Create VLAN 1000
CSCO10320953
Hi ,
In Existing switch i am unable to find running configuration of  the vlan number 1000.but sh vlan and sh vlan brief its showing active and some port are assinged.other than VLAN 1000 ,all inteface vlan configuration and l2 vlan name I am able to see same switch,ie switch is server mode....What would be
problem or how to see  vlan 1000.Pl help out...
Thanks..
9 Replies 9
Leo Laohoo
You can't use VLAN 1000 to 1005.  It's reserved.
Leo,
Are you sure about this? There are 5 reserved VLANs: 1, 1002-1005. VLAN 1000 in particular should be usable.
Best regards,
Peter
Mea culpa.  You're right.  VLAN 1000 is usable.
Leo,
Never mind - those pesky details are best for certification exams, anyway...
To the author of the original post: can you please post the complete show running-config (without sensitive information, of course), plus the output of show vlan brief and show vtp status?
Best regards,
Peter
I wonder what model is the switch.
johnlloyd_13
Level 9
Level 9
hi,
you can only see the configured VLANs in show run if switch's VTP mode is set to transparent.
Switch#sh run
Building configuration...
Current configuration : 1121 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Switch
vtp domain cisco1
vtp mode transparent
vlan 10
name ENG
vlan 20
name MRK
vlan 30
name IT
vlan 1000
Vlan 1000 May be created in VTP database .....
I thought you're asking how to see vlans in show run. Or did I just misunderstood you?
This is why I'm asking what is the model of your switch.  2900XL/3500XL switches and early IOS of the 2940/2950/2955 use VLAN Database to create VLANs.  Later IOS for the 2940/2950/2955 can do both.
If your switch model is newer then the only minimum "configuration" you'll see in the running/startup config is "vlan 1000" and that's it.
