/tracelogs/qfp_ucode_utah_pmanlog_F0-0.21281_0.20230607124354.bin.gz
61 1234 Jun 07 2023 12:45:25.0000000000 +00:00 /bootflash/tracelogs/reflector_R0-0.7107_4.20230607124414.bin.gz
62 1936 Jun 07 2023 13:24:18.0000000000 +00:00 /bootflash/tracelogs/plogd_0-0.24809_0.20230607131925.bin.gz
63 42808 Jun 07 2023 13:24:18.0000000000 +00:00 /bootflash/tracelogs/create_luid_file_db_0-0.18985_0.20230607132418.bin.gz
64 1512 Jun 07 2023 12:45:40.0000000000 +00:00 /bootflash/tracelogs/cfgwr_R0-0.32169_0.20230607124539.bin.gz
65 1511 Jun 07 2023 12:45:40.0000000000 +00:00 /bootflash/tracelogs/cfgwr_R0-0.32170_0.20230607124539.bin.gz
66 1511 Jun 07 2023 12:45:40.0000000000 +00:00 /bootflash/tracelogs/cfgwr_R0-0.32174_0.20230607124539.bin.gz
67 1513 Jun 07 2023 12:45:40.0000000000 +00:00 /bootflash/tracelogs/cfgwr_R0-0.32176_0.20230607124539.bin.gz
68 1515 Jun 07 2023 12:45:40.0000000000 +00:00 /bootflash/tracelogs/cfgwr_R0-0.32180_0.20230607124539.bin.gz
69 1514 Jun 07 2023 12:45:40.0000000000 +00:00 /bootflash/tracelogs/cfgwr_R0-0.32186_0.20230607124540.bin.gz
70 1513 Jun 07 2023 12:45:40.0000000000 +00:00 /bootflash/tracelogs/cfgwr_R0-0.32195_0.20230607124540.bin.gz
71 1351 Jun 07 2023 12:45:41.0000000000 +00:00 /bootflash/tracelogs/droputil_R0-0.7100_3.20230607124407.bin.gz
72 1515 Jun 07 2023 12:45:41.0000000000 +00:00 /bootflash/tracelogs/cfgwr_R0-0.32220_0.20230607124540.bin.gz
73 1519 Jun 07 2023 12:45:41.0000000000 +00:00 /bootflash/tracelogs/cfgwr_R0-0.32226_0.20230607124540.bin.gz
74 1512 Jun 07 2023 12:45:41.0000000000 +00:00 /bootflash/tracelogs/cfgwr_R0-0.32233_0.20230607124540.bin.gz
75 1516 Jun 07 2023 12:45:41.0000000000 +00:00 /bootflash/tracelogs/cfgwr_R0-0.32243_0.20230607124540.bin.gz
76 1508 Jun 07 2023 12:45:41.0000000000 +00:00 /bootflash/tracelogs/cfgwr_R0-0.32266_0.20230607124540.bin.gz
77 1435 Jun 07 2023 12:45:44.0000000000 +00:00 /bootflash/tracelogs/reflector_R0-0.7107_5.20230607124525.bin.gz
78 2249 Jun 07 2023 12:46:11.0000000000 +00:00 /bootflash/tracelogs/mmap_schema_R0-0.2865_0.20230607124550.bin.gz
79 2390 Jun 07 2023 12:46:11.0000000000 +00:00 /bootflash/tracelogs/pubd_R0-0.4212_0.20230607124557.bin.gz
80 916 Jun 07 2023 12:46:11.0000000000 +00:00 /bootflash/tracelogs/pubd_R0-0.4212_1.20230607124611.bin.gz
81 1186 Jun 07 2023 12:46:12.0000000000 +00:00 /bootflash/tracelogs/pubd_R0-0.4212_2.20230607124611.bin.gz
82 1373 Jun 07 2023 12:46:29.0000000000 +00:00 /bootflash/tracelogs/pubd_R0-0.4212_3.20230607124612.bin.gz
83 9998 Jun 07 2023 12:46:58.0000000000 +00:00 /bootflash/tracelogs/pvp_R0-0.13764_0.20230607124333.bin.gz
84 1304 Jun 07 2023 12:46:58.0000000000 +00:00 /bootflash/tracelogs/droputil_R0-0.7100_4.20230607124540.bin.gz
85 1347 Jun 07 2023 12:47:08.0000000000 +00:00 /bootflash/tracelogs/reflector_R0-0.7107_6.20230607124544.bin.gz
86 1712 Jun 07 2023 12:48:35.0000000000 +00:00 /bootflash/tracelogs/nginx_pmanlog_R0-0.19666_0.20230607124741.bin.gz
87 2622 Jun 07 2023 12:48:35.0000000000 +00:00 /bootflash/tracelogs/nginx_R0-0.19843_0.20230607124742.bin.gz
88 51664 Jun 07 2023 12:48:38.0000000000 +00:00 /bootflash/tracelogs/create_luid_file_db_R0-0.25033_0.20230607124835.bin.gz
89 46884 Jun 07 2023 12:48:39.0000000000 +00:00 /bootflash/tracelogs/create_luid_file_db_R0-0.25033_1.20230607124838.bin.gz
90 42855 Jun 07 2023 12:48:47.0000000000 +00:00 /bootflash/tracelogs/create_luid_file_db_F0-0.25227_0.20230607124846.bin.gz
91 44689 Jun 07 2023 12:48:47.0000000000 +00:00 /bootflash/tracelogs/create_luid_file_db_F0-0.25227_1.20230607124847.bin.gz
