How to configure etherchannel between c3560 and c2948G-GE-TX switches
Bienvenu Ngala
Hi everyone,
I really need help, on my study lab I have got 2 switches a c3560 running IOS and a c2948g-ge-tx running CatOS. Both switches
has SFP ports, I would like to configure etherchannel between them switches using 2 SFP ports on each switch.
my question is if such configuration is possible and how to configure etherchannel so that VLANS can travel between both switches running different operating system. I have tried but it's no working, Please help.
Best regards.
2 Accepted Solutions
Reza Sharifi
Can you post configs from both devices?
Hello Bienvenu,
your config on both switches look okay apart from the two ports which are assined to port-channel 15 on the 2900 which assinged to vlan 60 and the port level high with no specified speed.
set vlan 60   2/49-50
set port level      2/49-50  high
try and remove these port from this vlan and change the port level and speed and then try reconnection,
clear vlan 60
set port level      2/49-50  normal
set port speed      2/1-48 auto
res
Paul
Please don't forget to rate this post if it has been helpful.
Kind Regards
Paul
5 Replies 5
Reza Sharifi
Hi R. Sharifi,
Sorry for my late response please find attached configs for both devices.
Best regards,
BEN
Dear R. Sharifi,
I hope you are well.
I am still waiting for your help, since I post the configs for both devices I am not hearing from you that is why I would like to remind you that I am still waitng. My apology if you are busy with other preoccupations.
I look forward to.
Best regards,
BEN
Bienvenu Ngala
Both switches configs
Hello Bienvenu,
set vlan 60   2/49-50
clear vlan 60
res
Paul
Kind Regards
Paul
