Connection rate-limit
Machi Ma
I would like to check is it possible to using accesslist rate-limit to limit each services per number of times connection in period.  Example 5/sec ?
As I found it seems used for limit the bandwidth use.
Shelley Bhalla
Level 3
Level 3
Access list will only match on port numbers and ip's. There is no mechanism where we can identifty the # of connections per ip. There are devices that can do it (like a Cisco SCE) but not a router or QoS.
If this answers your question, Please mark thread comeplete.
Shelley
Cisco TAC