92 1603 Jun 07 2023 12:48:55.0000000000 +00:00 /bootflash/tracelogs/plogd_pmanlog_0-0.24275_0.20230607124400.bin.gz
93 1938 Jun 07 2023 12:48:55.0000000000 +00:00 /bootflash/tracelogs/plogd_0-0.24669_0.20230607124402.bin.gz
94 42866 Jun 07 2023 12:48:56.0000000000 +00:00 /bootflash/tracelogs/create_luid_file_db_0-0.25261_0.20230607124855.bin.gz
95 44624 Jun 07 2023 12:48:56.0000000000 +00:00 /bootflash/tracelogs/create_luid_file_db_0-0.25261_1.20230607124856.bin.gz
96 1620 Jun 07 2023 12:48:57.0000000000 +00:00 /bootflash/tracelogs/plogd_pmanlog_1-0.25070_0.20230607124402.bin.gz
97 1933 Jun 07 2023 12:48:57.0000000000 +00:00 /bootflash/tracelogs/plogd_1-0.25455_0.20230607124404.bin.gz
98 42819 Jun 07 2023 12:48:57.0000000000 +00:00 /bootflash/tracelogs/create_luid_file_db_1-0.25279_0.20230607124857.bin.gz
99 44604 Jun 07 2023 12:48:57.0000000000 +00:00 /bootflash/tracelogs/create_luid_file_db_1-0.25279_1.20230607124857.bin.gz
100 36983 Jun 07 2023 12:50:26.0000000000 +00:00 /bootflash/tracelogs/create_luid_file_db_R0-0.25033_2.20230607124839.bin.gz
101 35975 Jun 07 2023 12:53:46.0000000000 +00:00 /bootflash/tracelogs/create_luid_file_db_F0-0.25227_2.20230607124847.bin.gz
102 49189 Jun 07 2023 13:06:53.0000000000 +00:00 /bootflash/tracelogs/IOSRP_R0-0.16937_0.20230607124514.bin.gz
103 1626 Jun 07 2023 13:07:02.0000000000 +00:00 /bootflash/tracelogs/pubd_R0-0.4212_4.20230607124612.bin.gz
104 42881 Jun 07 2023 12:31:22.0000000000 +00:00 /bootflash/tracelogs/create_luid_file_db_1-0.25216_0.20230607123122.bin.gz
105 1510 Jun 07 2023 13:21:03.0000000000 +00:00 /bootflash/tracelogs/cfgwr_R0-0.32233_0.20230607132102.bin.gz
106 2196 Jun 07 2023 12:14:25.0000000000 +00:00 /bootflash/tracelogs/cmand_R0-0.6958_0.20230607121403.bin.gz
107 42919 Jun 05 2023 15:51:26.0000000000 +00:00 /bootflash/tracelogs/create_luid_file_db_F0-0.19605_0.20230605155125.bin.gz
108 1924 Jun 05 2023 15:46:35.0000000000 +00:00 /bootflash/tracelogs/cmcc_0-0.7299_0.20230605154554.bin.gz
109 36023 Jun 07 2023 12:53:55.0000000000 +00:00 /bootflash/tracelogs/create_luid_file_db_0-0.25261_2.20230607124856.bin.gz
110 36022 Jun 07 2023 12:53:57.0000000000 +00:00 /bootflash/tracelogs/create_luid_file_db_1-0.25279_2.20230607124857.bin.gz
111 1802 Jun 07 2023 13:20:56.0000000000 +00:00 /bootflash/tracelogs/linux_iosd_image_pmanlog_R0-0.16727_7.20230607132046.bin.gz
112 4382 Jun 07 2023 13:06:53.0000000000 +00:00 /bootflash/tracelogs/vdaemon_R0-0.7095_0.20230607124610.bin.gz
113 43290 Jun 05 2023 15:51:35.0000000000 +00:00 /bootflash/tracelogs/create_luid_file_db_1-0.19658_0.20230605155135.bin.gz
114 36310 Jun 05 2023 15:56:35.0000000000 +00:00 /bootflash/tracelogs/create_luid_file_db_0-0.19651_2.20230605155135.bin.gz
115 46989 Jun 07 2023 12:31:04.0000000000 +00:00 /bootflash/tracelogs/create_luid_file_db_R0-0.25093_1.20230607123103.bin.gz
116 1775 Jun 07 2023 12:16:15.0000000000 +00:00 /bootflash/tracelogs/plogd_F0-0.21360_0.20230607121446.bin.gz
117 2035 Jun 07 2023 13:06:49.0000000000 +00:00 /bootflash/tracelogs/linux_iosd_image_pmanlog_R0-0.16747_8.20230607124533.bin.gz
118 44673 Jun 07 2023 12:31:12.0000000000 +00:00 /bootflash/tracelogs/create_luid_file_db_F0-0.25165_1.20230607123112.bin.gz
119 36105 Jun 05 2023 15:56:25.0000000000 +00:00 /bootflash/tracelogs/create_luid_file_db_F0-0.19605_2.20230605155126.bin.gz
120 3934 Jun 07 2023 13:06:56.0000000000 +00:00 /bootflash/tracelogs/vdaemon_R0-0.7095_3.20230607130653.bin.gz
