Clear Reverse telnet to a remote host
m-geisler
The reverse telnet is a very powerfull tool, and when you want to connect to a remote host it is possible by just using the remote host ip-address. Nice.
My problem is how can I clear this line? Clear line <x> is not always helpful, especially if you have several lines active and don't know which line is the one to clear. (they all originate at the same IP address!)
Thanks for your help
Mike
devang_etcom
Level 7
Level 7
if you want to disable the telnet for any perticular line you can use the "transport input none" under the perticular line ...by this way you can disable the telnet...
rate this post if it helps
regards
Devang
Thanks for yout answer, but I want to connect to all hosts.Just from time to time one console port quits.
If the connection is local I can clear it with
" clear line 200x" or "clear line "
Unfortunatelly that doesn't work with the remote (vty) session.
Mike
Edison Ortiz
Type 'who' or 'show users'. It should list, in order, the sessions. If you want to disconnect session 1, type 'disconnect 1'.
