Configuring FTP on local IP Address
dhavaltandel
Hi Netpros,
I wanted to configure FTP server on private Ip Address Range as 192.xx.xx.xx/24. I do have one public IP.
So i wanted to forward the FTP request for port number 21 on that perticular Private Ip Address which is already configured with FTP Server and working fine locally.
Ii have Cisco 2621 with IOS 12.1
can any budy has the solution or provide me any link to resolve this issue.
Dhaval Tandel
and dhaval you can use same thing for port 80 for website
rate this post if it helps
regards
Devang
18 Replies 18
Edison Ortiz
interface f0/0
description internal network
ip address 192.168.1.1 255.255.0
ip nat inside
interface fa0/1
description outside network
ip address 69.255.255.255 255.255.255.252
ip nat outside
ip nat inside source static tcp [local ip] 21 interface fa0/1 21
Thanks for taking interest..
I did try by above config but its not working i also do same for port number 80 but no any luck.....is there any thing else to do with this configuration...?
Dhaval Tandel
Can you post your config ?
Current configuration : 1997 bytes
version 12.1
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname IndiaVoiceRouter
logging buffered 16000 debugging
enable secret xxx
ip subnet-zero
ip host voicerouter 192.168.1.100
ip name-server 202.xx.xx.xx
ip dhcp database tftp://192.168.1.13/dhcp-lease
ip dhcp excluded-address 192.168.1.100
ip dhcp pool 192.168.1.0/24
network 192.168.1.0 255.255.255.0
default-router 192.168.1.100
dns-server 202.xx.xx.xx 202.xx.xx.xx
lease 333
interface FastEthernet0/0
ip address 61.xx.xx.xx 255.255.255.0
no ip redirects
ip nat outside
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.1.100 255.255.255.0
ip nat inside
duplex auto
speed auto
ip default-gateway 61.xx.xx.xx
ip nat pool dhara 61.xx.xx.xx 61.xx.xx.xx netmask 255.255.255.0
ip nat inside source list 3 pool dhara overload
ip nat inside source static tcp 192.168.1.11 80 interface FastEthernet0/0 80
ip nat inside source static tcp 192.168.1.11 21 interface FastEthernet0/0 21
ip classless
ip route 0.0.0.0 0.0.0.0 61.xx.xx.xx
no ip http server
logging 192.168.1.13
access-list 3 permit 192.168.1.0 0.0.0.255
access-list 121 permit tcp any any range ftp-data ftp
access-list 121 permit tcp any any eq www
line con 0
line aux 0
line vty 0 4
password xxx
login
end
IndiaVoiceRouter#
HI
Additionally both the ACL-121 has been removed now....
Dhaval Tandel
Any Luck...?
Can you turn a debug ip nat and see if the address is getting translated ?
Also, since you have a pool of public IPs, why don't you take a public IP from the pool and do a static assignment instead of using the Fa0/0 interface ?
HI
Thnaks fo rtakin interest...
I did replace with public ip instade of fa0/0.
my debug is on bu i cant see any messages on terminal...
am not getting this...
Dhaval Tandel
You won't see the messages on terminal unless you typed 'term mon'. You should be able to see the message in the log by typing 'show log'.
The command is
#debug ip nat detailed
dhaval add only extendable keyword
ip nat inside source static tcp localIP 21 globalIP address 21 extendable
and let me know it works or not
please rate this post if it helps
regards
Devang
rajinikanth
Level 3
Level 3
Hi dhaval,
use this command
ip nat service list ftp tcp command.
Note:The access list address in the above command must match the inside local IP address for the FTP server .
access-list 10 permit 192.168.1.11
ip nat service list 10 ftp tcp port 21
ip nat inside source static 192.168.1.11 interface FastEthernet0/0
Tell me if it worked
Raj
HI, RAJ
Thasks but no any luck yet...
i think you saw my last post for statics can you recognise why that...?
Dhaval Tandel
Dhaval,
Can we see the #debug ip nat detailed
output ?
regards
Devang