121 374 Jun 07 2023 12:14:25.0000000000 +00:00 /bootflash/tracelogs/inst_publish_retrieve_sw_sets_R0-0.7751_0.20230607121407.bin.gz
122 1777 Jun 05 2023 15:58:22.0000000000 +00:00 /bootflash/tracelogs/qfp_ucode_utah_pmanlog_F0-0.21361_0.20230605154633.bin.gz
123 1511 Jun 07 2023 13:21:03.0000000000 +00:00 /bootflash/tracelogs/cfgwr_R0-0.32236_0.20230607132102.bin.gz
124 9463 Jun 07 2023 13:06:54.0000000000 +00:00 /bootflash/tracelogs/cmand_R0-0.15028_0.20230607124337.bin.gz
125 1783 Jun 07 2023 12:16:15.0000000000 +00:00 /bootflash/tracelogs/qfp_ucode_utah_pmanlog_F0-0.21819_0.20230607121445.bin.gz
126 2246 Jun 05 2023 15:48:52.0000000000 +00:00 /bootflash/tracelogs/mmap_schema_R0-0.5237_0.20230605154840.bin.gz
127 1608 Jun 07 2023 12:27:50.0000000000 +00:00 /bootflash/tracelogs/plogd_pmanlog_F0-0.20390_0.20230607122617.bin.gz
128 3779 Jun 07 2023 13:06:58.0000000000 +00:00 /bootflash/tracelogs/nginx_R0-0.24257_1.20230607130657.bin.gz
129 44656 Jun 07 2023 12:31:22.0000000000 +00:00 /bootflash/tracelogs/create_luid_file_db_0-0.25209_1.20230607123121.bin.gz
130 3777 Jun 07 2023 13:06:59.0000000000 +00:00 /bootflash/tracelogs/nginx_R0-0.24257_3.20230607130658.bin.gz
131 1931 Jun 07 2023 12:31:21.0000000000 +00:00 /bootflash/tracelogs/plogd_0-0.24790_0.20230607122627.bin.gz
132 3913 Jun 07 2023 13:06:54.0000000000 +00:00 /bootflash/tracelogs/vdaemon_R0-0.7095_2.20230607130653.bin.gz
133 509 Jun 05 2023 15:46:14.0000000000 +00:00 /bootflash/tracelogs/inst_issu_check_R0-0.10908_0.20230605154601.bin.gz
134 13812 Jun 05 2023 15:46:38.0000000000 +00:00 /bootflash/tracelogs/plogd_R0-0.19224_1.20230605154635.bin.gz
135 1048576 Jun 07 2023 13:07:02.0000000000 +00:00 /bootflash/tracelogs/nginx_R0-0.24257_2.20230607130658.bin
136 1935 Jun 07 2023 13:24:19.0000000000 +00:00 /bootflash/tracelogs/plogd_1-0.25315_0.20230607131927.bin.gz
137 1921 Jun 07 2023 13:19:18.0000000000 +00:00 /bootflash/tracelogs/cmcc_0-0.7303_0.20230607131838.bin.gz
138 1926 Jun 05 2023 15:51:35.0000000000 +00:00 /bootflash/tracelogs/plogd_1-0.25511_0.20230605154644.bin.gz
139 1512 Jun 07 2023 13:21:03.0000000000 +00:00 /bootflash/tracelogs/cfgwr_R0-0.32237_0.20230607132102.bin.gz
140 1509 Jun 07 2023 13:21:03.0000000000 +00:00 /bootflash/tracelogs/cfgwr_R0-0.32238_0.20230607132102.bin.gz
141 46989 Jun 05 2023 15:51:18.0000000000 +00:00 /bootflash/tracelogs/create_luid_file_db_R0-0.19548_1.20230605155117.bin.gz
142 371 Jun 07 2023 12:26:01.0000000000 +00:00 /bootflash/tracelogs/inst_rollback_timer_R0-0.11181_0.20230607122549.bin.gz
143 3933 Jun 07 2023 13:06:54.0000000000 +00:00 /bootflash/tracelogs/vdaemon_R0-0.7095_1.20230607130653.bin.gz
144 1602 Jun 05 2023 15:51:35.0000000000 +00:00 /bootflash/tracelogs/plogd_pmanlog_1-0.25096_0.20230605154641.bin.gz
145 9910 Jun 05 2023 15:49:36.0000000000 +00:00 /bootflash/tracelogs/pvp_R0-0.13763_0.20230605154612.bin.gz
146 972 Jun 07 2023 13:06:54.0000000000 +00:00 /bootflash/tracelogs/linux_iosd_image_pmanlog_R0-0.16747_9.20230607130649.bin.gz
147 1511 Jun 07 2023 13:21:03.0000000000 +00:00 /bootflash/tracelogs/cfgwr_R0-0.32242_0.20230607132102.bin.gz
148 9911 Jun 07 2023 12:29:24.0000000000 +00:00 /bootflash/tracelogs/pvp_R0-0.13774_0.20230607122558.bin.gz
149 2199 Jun 07 2023 13:18:58.0000000000 +00:00 /bootflash/tracelogs/cmand_R0-0.6954_0.20230607131836.bin.gz
150 51574 Jun 05 2023 15:51:17.0000000000 +00:00 /bootflash/tracelogs/create_luid_file_db_R0-0.19548_0.20230605155114.bin.gz
