Cisco Router NAT transparency
AvidPontoon1
I have a firewall box that sits between the 'WAN' port on a cisco 2811 and the main ISP line in to my building. The topology looks like:
 ISP CONNECTION IN
UTM
CISCO ROUTER
My problem is logging on the UTM. It runs a dns filtering service that filters the network traffic for the site. Between the UTM and Router there is a class C subnet: 20.20.20.0/24. The utm has 20.20.20.1 and the router has 20.20.20.2. The cisco router has nat configured on it to allow 0.0.0.0. My problem is that when a client visits a blocked page the UTM logs this with the ip of the client. The problem I am having is that the client ip address is always 20.20.20.2 (The ip of the WAN on the router) and not the ip of the actual client.
How can i get the firewall to see the actual client ip? Ive ruled it down to NAT on the router but have no idea on how to configure it. Please could someone explain what I need to do?
33 Replies 33
that is because everything is being translated to 20.20.20.2. Change your NAT access list to:
access-list 10 deny 10.1.1.0 0.0.0.255
access-list 10 permit any
Still being translated to 20.20.20.2. But the interface that the UTM is connected to the router on is still 'ip nat outside' so thats stopping it i guess
Have you been able to add the static route for network 10.x.x.x to the pfsense ?
I only added 10.1.1.0/24 as I dont know the /xx value for 10.0.0.0.
I had the two commands wrong for the ip access-list and now the pfsense can ping 10.1.1.253 and it doesnt get translated to 20.20.20.2. But adding it has stopped one of my subnets from accessing the internet :/
So back to the original problem:
"My problem is that when a client visits a blocked page the UTM logs this with the ip of the client. The problem I am having is that the client ip address is always 20.20.20.2 (The ip of the WAN on the router) and not the ip of the actual client."
Which IP addresses are logged now by the UTM ?
I have enabled squid to have a better look and it still says 20.20.20.2 when it should be 10.63.12.1 on VLAN 203
Note: PFSENSE cannot ping 10.63.12.1
10.63.12.1 is not part of 10.1.1.0/24. The access list right now only blocks 10.1.1.0/24 from being translated.
Change it to:
access-list 10 deny 10.0.0.0 0.255.255.255
Change it to:
Adding that has now denied the whole internal network of internet access
"I only added 10.1.1.0/24 as I dont know the /xx value for 10.0.0.0."
Add 10.0.0.0/8 as the destination in the static route on the pfsense. This includes all networks in the 10.x.x.x range.
That has not helped as the command 'access-list 10 deny 10.0.0.0 0.255.255.255' denies everyone access to the UTM and therefore the internet.
Current config:
Current configuration : 1947 bytes
! Last configuration change at 19:48:22 UTC Sun Aug 26 2018 by admin
version 15.1
hostname v1.site.isr
boot-start-marker
boot system usbflash0:c1841-advipservicesk9-mz.151-4.M3.bin
boot-end-marker
no aaa new-model
ip source-route
no ip dhcp use vrf connected
ip cef
no ip domain lookup
ip domain name cisco.lab
license udi pid CISCO1841 sn FCZ09101223
interface FastEthernet0/1
ip address 10.1.1.253 255.255.255.0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface FastEthernet0/0/0
ip address dhcp
ip nat outside
duplex auto
speed auto
router ospf 100
router-id 10.1.1.253
passive-interface FastEthernet0/0/0
network 0.0.0.0 255.255.255.255 area 0
ip forward-protocol nd
ip http server
ip nat inside source list 10 interface FastEthernet0/0/0 overload
ip nat inside source static 10.0.0.0 0.255.255.255
ip route 0.0.0.0 0.0.0.0 20.20.20.1
ip access-list extended FILTER_VLAN30
permit ip 10.1.30.0 0.0.0.255 host 10.1.100.65
deny ip 10.1.30.0 0.0.0.255 10.1.0.0 0.0.255.255
permit ip any any
control-plane
bridge 1 protocol ieee
line con 0
line aux 0
line vty 0 4
login local
transport input telnet
scheduler allocate 20000 1000
end
have you added the static route for 10.0.0.0/8 pointing to 20.20.20.2 on the pfsense ?
See the screenshot in last post. In theory that route won't matter if no clients can access the UTM?
if 10.0.0.0/8 has been added to the pfsense, take all the NAT config off your router. At the very least, with the config below, all clients should be able to ping 20.20.20.1:
Current config:
version 15.1
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
no ip domain lookup
duplex auto
speed auto
ip address dhcp
duplex auto
speed auto
router ospf 100
ip http server
permit ip any any
control-plane
line con 0
line aux 0
line vty 0 4
login local
end
Current config:
version 15.1
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
no ip domain lookup
duplex auto
speed auto
ip address dhcp
duplex auto
speed auto
router ospf 100
ip http server
permit ip any any
control-plane
line con 0
line aux 0
line vty 0 4
login local
end
I have done that and can now ping 20.20.20.1 but no internet access
now check the NAT rules generated on the pfsense. Since you have added a static route for 10.0.0.0/8, that network should be included in an automatically generated rule:
https://www.netgate.com/docs/pfsense/nat/automatic-nat-rules-generation.html
