12-14-2006 04:49 AM - edited 03-03-2019 03:02 PM
I have this Controller Card. When i write
Router(config)#controller dsl 0/0
i only see many configuration commands. Like description. But these are not enough to configure it. My router model is Cisco 1760. How and where i can configure this card.
Thanks for your help.
Solved! Go to Solution.
12-14-2006 05:01 AM
Once you have configured controller dsl, then you can configure the interface atm. Here you are the guide:
Hope this helps
12-14-2006 05:01 AM
Hope this helps
12-14-2006 05:04 AM
Can you post the output of show version and show diag commands ??
regds
