I have a CISCO 2921 router with a 24 port switch module. Everything has been configured and working excepte the following, please help!!
VLAN1: 10.10.10.x, default network for Router GI 0/0, which has IP 10.10.10.1
VLAN2: 10.10.9.x subnet for development
Connection: router GI 0/0 is connected to SW port 17, my laptop is connected to SW port 16 with IP 10.10.9.22. VLAN setting for port 17 is: VLAN1; VLAN setting for port 16 is: VLAN2.
Issue I am having: From my laptop, I can ping 10.10.10.1, but I can't do http://10.10.10.1
What did I miss? Thanks.
Solved! Go to Solution.
Coul you add this and try accessing your router from the 10.0.9.0/24 subnet?
access-list 23 permit ip 10.0.9.0 0.0.0.255
Hi Bin,
You need to enable http server on your router by doing the below:
ip http server
ip http authentication local (you will need to create a username for access)
username (xxxxxx) secret (password)
You can also enable https by typing ip http secure-server
HTH.
Terence
Hi, Terence,
I have eveything you listed above. But I simply can't access https://10.10.10.1, therefore I can't run CISCO CP.
Help.
Then you have other configuration misatkes.
Note however, Cisco CP is pretty useless.
The original post establishes that there is IP connectivity from the laptop to the router address. If https access does not work then I must agree with Paolo that there is some other issue in the configuration. A good next step would be for the original poster to post the configuration of the router so that we can identify what is the other issue.
Rick
Hi Bin,
Does CCP prompts you for a username/password? Make sure you've got a username with privilege 15 configured.
username USERNAME privilege 15 secret PASSWORD
If this still doesn't work, kindly post your show run as Rick suggested and remove any sensitive info.
Hi, eveyone, thank you for taking time to respond to my post. Here is my config, please refer to Original post for connection INFO.
What I need help with:
1: be able to access manage C2921 from 10.0.9 network or
2: once connected to VPN, be able to access and manage C2921.
hostname C2921W
boot-start-marker
boot-end-marker
card type t1 0 0
logging buffered 51200 warnings
enable secret 4 SECRET
aaa new-model
aaa authentication login rtr-remote-list local
aaa authorization network rtr-remote-list local
aaa session-id common
clock timezone EST -5 0
clock summer-time EDT recurring
network-clock-participate wic 0
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 10.0.9.241 10.0.9.254
ip dhcp excluded-address 10.0.9.1 10.0.9.21
ip dhcp pool P-VLAN10
import all
network 10.0.9.0 255.255.255.0
default-router 10.0.9.254
dns-server 10.0.2.22
domain-name example.net
lease 10
ip domain name example.net
ip name-server 12.12.12.67
ip name-server 12.12.12.71
ip inspect log drop-pkt
ip inspect name CCP_HIGH appfw CCP_HIGH
ip inspect name CCP_HIGH icmp
ip inspect name CCP_HIGH dns
ip inspect name CCP_HIGH esmtp
ip inspect name CCP_HIGH https
ip inspect name CCP_HIGH imap reset
ip inspect name CCP_HIGH pop3 reset
ip inspect name CCP_HIGH sip
ip inspect name CCP_HIGH h323
ip inspect name CCP_HIGH tcp
ip inspect name CCP_HIGH udp
appfw policy-name CCP_HIGH
application im aol
service default action reset alarm
service text-chat action reset alarm
server deny name login.oscar.aol.com
server deny name toc.oscar.aol.com
server deny name oam-d09a.blue.aol.com
audit-trail on
application im msn
server deny name messenger.hotmail.com
server deny name gateway.messenger.hotmail.com
server deny name webmessenger.msn.com
audit-trail on
application http
strict-http action reset alarm
port-misuse im action reset alarm
port-misuse p2p action reset alarm
port-misuse tunneling action reset alarm
application im yahoo
server deny name scs.msg.yahoo.com
server deny name scsa.msg.yahoo.com
server deny name scsb.msg.yahoo.com
server deny name scsc.msg.yahoo.com
server deny name scsd.msg.yahoo.com
server deny name cs16.msg.dcn.yahoo.com
server deny name cs19.msg.dcn.yahoo.com
server deny name cs42.msg.dcn.yahoo.com
server deny name cs53.msg.dcn.yahoo.com
server deny name cs54.msg.dcn.yahoo.com
server deny name ads1.vip.scd.yahoo.com