151 44595 Jun 05 2023 15:51:35.0000000000 +00:00 /bootflash/tracelogs/create_luid_file_db_1-0.19658_1.20230605155135.bin.gz
152 1615 Jun 07 2023 12:31:22.0000000000 +00:00 /bootflash/tracelogs/plogd_pmanlog_1-0.25034_0.20230607122626.bin.gz
153 2288 Jun 07 2023 13:21:33.0000000000 +00:00 /bootflash/tracelogs/pubd_R0-0.4309_0.20230607132125.bin.gz
154 868 Jun 07 2023 12:14:25.0000000000 +00:00 /bootflash/tracelogs/tdl_boottime_R0-0.7570_0.20230607121406.bin.gz
155 44624 Jun 05 2023 15:56:35.0000000000 +00:00 /bootflash/tracelogs/create_luid_file_db_0-0.19651_1.20230605155135.bin.gz
156 2627 Jun 07 2023 12:31:00.0000000000 +00:00 /bootflash/tracelogs/nginx_R0-0.19739_0.20230607122957.bin.gz
157 13945 Jun 07 2023 12:14:52.0000000000 +00:00 /bootflash/tracelogs/plogd_R0-0.19087_1.20230607121447.bin.gz
158 3948 Jun 07 2023 13:06:55.0000000000 +00:00 /bootflash/tracelogs/vdaemon_R0-0.7095_5.20230607130654.bin.gz
159 3949 Jun 07 2023 13:06:55.0000000000 +00:00 /bootflash/tracelogs/vdaemon_R0-0.7095_4.20230607130654.bin.gz
160 1748 Jun 07 2023 13:06:56.0000000000 +00:00 /bootflash/tracelogs/cmand_pmanlog_R0-0.14873_0.20230607124336.bin.gz
161 3930 Jun 07 2023 13:06:56.0000000000 +00:00 /bootflash/tracelogs/vdaemon_R0-0.7095_9.20230607130655.bin.gz
162 3945 Jun 07 2023 13:06:56.0000000000 +00:00 /bootflash/tracelogs/vdaemon_R0-0.7095_8.20230607130655.bin.gz
163 3932 Jun 07 2023 13:06:56.0000000000 +00:00 /bootflash/tracelogs/vdaemon_R0-0.7095_7.20230607130655.bin.gz
164 3946 Jun 07 2023 13:06:57.0000000000 +00:00 /bootflash/tracelogs/vdaemon_R0-0.7095_6.20230607130654.bin.gz
165 3921 Jun 07 2023 13:06:57.0000000000 +00:00 /bootflash/tracelogs/vdaemon_R0-0.7095_11.20230607130656.bin.gz
166 4018 Jun 07 2023 13:06:57.0000000000 +00:00 /bootflash/tracelogs/vdaemon_R0-0.7095_10.20230607130656.bin.gz
167 3906 Jun 07 2023 13:06:57.0000000000 +00:00 /bootflash/tracelogs/vdaemon_R0-0.7095_12.20230607130657.bin.gz
168 4045 Jun 07 2023 13:06:57.0000000000 +00:00 /bootflash/tracelogs/vdaemon_R0-0.7095_13.20230607130657.bin.gz
169 1034 Jun 07 2023 13:06:58.0000000000 +00:00 /bootflash/tracelogs/droputil_R0-0.7100_5.20230607124629.bin.gz
170 3898 Jun 07 2023 13:06:58.0000000000 +00:00 /bootflash/tracelogs/vdaemon_R0-0.7095_14.20230607130657.bin.gz
171 3906 Jun 07 2023 13:07:00.0000000000 +00:00 /bootflash/tracelogs/vdaemon_R0-0.7095_15.20230607130658.bin.gz
172 658 Jun 07 2023 13:18:58.0000000000 +00:00 /bootflash/tracelogs/install_engine_R0-0.2019_0.20230607131819.bin.gz
173 13540 Jun 07 2023 12:26:30.0000000000 +00:00 /bootflash/tracelogs/plogd_R0-0.19715_1.20230607122625.bin.gz
174 866 Jun 07 2023 13:18:59.0000000000 +00:00 /bootflash/tracelogs/tdl_boottime_R0-0.7565_0.20230607131839.bin.gz
175 372 Jun 07 2023 13:18:59.0000000000 +00:00 /bootflash/tracelogs/inst_publish_retrieve_sw_sets_R0-0.7750_0.20230607131839.bin.gz
176 872 Jun 07 2023 12:26:01.0000000000 +00:00 /bootflash/tracelogs/tdl_boottime_R0-0.7580_0.20230607122541.bin.gz
177 2183 Jun 07 2023 12:26:01.0000000000 +00:00 /bootflash/tracelogs/cmand_R0-0.6969_0.20230607122539.bin.gz
178 1782 Jun 05 2023 15:51:25.0000000000 +00:00 /bootflash/tracelogs/plogd_F0-0.21064_0.20230605154635.bin.gz
179 1943 Jun 05 2023 15:51:35.0000000000 +00:00 /bootflash/tracelogs/plogd_0-0.25007_0.20230605154642.bin.gz
180 1776 Jun 07 2023 12:27:50.0000000000 +00:00 /bootflash/tracelogs/qfp_ucode_utah_pmanlog_F0-0.21314_0.20230607122619.bin.gz
181 1143 Jun 07 2023 13:18:59.0000000000 +00:00 /bootflash/tracelogs/droputil_R0-0.7103_0.20230607131837.bin.gz
