DHCP Binding in IOS: Entries under DHCP client-id/hardware address
gongya001
DHCP-Server
ip dhcp pool client-id
 host 172.16.1.200 255.255.255.0
 client-identifier 01aa.bbcc.0030.00
DHCP-Client-2
interface Ethernet0/0
 ip address dhcp client-id Ethernet0/0 hostname DHCP-Client-2
DHCP-Client-2(config-if)#do show int e0/0 | i bia
  Hardware is AmdP2, address is aabb.cc00.3000 (bia aabb.cc00.3000)
On DHCP-Server debug *Oct 13 09:45:42.249: DHCPD: DHCPREQUEST received from client 0063.6973.636f.2d61.6162.622e.6363.3030.2e33.3030.302d.4574.302f.30.
From the wireshark, I got the following;
Why does client-id not use MAC ?
The client just receives IP from pool instead of statically configured. If I use long client-id, it works, but not for the client-id I configured on the client.
thanks !!
try:
hardware-address 01aa.bbcc.0030.00
It does not work.
I am not sure whether because of different versions.
for version 15.5, it does not work.
for version 12.4, it works.
I noticed client-id from DHCP clients are different.
version 15.5
version 12.4
Not sure whether the client needs to be configured in a different way.
thanks !!
Hello
It looks like on your dhcp server the static pool is named “client-Id”
But on the dhcp client interface you have specified client-id2?
Kind Regards
Paul
DHCP-Client-2 is hostname. Client-id is the interface.
 ip address dhcp client-id e 0/0 hostname DHCP-Client-2
thanks !!
