02-11-2007 06:13 PM - edited 03-03-2019 03:42 PM
I have two 2851 routers with VWIC2-2MFT-T1/E1 cards. before deploying them on field,I want to simulate E1 links at the lab. there are regular rj45 ports on E1 cards.
Can I connect routers back-to-back using E1 modules (if ethernet cable would do the job,how should I terminate pins on RJ 45 connectors?)
tx in advance for any help
Solved! Go to Solution.
02-11-2007 10:41 PM
yes, you can.
You just need E1 crossover cable.
http://www.cisco.com/univercd/cc/td/doc/product/access/multicon/3810hwig/3810cabl.htm#15724
http://www.chebucto.ns.ca/Chebucto/Technical/Manuals/Max/max6000/gs/cables.htm#21066
hope this helps,
Alexander
02-11-2007 10:41 PM
yes, you can.
hope this helps,
Alexander
02-12-2007 01:52 AM
hi alexnder tx you gave me just what i was looking for
tx buddy
02-12-2007 01:47 AM
You need an E1 cross cable which you need to manually crimp.
Router 1 Router 2
Pin 1 connects to Pin 4
Pin 2 connects to Pin 5
Pin 4 connects to Pin 1
Pin 5 connects to Pin 2
HTH and rate helpful posts.
Br,
Mike
