Configure License for router ASR 1001-X
Goode morning,
I wanted to know how to install license XXXX.lic for Cisco router ASR 1001-X
Configuration syntax, the command needed to install license
Is there a detail guide for asr router
what if you copy the license file to your flash or bootflash first and then install it from there ?
router# license install (boot)flash: XXXXXXXX.lic
5 Replies 5
hello ,
I try to add file license in my router cisco ASR 1001-x and not worked
this my syntax in my router asr:
router# license install tftp://C:/Users/Omar/Desktop/Company/License-ASR/XXXXXXXX.lic
He show me error:
Error: license installed failed with timeout
that is not the correct syntax of TFTP
tftp://ipaddress/
here is TFTP config :
https://techzain.com/how-to-setup-tftp-server-tftpd64-tfptd32-windows/
BB