182 44599 Jun 07 2023 12:31:22.0000000000 +00:00 /bootflash/tracelogs/create_luid_file_db_1-0.25216_1.20230607123122.bin.gz
183 507 Jun 07 2023 12:14:26.0000000000 +00:00 /bootflash/tracelogs/inst_issu_check_R0-0.10874_0.20230607121412.bin.gz
184 13696 Jun 07 2023 13:20:44.0000000000 +00:00 /bootflash/tracelogs/plogd_R0-0.19525_1.20230607131922.bin.gz
185 1516 Jun 07 2023 13:21:03.0000000000 +00:00 /bootflash/tracelogs/cfgwr_R0-0.32243_0.20230607132102.bin.gz
186 507 Jun 05 2023 15:46:14.0000000000 +00:00 /bootflash/tracelogs/inst_issu_check_R0-0.10832_0.20230605154601.bin.gz
187 371 Jun 05 2023 15:46:14.0000000000 +00:00 /bootflash/tracelogs/inst_rollback_timer_R0-0.11173_0.20230605154603.bin.gz
188 508 Jun 07 2023 12:14:26.0000000000 +00:00 /bootflash/tracelogs/inst_issu_check_R0-0.10955_0.20230607121413.bin.gz
189 10 Jun 05 2023 15:48:25.0000000000 +00:00 /bootflash/tracelogs/timestamp
190 42836 Jun 07 2023 12:31:12.0000000000 +00:00 /bootflash/tracelogs/create_luid_file_db_F0-0.25165_0.20230607123111.bin.gz
191 36062 Jun 05 2023 15:56:35.0000000000 +00:00 /bootflash/tracelogs/create_luid_file_db_1-0.19658_2.20230605155135.bin.gz
192 844 Jun 07 2023 13:18:59.0000000000 +00:00 /bootflash/tracelogs/issu_boottime_R0-0.7554_3.20230607131844.bin.gz
193 506 Jun 07 2023 13:18:59.0000000000 +00:00 /bootflash/tracelogs/inst_issu_check_R0-0.10865_0.20230607131845.bin.gz
194 506 Jun 07 2023 13:18:59.0000000000 +00:00 /bootflash/tracelogs/inst_issu_check_R0-0.10952_0.20230607131845.bin.gz
195 368 Jun 07 2023 13:18:59.0000000000 +00:00 /bootflash/tracelogs/inst_rollback_timer_R0-0.11166_0.20230607131847.bin.gz
196 1162 Jun 07 2023 13:18:59.0000000000 +00:00 /bootflash/tracelogs/issu_boottime_R0-0.7554_2.20230607131844.bin.gz
197 1514 Jun 07 2023 13:21:03.0000000000 +00:00 /bootflash/tracelogs/cfgwr_R0-0.32285_0.20230607132102.bin.gz
198 1605 Jun 07 2023 13:24:19.0000000000 +00:00 /bootflash/tracelogs/plogd_pmanlog_1-0.25000_0.20230607131924.bin.gz
199 51582 Jun 07 2023 12:31:03.0000000000 +00:00 /bootflash/tracelogs/create_luid_file_db_R0-0.25093_0.20230607123100.bin.gz
200 2181 Jun 05 2023 15:46:14.0000000000 +00:00 /bootflash/tracelogs/cmand_R0-0.6950_0.20230605154551.bin.gz
201 1328 Jun 07 2023 13:21:03.0000000000 +00:00 /bootflash/tracelogs/droputil_R0-0.7103_3.20230607131931.bin.gz
202 615 Jun 05 2023 15:46:14.0000000000 +00:00 /bootflash/tracelogs/install_engine_R0-0.2016_0.20230605154534.bin.gz
203 9924 Jun 07 2023 12:17:46.0000000000 +00:00 /bootflash/tracelogs/pvp_R0-0.13761_0.20230607121423.bin.gz
204 1389 Jun 07 2023 12:28:37.0000000000 +00:00 /bootflash/tracelogs/pubd_R0-0.4158_3.20230607122836.bin.gz
205 45479 Jun 05 2023 15:48:25.0000000000 +00:00 /bootflash/tracelogs/dmesg
206 848 Jun 07 2023 13:18:59.0000000000 +00:00 /bootflash/tracelogs/issu_boottime_R0-0.7554_1.20230607131843.bin.gz
207 36936 Jun 07 2023 12:32:53.0000000000 +00:00 /bootflash/tracelogs/create_luid_file_db_R0-0.25093_2.20230607123104.bin.gz
208 1667 Jun 05 2023 15:51:35.0000000000 +00:00 /bootflash/tracelogs/ngiolite_pmanlog_0-0.28636_0.20230605154652.bin.gz
209 1849 Jun 05 2023 15:46:25.0000000000 +00:00 /bootflash/tracelogs/cman_fp_F0-0.7060_0.20230605154553.bin.gz
210 1780 Jun 07 2023 12:27:50.0000000000 +00:00 /bootflash/tracelogs/plogd_F0-0.20881_0.20230607122621.bin.gz
211 1271 Jun 07 2023 13:18:59.0000000000 +00:00 /bootflash/tracelogs/issu_boottime_R0-0.7554_0.20230607131839.bin.gz
