01-09-2007 08:40 AM - edited 03-03-2019 03:18 PM
It has been a while since I have used it. But thier was an IOS cmd where you could send a note to any users in the router. Does anyone know the command. I thought that it was cisco# speak and then the note but that doesn't seem to be working for me. Any help I will rate.
01-09-2007 08:53 AM
what platform are you using? do you mean a banner motd?
config t
(config)#banner motd # Use strictly prohibited #
Peter
01-09-2007 08:54 AM
Josh
You got the first letter right. Check out "send" instead of "speak". Send is used to send messages to other users on the router.
Rick
01-09-2007 08:55 AM
The command is "send"
01-09-2007 09:00 AM
Is it "send" which u r looking for???
Router#send ?
* All tty lines
<0-81> Send a message to a specific line
aux Auxiliary line
console Primary terminal line
qdm Send a message to QDM client
tty Terminal controller
vty Virtual terminal
Router#send *
Enter message, end with CTRL/Z; abort with CTRL/C:
hello ^Z
Send message? [confirm]
Router#
*** Message from tty0 to all terminals:
hello
Router#
If this is not what you are looking for , can you tell me what you meant by any users in the router??????
Pallavi
