Conditional NAT based on NOT going to a specific destination
mikehallevms
Good day, Need a little assistance.
I need IP 192.168.1.1 to be nat’d to 100.1.1.2 for internet access when the destination is NOT 10.10.10.0/24(tunnel destination). Egress interface is the same. Can anyone provide an example of this?
much appreciated
6 Replies 6
pieterh
you can have multiple NAT statements using  the same egress interface.
use an access-list for "interesting traffic" for the VPN (maybe al ready present for NAT or noNAT to the VPN?)
permit traffic to the 10.10.10.0/24 destination
deny all other traffic
create another access-list
deny traffic to the 10.10.10.0/24 destination
permit 192.168.1.1 to any (or whatever but not 10.10.10.0/24)
use this access-list to nat 192.168.1.1 to 100.1.1.2
details can be found in this document
It would be a static nat. The IP’s I’ve given are just an example, not the actual ones. Thanks
Here is an example from another message on this forum: I assume this is what I would need, correct? Thanks all!
Re: Static NAT with exclusion
access-list 101 deny ip host 192.168.100.6 192.168.200.0 0.0.0.255
access-list 101 permit ip host 192.168.100.6 any
route-map transStatic permit 10
match ip address 101
ip nat inside source static 192.168.1.6 172.16.0.1 route-map transStatic
int x/x
ip nat inside
int x/y
ip nat outside
   Yes, use a route-map with the ACL, for static NAT you have to use a route-map, but in general, policy NAT can only work with route-maps.
   With your given example, 192.168.100.6 will get NAT'ed into 172.16.0.1 when accessing any destination except 192.168.200.0/24. For reverse session initiation, if you also want that all hosts except 192.168.200.0/24 to be allowed reaching 172.16.0.1/192.168.100.6, add the "reversible"  keyword at the end of your NAT statement.
Cristian Matei.
this sequence of commands you need for the NAT.
but you mentioned using a tunnel
if all 192.168.100.0/24 is normally sent through the tunnel, and you want to bypass the tunnel for traffic from 192.168.100.6
you need to adjust the ACL that is used for the tunnel traffic
Cristian Matei
 Can you post your current NAT config, so we can work based on that? It's not clear if you want a static NAT for 192.168.1.1 or dynamic NAT or PAT?
Cristian Matei.
