Debug ip packet IP: Output changed by feature=23:
danhed7400
hi.
has anyone seen this before, i want to debug web traffic from a host.
i have create an ACL "access-list 2010 permit tcp host 192.168.80.51 any eq www" then i did a debug ip packet 2010 detail.
and then this spams the console.
.Feb  9 13:10:46.248: IP: Output changed by feature=23: FastEthernet4 -> Vlan80 .Feb  9 13:10:46.256: IP: Output changed by feature=23: FastEthernet4 -> Vlan80 .Feb  9 13:10:46.304: IP: Output changed by feature=23: FastEthernet4 -> Vlan80 .Feb  9 13:10:46.304: IP: Output changed by feature=23: FastEthernet4 -> Vlan80 .Feb  9 13:10:46.304: IP: Output changed by feature=23: FastEthernet4 -> Vlan80 .Feb  9 13:10:46.304: IP: Output changed by feature=23: FastEthernet4 -> Vlan80 .Feb  9 13:10:46.368: IP: Output changed by feature=23: FastEthernet4 -> Vlan80 .Feb  9 13:10:46.384: IP: Output changed by feature=23: FastEthernet4 -> Vlan80
i have disable CEF and Fast Switching, on this small 800 series router.
im using NAT (NVI) on this router could i have anything to do with that ?
mahmoodmkl
Level 7
Level 7
it seems the issue is with the nat config
Jeff Van Houten
Level 5
Level 5
iOS has a complete packet capture facility that creates pcap files now if you have the correct version.