server deny name radio1.launch.vip.dal.yahoo.com
server deny name in1.msg.vip.re2.yahoo.com
server deny name data1.my.vip.sc5.yahoo.com
server deny name address1.pim.vip.mud.yahoo.com
server deny name edit.messenger.yahoo.com
server deny name messenger.yahoo.com
server deny name http.pager.yahoo.com
server deny name privacy.yahoo.com
server deny name csa.yahoo.com
server deny name csb.yahoo.com
server deny name csc.yahoo.com
audit-trail on
parameter-map type inspect global
log dropped-packets enable
crypto pki trustpoint TP-self-signed-1375906681
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1375906681
revocation-check none
rsakeypair TP-self-signed-1375906681
hw-module sm 1
username admin privilege 15 secret 4 PASSWORD
username rwadmin password 0 CLIENTKEY
redundancy
controller T1 0/0/0
fdl both
cablelength long 0db
channel-group 0 timeslots 1-24
controller T1 0/0/1
fdl both
controller T1 0/0/2
fdl both
controller T1 0/0/3
fdl both
class-map match-any sdm_p2p_kazaa
match protocol fasttrack
match protocol kazaa2
class-map match-any sdm_p2p_edonkey
match protocol edonkey
class-map match-any sdm_p2p_gnutella
match protocol gnutella
class-map match-any sdm_p2p_bittorrent
match protocol bittorrent
policy-map sdmappfwp2p_CCP_HIGH
class sdm_p2p_edonkey
drop
class sdm_p2p_gnutella
drop
class sdm_p2p_kazaa
drop
class sdm_p2p_bittorrent
drop
crypto isakmp policy 5
encr 3des
authentication pre-share
group 2
crypto isakmp key ISAKMPKEY address 19.19.18.71 no-xauth
crypto isakmp key ISAKMPKEY address 29.29.28.68 no-xauth
crypto isakmp keepalive 10
crypto isakmp client configuration group rtr-remote-list
key CLIENTKEY
domain example.net
pool ippool
acl 102
crypto ipsec transform-set 3des-sha esp-3des esp-sha-hmac
crypto dynamic-map dynmap 10
set transform-set 3des-sha
reverse-route
crypto map outsidemap client authentication list rtr-remote-list
crypto map outsidemap isakmp authorization list rtr-remote-list
crypto map outsidemap client configuration address respond
crypto map outsidemap 1 ipsec-isakmp
set peer 19.19.18.71
match address outside_cryptomap
crypto map outsidemap 2 ipsec-isakmp
set peer 29.29.28.68
set security-association lifetime seconds 28800
match address outside_cryptomap_dil
crypto map outsidemap 10 ipsec-isakmp dynamic dynmap
interface Multilink1
ip address 12.12.13.94 255.255.255.252
ip nat outside
ip inspect CCP_HIGH out
ip virtual-reassembly in
ppp multilink
ppp multilink group 1
ppp multilink fragment disable
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 10.10.10.1 255.255.255.248
ip nat inside
duplex auto
speed auto
interface GigabitEthernet0/1
description $FW_OUTSIDE$
ip address 12.12.15.145 255.255.255.248
ip access-group 101 in
ip nat outside
ip verify unicast reverse-path
duplex auto
speed auto
service-policy input sdmappfwp2p_CCP_HIGH
service-policy output sdmappfwp2p_CCP_HIGH
interface GigabitEthernet0/2
description $ES_LAN$
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:0
description multilink 1 interface
no ip address
encapsulation ppp
ppp multilink
interface Serial0/0/1:0
no ip address
encapsulation ppp
ppp multilink
interface Serial0/0/2:0
no ip address
interface Serial0/0/3:0
no ip address
interface GigabitEthernet1/0
description $ETH-LAN$$SWDMADDR:192.168.1.245:80$$FW_INSIDE$
ip address 10.0.9.254 255.255.255.0
ip access-group 100 in
ip nat inside
interface GigabitEthernet1/1
description Internal switch interface connected to EtherSwitch Service Module
no ip address
interface Vlan1
no ip address
ip local pool ippool 10.0.10.30 10.0.10.40
ip forward-protocol nd
ip http server
ip http access-class 23
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list inside_nat0_outbound interface Multilink1 overload
ip route 0.0.0.0 0.0.0.0 12.12.13.93
ip access-list extended inside_nat0_outbound
deny ip 10.0.9.0 0.0.0.255 10.0.2.0 0.0.0.255
deny ip 10.0.9.0 0.0.0.255 10.0.6.0 0.0.0.255
deny ip 10.0.9.0 0.0.0.255 10.0.4.0 0.0.0.255
permit ip 10.0.9.0 0.0.0.255 any
deny ip 10.10.10.0 0.0.0.255 10.0.10.0 0.0.0.255
permit ip 10.0.10.0 0.0.0.255 any
permit ip any any
ip access-list extended outside_cryptomap