212 42863 Jun 07 2023 12:31:21.0000000000 +00:00 /bootflash/tracelogs/create_luid_file_db_0-0.25209_0.20230607123121.bin.gz
213 44670 Jun 05 2023 15:51:26.0000000000 +00:00 /bootflash/tracelogs/create_luid_file_db_F0-0.19605_1.20230605155126.bin.gz
214 1510 Jun 07 2023 13:21:03.0000000000 +00:00 /bootflash/tracelogs/cfgwr_R0-0.32286_0.20230607132102.bin.gz
215 1510 Jun 07 2023 13:21:03.0000000000 +00:00 /bootflash/tracelogs/cfgwr_R0-0.32289_0.20230607132102.bin.gz
216 3590 Jun 05 2023 15:51:35.0000000000 +00:00 /bootflash/tracelogs/ngiolite_0-0.28881_0.20230605154653.bin.gz
217 1154 Jun 07 2023 12:26:01.0000000000 +00:00 /bootflash/tracelogs/issu_boottime_R0-0.7569_2.20230607122546.bin.gz
218 1510 Jun 07 2023 13:21:03.0000000000 +00:00 /bootflash/tracelogs/cfgwr_R0-0.32297_0.20230607132103.bin.gz
219 1853 Jun 07 2023 12:26:11.0000000000 +00:00 /bootflash/tracelogs/cman_fp_F0-0.7079_0.20230607122540.bin.gz
220 874 Jun 05 2023 15:46:14.0000000000 +00:00 /bootflash/tracelogs/tdl_boottime_R0-0.7561_0.20230605154554.bin.gz
221 374 Jun 07 2023 12:26:01.0000000000 +00:00 /bootflash/tracelogs/inst_publish_retrieve_sw_sets_R0-0.7761_0.20230607122542.bin.gz
222 662 Jun 07 2023 12:26:00.0000000000 +00:00 /bootflash/tracelogs/install_engine_R0-0.2022_0.20230607122521.bin.gz
223 1660 Jun 07 2023 13:19:03.0000000000 +00:00 /bootflash/tracelogs/reflector_R0-0.7093_0.20230607131837.bin.gz
224 1850 Jun 07 2023 13:19:09.0000000000 +00:00 /bootflash/tracelogs/cman_fp_F0-0.7064_0.20230607131837.bin.gz
225 1299 Jun 07 2023 13:19:15.0000000000 +00:00 /bootflash/tracelogs/droputil_R0-0.7103_1.20230607131842.bin.gz
226 1370 Jun 07 2023 13:19:18.0000000000 +00:00 /bootflash/tracelogs/reflector_R0-0.7093_1.20230607131903.bin.gz
227 1103 Jun 07 2023 13:19:31.0000000000 +00:00 /bootflash/tracelogs/droputil_R0-0.7103_2.20230607131915.bin.gz
228 1287 Jun 07 2023 13:19:33.0000000000 +00:00 /bootflash/tracelogs/reflector_R0-0.7093_2.20230607131918.bin.gz
229 1228 Jun 07 2023 13:19:37.0000000000 +00:00 /bootflash/tracelogs/reflector_R0-0.7093_3.20230607131933.bin.gz
230 1187 Jun 07 2023 13:20:44.0000000000 +00:00 /bootflash/tracelogs/reflector_R0-0.7093_4.20230607131937.bin.gz
231 2311 Jun 07 2023 13:20:44.0000000000 +00:00 /bootflash/tracelogs/linux_iosd_image_pmanlog_R0-0.16727_0.20230607131906.bin.gz
232 1627 Jun 07 2023 13:20:46.0000000000 +00:00 /bootflash/tracelogs/linux_iosd_image_pmanlog_R0-0.16727_2.20230607132046.bin.gz
233 1702 Jun 07 2023 13:20:46.0000000000 +00:00 /bootflash/tracelogs/linux_iosd_image_pmanlog_R0-0.16727_1.20230607132044.bin.gz
234 1594 Jun 07 2023 13:20:46.0000000000 +00:00 /bootflash/tracelogs/linux_iosd_image_pmanlog_R0-0.16727_6.20230607132046.bin.gz
235 1590 Jun 07 2023 13:20:46.0000000000 +00:00 /bootflash/tracelogs/linux_iosd_image_pmanlog_R0-0.16727_5.20230607132046.bin.gz
236 1608 Jun 07 2023 13:20:46.0000000000 +00:00 /bootflash/tracelogs/linux_iosd_image_pmanlog_R0-0.16727_4.20230607132046.bin.gz
237 1618 Jun 07 2023 13:20:46.0000000000 +00:00 /bootflash/tracelogs/linux_iosd_image_pmanlog_R0-0.16727_3.20230607132046.bin.gz
238 36900 Jun 05 2023 15:53:06.0000000000 +00:00 /bootflash/tracelogs/create_luid_file_db_R0-0.19548_2.20230605155118.bin.gz
239 1850 Jun 07 2023 12:14:36.0000000000 +00:00 /bootflash/tracelogs/cman_fp_F0-0.7069_0.20230607121405.bin.gz
240 44611 Jun 07 2023 13:24:18.0000000000 +00:00 /bootflash/tracelogs/create_luid_file_db_0-0.18985_1.20230607132418.bin.gz
241 1508 Jun 07 2023 13:21:03.0000000000 +00:00 /bootflash/tracelogs/cfgwr_R0-0.32299_0.20230607132103.bin.gz
