Bookmark
Subscribe
4759
d* Route on show route (Cisco ASA)
santiago.jem
Hi Experts,
I'm a bit confused on why, when I issue a "show route" command on my Cisco 5510 ASA the default route shows:      d*
Please see below for the output.
There seem to be no small letter "d" in the codes below.
Why am I getting this kind of default route?
Result of the command: "sh route"
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
       * - candidate default, U - per-user static route, o - ODR
       P - periodic downloaded static route
Gateway of last resort is x.x.x. to network 0.0.0.0
C    a.a.a.a 255.255.255.0 is directly connected, inside
C    y.y.y.y 255.255.255.248 is directly connected, outside
d*   0.0.0.0 0.0.0.0 [1/0] via x.x.x.x, outside
2 Accepted Solutions
pompeychimes
Level 4
Level 4
Is it not the default route being received via DHCP on your WAN interface?
cadet alain
I think this is a default route learned via DHCP with ip address dhcp setroute command.
Regards.
Alain
6 Replies 6
pompeychimes
Level 4
Level 4
cadet alain
Regards.
Alain
Alain, Pompey,
Thank you for the reply. That clears my confusion.
May I know if this d* route is given priority over S*?
Jemel
i think S* has priority .
thanks
I don't think so as these are both static routes with an AD of 1.
Regards.
Alain
Hi Alain,
I also thought it would be the same because both have an AD of 1.
If so, what would be the best practice, if I have 2 routes going to the internet?
Interface1 - is learned via DHCP from ISP, the other  interface2 - PPPoE from ISP?
Should I enable set-route on both interfaces?
Or should I only enable it on the active interface that's is forwarding the traffic?
Thank you.
Jemel
