Configuring FTP on local IP Address
dhavaltandel
Hi Netpros,
I wanted to configure FTP server on private Ip Address Range as 192.xx.xx.xx/24. I do have one public IP.
So i wanted to forward the FTP request for port number 21 on that perticular Private Ip Address which is already configured with FTP Server and working fine locally.
Ii have Cisco 2621 with IOS 12.1
can any budy has the solution or provide me any link to resolve this issue.
Dhaval Tandel
18 Replies 18
i got resolve my issue and thaks for takin interest...
Dhaval Tandel
I now my 21 port is workin but i cant use port number 80 using same command....
is there any additional thing required...
Dhaval Tandel
Port 80 active on 192.168.1.11 ?
Can you access port 80 to this device internally ?
Can you post the config with the new changes ?
dhaval again make sure your static natting must be perfect with port 80 and tcp and dont forgot to use extendable...
because i have configured same thing for my home also...
rate this post if it helps
regards
Devang
