Configuring Netflow on a 7304
c.walsh
Level 3
Level 3
Customer requests netflow to be configured on a POS i/f on a 7304. The "ip route-cache flow" command has been remapped to the "ip flow ingress" command. Can netflow be configured in both directions on the interface by adding the "ip flow egress" command, or can it be configured in one direction only ?
spremkumar
Level 9
Level 9
Hi Walsh
You can configure it on both the directions using ingress/egress keywords..
Also do refer the below link for more info on the same..
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124tcr/tnf_r/nfl_a1ht.htm#wp1440361
regds