242 1452 Jun 07 2023 13:21:10.0000000000 +00:00 /bootflash/tracelogs/reflector_R0-0.7093_5.20230607132044.bin.gz
243 2249 Jun 07 2023 13:21:33.0000000000 +00:00 /bootflash/tracelogs/mmap_schema_R0-0.3223_0.20230607132116.bin.gz
244 509 Jun 07 2023 12:26:01.0000000000 +00:00 /bootflash/tracelogs/inst_issu_check_R0-0.10880_0.20230607122547.bin.gz
245 933 Jun 07 2023 13:21:34.0000000000 +00:00 /bootflash/tracelogs/pubd_R0-0.4309_1.20230607132133.bin.gz
246 1607 Jun 07 2023 12:31:21.0000000000 +00:00 /bootflash/tracelogs/plogd_pmanlog_0-0.24384_0.20230607122625.bin.gz
247 370 Jun 07 2023 12:14:26.0000000000 +00:00 /bootflash/tracelogs/inst_rollback_timer_R0-0.11175_0.20230607121414.bin.gz
248 1145 Jun 07 2023 13:21:34.0000000000 +00:00 /bootflash/tracelogs/pubd_R0-0.4309_2.20230607132134.bin.gz
249 42837 Jun 07 2023 13:24:19.0000000000 +00:00 /bootflash/tracelogs/create_luid_file_db_1-0.18992_0.20230607132419.bin.gz
250 1397 Jun 07 2023 13:21:34.0000000000 +00:00 /bootflash/tracelogs/pubd_R0-0.4309_3.20230607132134.bin.gz
251 42780 Jun 05 2023 15:51:35.0000000000 +00:00 /bootflash/tracelogs/create_luid_file_db_0-0.19651_0.20230605155134.bin.gz
252 1292 Jun 07 2023 13:21:45.0000000000 +00:00 /bootflash/tracelogs/droputil_R0-0.7103_4.20230607132102.bin.gz
253 1606 Jun 05 2023 15:51:25.0000000000 +00:00 /bootflash/tracelogs/plogd_pmanlog_F0-0.20581_0.20230605154631.bin.gz
254 1341 Jun 07 2023 13:22:02.0000000000 +00:00 /bootflash/tracelogs/reflector_R0-0.7093_6.20230607132110.bin.gz
255 44672 Jun 07 2023 13:24:20.0000000000 +00:00 /bootflash/tracelogs/create_luid_file_db_1-0.18992_1.20230607132419.bin.gz
256 1930 Jun 07 2023 12:31:22.0000000000 +00:00 /bootflash/tracelogs/plogd_1-0.25339_0.20230607122629.bin.gz
257 1698 Jun 07 2023 12:31:00.0000000000 +00:00 /bootflash/tracelogs/nginx_pmanlog_R0-0.19559_0.20230607122956.bin.gz
258 841 Jun 07 2023 12:26:01.0000000000 +00:00 /bootflash/tracelogs/issu_boottime_R0-0.7569_3.20230607122547.bin.gz
259 508 Jun 07 2023 12:26:01.0000000000 +00:00 /bootflash/tracelogs/inst_issu_check_R0-0.10956_0.20230607122548.bin.gz
260 2239 Jun 07 2023 12:17:01.0000000000 +00:00 /bootflash/tracelogs/mmap_schema_R0-0.5846_0.20230607121648.bin.gz
261 2243 Jun 07 2023 12:28:36.0000000000 +00:00 /bootflash/tracelogs/mmap_schema_R0-0.2811_0.20230607122815.bin.gz
262 1926 Jun 07 2023 12:26:21.0000000000 +00:00 /bootflash/tracelogs/cmcc_0-0.7318_0.20230607122541.bin.gz
263 1928 Jun 07 2023 12:14:46.0000000000 +00:00 /bootflash/tracelogs/cmcc_0-0.7308_0.20230607121406.bin.gz
264 1603 Jun 05 2023 15:51:35.0000000000 +00:00 /bootflash/tracelogs/plogd_pmanlog_0-0.24617_0.20230605154639.bin.gz
265 662 Jun 07 2023 12:14:25.0000000000 +00:00 /bootflash/tracelogs/install_engine_R0-0.2020_0.20230607121346.bin.gz
266 372 Jun 05 2023 15:46:14.0000000000 +00:00 /bootflash/tracelogs/inst_publish_retrieve_sw_sets_R0-0.7730_0.20230605154555.bin.gz
267 1608 Jun 07 2023 12:16:15.0000000000 +00:00 /bootflash/tracelogs/plogd_pmanlog_F0-0.20916_0.20230607121443.bin.gz
268 36962 Jun 07 2023 13:25:50.0000000000 +00:00 /bootflash/tracelogs/create_luid_file_db_R0-0.18881_2.20230607132402.bin.gz
269 36086 Jun 07 2023 13:29:09.0000000000 +00:00 /bootflash/tracelogs/create_luid_file_db_F0-0.18944_2.20230607132410.bin.gz
270 36091 Jun 07 2023 13:29:18.0000000000 +00:00 /bootflash/tracelogs/create_luid_file_db_0-0.18985_2.20230607132418.bin.gz
