Cisco router 3900 high CPU utilization
mjrosana02
Any idea regarding  the bug that we're hitting? CPU process is 99% and its causing a downtime on our network.
IOS version: c3900-universalk9-mz.SPA.152-3.T1.bin
#sh proc cpu sorted | ex 0.00
CPU utilization for five seconds: 99%/98%; one minute: 99%; five minutes: 99%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
2 23258444 6062854 3836 0.79% 1.22% 1.22% 0 Load Meter
106 248749408 120352429 2066 0.15% 0.14% 0.15% 0 Netclock Backgro
6 80266504 5803708 13830 0.07% 0.05% 0.05% 0 Check heaps
87 184062348 30403538 6053 0.07% 0.11% 0.13% 0 Per-Second Jobs
170 22762448 123575031 184 0.07% 0.05% 0.03% 0 IP Input
Thanks for you answers.
Tamurmur
Joseph W. Doherty
Might not be a bug.  You may have hit capacity/performance limit of your router.
What model 3900?
What's aggregate interfaces bandwidth (when CPU maxed out)?
Using any tunnels?
5 Replies 5
Mark Elsen
 - FYI : https://www.cisco.com/c/en/us/support/docs/routers/10000-series-routers/15095-highcpu.html
 M.
balaji.bandi
Look at the discussion we had some time back :
https://community.cisco.com/t5/routing/high-cpu-utilization/td-p/4157696
BB
I need to see cpu history
Joseph W. Doherty
What model 3900?
Using any tunnels?
Hi Seems you're right we tried to disable it temporarily the utilization went back to normal... .
Thanks everyone for your Help!
