Cisco router management over VPN
Piotr Kowalczyk
I’m trying to manage Cisco router (using internal interface) but not able to get access (even ping) -VPN is working ok. In ASA it was quite simple, just to use command: management-access inside but how to do this in router?
Thank you for advise
Edison Ortiz
No configuration is required.
Verify the internal interface configuration for ACL preventing access and/or IP subnet configuration.
Thank you for your reply.
I believe ACL doesn't prevent access as I can ping any host inside the network but not internal IP address of the Cisco router.
Could you post config please?
HTH,
Dragan
HTH,
Dragan
So you are trying to access the internal IP address via the VPN or via an internal host?
If so, it could be an issue of allowing that communication via the VPN.
Check the VPN ACL and make sure this flow matches.