permit ip 10.0.9.0 0.0.0.255 10.0.2.0 0.0.0.255
permit ip 10.0.9.0 0.0.0.255 10.0.4.0 0.0.0.255
ip access-list extended outside_cryptomap_dil
permit ip 10.0.9.0 0.0.0.255 10.0.6.0 0.0.0.255
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 100 remark auto generated by CCP firewall configuration
access-list 100 remark CCP_ACL Category=1
access-list 100 permit ip 12.12.15.144 0.0.0.7 any
access-list 100 deny ip host 255.255.255.255 any
access-list 100 deny ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by CCP firewall configuration
access-list 101 remark CCP_ACL Category=1
access-list 101 permit ip 10.0.9.0 0.0.0.255 any
access-list 101 permit icmp any host 12.12.15.145 echo-reply
access-list 101 permit icmp any host 12.12.15.145 time-exceeded
access-list 101 permit icmp any host 12.12.15.145 unreachable
access-list 101 deny ip 10.0.0.0 0.255.255.255 any
access-list 101 deny ip 172.16.0.0 0.15.255.255 any
access-list 101 deny ip 192.168.0.0 0.0.255.255 any
access-list 101 deny ip 127.0.0.0 0.255.255.255 any
access-list 101 deny ip host 255.255.255.255 any
access-list 101 deny ip host 0.0.0.0 any
access-list 101 deny ip any any log
access-list 102 permit ip 10.10.10.0 0.0.0.248 10.0.10.0 0.0.0.255
control-plane
line con 0
exec-timeout 0 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 67
no exec
transport input all
stopbits 1
flowcontrol software
line vty 0 4
access-class 23 in
privilege level 15
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
scheduler allocate 20000 1000
end
I believe that John has correctly identified the issue. To give some supporting detail about it, this line of the config is the key:
This uses access-list 23 to control who can use the web interface to access the router. And access-list 23 only permits a small part of a subnet. Note that this looks like the access-list that is part of the standard initial configuration of an IOS router. And note that this access list is also controlling who can get remote access for the command line also
line vty 0 4
access-class 23 in
So if you add 10.0.9 as a permit in access-list 23 the http/https should work.
Rick
Thank you John / Richard. With this access-list, my first problem was resolved: that is to be able to access the router from 10.0.9 network.
My second problem is this: once I connect to the Router with CISCO VPN client, I got an IP address 10.0.10.30, with mask: 255.0.0.0. I am not able to access the router. What else do I need to do?
I am glad that our suggestion about modifying the access list has resolved the first problem. The solution to the second problem is quite similar. You need to modify access list 23 and add an entry that will include a permit for an address range that includes the VPN addresses.
Do you have access to the device that is providing the VPN and can you determine what range of addresses in the the VPN pool? That is the range that you need to permit in the access list.
Rick
Rick, yes, the range is in the above config file that I posted earlier. I added access list 23 for 10.0.10, but no luck.
When I connect to VPN, my subnet mask should be 255.255.255.0, right? But is is 255.0.0.0. So I think something is not right.
I followed CISCO documentation and example to setup the VPN access.
Perhaps you can post the current version of access list 23? I am guessing that there is something about the way that you did the permit for 10.0.10.
I can see where you intend the mask for VPN to be 255.255.255.0. But I do not see anywhere that you specify this in the VPN config. Have I missed something?
Rick
Hi Bin,
Are you referring to Easy VPN server setup on the router? By the way, I've got your email but I will be responding here on this thread. This will help other folks keep track and assist in resolving your issue if I'm not available.
Please help rate useful posts. Thanks!
John,
Yes, this is Easy VPN server setup on the router. Please refer to the router configuration above.
I added the following access list:
access-list 23 permit ip 10.0.10.0 0.0.0.255
But, no luck this time. The purpose of this exercise is that I can VPN in to the router, and then SSH to the router management interface.
