CiscoSwitch 2950 alway root
rechard_david
Dear All,
I had Cisco Switch 2950 48port,when i turn on power it alway restart.how can i fix this problem?
i want to upload the new IOS but i don't how to upload.
Rechard
royalblues
Level 10
Level 10
Do you mean to say it goes into a restart loop?
It might be due to IOS corruption
you can use the break sequence and do a Xmodem recovery
http://www.cisco.com/en/US/products/hw/switches/ps628/products_tech_note09186a0080169696.shtml
Narayan
royalblues
Level 10
Level 10
Narayan
Dear Narayan,
Thank you for your support.
Best Regards,
Rechard
