Dial is successful, but PCs can not access internet
miaozhixu
Cisco 1941-sec-k9, with EHWIC-D-8ESG.
running-config as follow:
Current configuration : 4866 bytes
! Last configuration change at 02:24:32 UTC Sun Jul 6 2014 by miaozhixu
version 15.2
hostname SkyHomeRouter
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
ip cef
ip domain name yourdomain.com
ip name-server 202.96.128.166
ip name-server 202.96.128.86
no ipv6 cef
crypto pki trustpoint TP-self-signed-3419031012
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-3419031012
 revocation-check none
 rsakeypair TP-self-signed-3419031012
crypto pki certificate chain TP-self-signed-3419031012
 certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  0D7EB119 DEC27469 10F29A9D E6BC9692 C995985B 627B4CC4 637DCF85 7DCA6B2A
  DF64FE1C C9A134AD 2FD98208 D7017E
      quit
license udi pid CISCO1941/K9 sn FGL1723205C
redundancy
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description PPPoE Dialer Interface
 ip address 192.168.0.1 255.255.255.0
 duplex auto
 speed auto
 pppoe enable group global
 pppoe-client dial-pool-number 1
 no mop enabled
interface GigabitEthernet0/1
 description Management Interface
 duplex auto
 speed auto
interface GigabitEthernet0/1/0
 switchport access vlan 102
 no ip address
interface GigabitEthernet0/1/1
 no ip address
interface GigabitEthernet0/1/2
 no ip address
interface GigabitEthernet0/1/3
 no ip address
interface GigabitEthernet0/1/4
 switchport access vlan 103
 no ip address
interface GigabitEthernet0/1/5
 no ip address
interface GigabitEthernet0/1/6
 no ip address
interface GigabitEthernet0/1/7
 no ip address
interface Vlan1
 no ip address
interface Vlan102
 description Floor 2 VLAN
 ip address 192.168.2.1 255.255.255.0
interface Vlan103
 description Floor 3 VLAN
 ip address 192.168.3.1 255.255.255.0
interface Dialer1
 ip address negotiated
 ip nat outside
 ip virtual-reassembly in
 encapsulation ppp
 dialer pool 1
 dialer-group 1
  ppp pap sent-username (username) password 0 (password)
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
ip dns spoofing
ip nat inside source list 1 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 5 permit 192.168.3.254
dialer-list 1 protocol ip permit
control-plane
line con 0
 login local
 length 50
 width 190
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 access-class 5 in
 exec-timeout 60 0
 privilege level 0
 lockable
 login local
 no domain-lookup
 exec prompt timestamp
 length 45
 width 100
 full-help
 transport input ssh
scheduler allocate 20000 1000
end
On the router, I can access the internet.
my PC's ip is 192.168.3.3, gateway is 192.168.3.1. On my PC, I can ping 192.168.0.1,192.168.2.1, even another PC's ip 192.168.2.3. But I can not access internet, I can only access LAN.
5 Replies 5
cco4mike1
I can see the "ip nat inside" statement on your outside interface, however I see no "ip nat inside" statement on your inside interface.  ie Gig0/1
sorry, I meant
I can see the "IP NAT OUTSIDE" statement on your outside interface, however I see no "IP NAT INSIDE" statement on your inside interface.  ie Gig0/1
I have added the "ip nat inside" statement to Gigabitethernet 0/1, VLAN102, VLAN103, but it still not work.
Following is "ping www.baidu.com"; on router and PC.
SkyHomeRouter#ping www.baidu.com
Sending 5, 100-byte ICMP Echos to 180.97.33.71, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 32/32/32 ms
MacBookPro:~ miaozhixu$ ping www.baidu.com
PING www.a.shifen.com (180.97.33.71): 56 data bytes
Request timeout for icmp_seq 0
Request timeout for icmp_seq 1
^C
--- www.a.shifen.com ping statistics ---
3 packets transmitted, 0 packets received, 100.0% packet loss
cco4mike1
Ok, I can see you'll need more-
interface Vlan102
ip nat inside
interface Vlan103
ip nat inside
then
remove this-
ie . no access-list 5 permit 192.168.3.254
then -
add this
access-list 1 permit 192.168.0.0 0.0.7.255
remember the source list '1' in the PAT statement below relates to access list 1  (not 5)
try this first---and do you intend to use DHCP?
Yeah, it works. Thanks!
And I found that "Configuring Network Address Translation: Getting Started" helpful.
DHCP, yes, next step is configuring DHCP on Gig0/1 VLAN102 VLAN 103.
