07-02-2014 09:22 PM - edited 03-05-2019 06:52 AM
Platform Cisco 1941, Interface Card EHWIC-D-8ESG
After these commands issued, I immediately configure the interface on EHWIC-D-8ESG,using the following commands.
But, IOS replied that Could not found the access vlan, creating vlan 2.
And, show ip int bri shows that the vlan 2 is shutdown.
Any help will be appreciated.
Solved! Go to Solution.
07-04-2014 05:05 PM
Could you please post the output of "show vlan brief " or " show vlan-switch brief ". Did you create a Layer 2 interface. Please issue the command " vlan 2 " under config mode as that would create a Layer 2 vlan in the vlan database.
conf t
vlan 2
exit
HK
07-05-2014 01:14 AM
Hi Friend,
Debugging :-
1) when interface vlan is showing shutdown then check if physical interface to which acces vlan is configured is up or not.
now do no shut on interface vlan and check.
07-04-2014 05:05 PM
conf t
vlan 2
exit
HK
07-06-2014 09:58 AM
To define a VLAN, not only use interface vlan command to configure it, but also need a vlan command to create it first?
07-05-2014 01:14 AM
Hi Friend,
Debugging :-
07-06-2014 07:55 AM
I just know that. I thought that vlan and ethernet interfaces are independent.
07-06-2014 07:55 AM
Vlan depends upon your port status otherwise traffic will not be allowed.
yes
07-06-2014 09:56 AM
Yes, when the port status changed, it also change the vlan status, but it has a 2-3 seconds delay.
07-05-2014 04:43 AM
this message comes, when a vlan does not exit in database.