271 36012 Jun 07 2023 13:29:19.0000000000 +00:00 /bootflash/tracelogs/create_luid_file_db_1-0.18992_2.20230607132420.bin.gz
272 4096 Jun 05 2023 15:48:03.0000000000 +00:00 /bootflash/CRDU
273 30 Jun 07 2023 13:20:47.0000000000 +00:00 /bootflash/throughput_monitor_params
274 4096 Jun 05 2023 15:48:19.0000000000 +00:00 /bootflash/onep
275 4096 Jun 05 2023 15:48:19.0000000000 +00:00 /bootflash/onep/apps-cli
276 4096 Jun 05 2023 15:48:28.0000000000 +00:00 /bootflash/sdwan
277 4096 Jun 05 2023 15:48:28.0000000000 +00:00 /bootflash/sdwan/usr
278 4096 Jun 05 2023 15:48:28.0000000000 +00:00 /bootflash/sdwan/usr/share
279 4096 Jun 07 2023 13:21:02.0000000000 +00:00 /bootflash/sdwan/usr/share/viptela
280 7444 Jun 05 2023 15:48:29.0000000000 +00:00 /bootflash/sdwan/usr/share/viptela/root-ca.crt
281 7444 Jun 05 2023 15:48:29.0000000000 +00:00 /bootflash/sdwan/usr/share/viptela/symantec-root-ca.crt
282 43 Jun 07 2023 13:21:02.0000000000 +00:00 /bootflash/sdwan/usr/share/viptela/viptela-eng-ca.crt
283 50 Jun 07 2023 13:21:02.0000000000 +00:00 /bootflash/sdwan/usr/share/viptela/viptela-production-ca.crt
284 41 Jun 07 2023 13:21:02.0000000000 +00:00 /bootflash/sdwan/usr/share/viptela/zprov-eng-ca.crt
285 48 Jun 07 2023 13:21:02.0000000000 +00:00 /bootflash/sdwan/usr/share/viptela/zprov-production-ca.crt
286 41 Jun 05 2023 15:48:29.0000000000 +00:00 /bootflash/sdwan/usr/share/viptela/ViptelaChain.pem
287 0 Jun 07 2023 13:21:35.0000000000 +00:00 /bootflash/sdwan/usr/share/viptela/diff_vedge_serial_numbers
288 1704 Jun 05 2023 15:49:52.0000000000 +00:00 /bootflash/sdwan/usr/share/viptela/clientkey.pem
289 1131 Jun 05 2023 15:49:52.0000000000 +00:00 /bootflash/sdwan/usr/share/viptela/clientkey.crt
290 2995 Jun 07 2023 13:22:33.0000000000 +00:00 /bootflash/sdwan/usr/share/viptela/boardid.pem
291 4096 Jun 05 2023 15:48:28.0000000000 +00:00 /bootflash/sdwan/etc
292 4096 Jun 05 2023 15:48:29.0000000000 +00:00 /bootflash/sdwan/etc/viptela
293 22 Jun 07 2023 13:21:02.0000000000 +00:00 /bootflash/sdwan/etc/viptela/uuid
294 1 Jun 07 2023 13:21:35.0000000000 +00:00 /bootflash/sdwan/etc/viptela/vdaemon_gen_id
295 2 Jun 05 2023 15:48:29.0000000000 +00:00 /bootflash/sdwan/etc/viptela/csr_index
296 4096 Jun 05 2023 15:48:31.0000000000 +00:00 /bootflash/vmanage-admin
297 4096 Jun 05 2023 15:48:31.0000000000 +00:00 /bootflash/vmanage-admin/.ssh
298 0 Jun 07 2023 13:21:03.0000000000 +00:00 /bootflash/vmanage-admin/.ssh/authorized_keys
299 11 Jun 07 2023 13:07:17.0000000000 +00:00 /bootflash/.reboot_time
5866835968 bytes available (498991104 bytes used)
In enable mode, please enter this command:
razeev rohilla
Hi Leo,
i am not found bootable IOS image in Router. So download image from Cisco and copy in flash. Which is work perfectly but after completing installation suddenly facing an error,  set boot variable also.
WARNING:
Boot variable either does not exist or buffer is too small
This may impact autoboot of the router. Proceed with caution
Do you wish to proceed with reload anyway[confirm]
Proceed with reload? [confirm]
*Jun 7 16:41:55.689: %IOSXE_RP_CFG_NOT-3-BOOT_VAR_NOT_SET: Either the boot variable does not exist or the buffer is too small.Keep it blank.
*Jun 7 16:41:58.021: %SYS-5-RELOAD: Reload requested by console. Reload Reason: Reload Command.Jun 7 16:42:05.296: %PMAN-5-EXITACTION: R0/0: pvp: Process manager is exiting: process exit with reload chassis code
Router(config)#$ flash bootflash:isr4300-universalk9.17.06.05.SPA.bin
Router(config)#boot system flash:isr4300-universalk9.17.06.05.SPA.bin
