Does this 2851 can give lots of RAM memory? How about flash?
news2010a
Level 3
Level 3
I am not sure on whether the 2851 below comes with 256MB or 1GB of RAM? That
WAAS module has 1GB, but is that considered somehow a complement to RAM memory?
I want to make sure I will order a router robust and which can sustant IOS
versions for year to come.
Please suggest the amount of RAM and flash memory people are ordering
to make sure I buy a scalable router.
1 CISCO2851-SEC/K9 2851 Security Bundle,Adv Security,64F/256D 1
2 CAB-AC Power Cord,110V 1
3 S28NUASK9B-12409T Cisco 2800 ASK9-AISK9 FEAT SET FACTORY UPG FOR BUNDLES 1
4 NME-WAE-502-K9 WAAS Network Module For 2800, 3800 ISR - 1GB RAM, 120GB HDD 1
5 SF-WAAS-4.0-NM-K9 Cisco WAAS 4.0 NM SW image (separate license required) 1
6 WAAS-ENT-NM Cisco WAAS Enterprise License for 1 NME-WAE-502-K9 1
7 WIC-1DSU-T1-V2 Updated 1-Port T1/Fractional T1 DSU/CSU WAN Interface Card 1
8 ROUTER-SDM Device manager for routers 1
9 PWR-2821-51-AC Cisco 2821/51 AC power supply 1
10 MEM2800-256D-INC 256MB DDR DRAM Memory factory default for the Cisco 2800 1
11 MEM2800-64CF-INC 64MB CF default for Cisco 2800 Series 1
12 PWR675-AC-RPS-N1= 675W Redundant Power Supply with 1 connector cable 1
13 CAB-AC Power Cord,110V 1
The Sec9 bundle comes with default 256MB RAM and 64MB flash.
However if you want to increase it here are the options avaialble
MEM2851-512D= 512MB DIMM DDR DRAM for the Cisco 2851
MEM2851-256U512D 256 to 512MB DDR DRAM factory upgrade for the Cisco 2851
MEM2851-256U768D 256 to 768MB DDR DRAM factory upgrade for the Cisco 2851
MEM2851-256U1024D 256 to 1024MB DDR DRAM factory upgrade for Cisco 2851
MEM2800-64U128CF 64 to 128 MB CF Factory Upgrade for Cisco 2800 Series
MEM2800-64U256CF 64 to 256 MB CF Factory Upgrade for Cisco 2800 Series
Narayan
6 Replies 6
Edison Ortiz
The router comes with 256MB Ram and 64MB Flash.
The WAAS is a WAN optimization and application accelerator http://www.cisco.com/en/US/products/ps6474/products_data_sheet0900aecd8058218c.html
HTH,
Narayan
paolo bevilacqua
Are you buying a 2851 for just 1 T1 link ?
Seems excessive ...
Initially T1 MPLS. Later I could put DS-3 there.
If you plan to put a DS3 at a later stage i would suggest looking into the 3800 series instead of the 2800.
The 2800 series do not support full rate T3/E3 but only subrate
http://www.cisco.com/en/US/products/hw/modules/ps2797/products_data_sheet09186a008010fba2.html
Narayan
I wouldn'be too worried about T3 performances on a 2851. Attaching here the performance sheet that Narayan has previously posted.
Go over the numbers and use common sense. Remember that certain tables have a 'sales sense' while technical analysis and experience can reveal otherwise.
For example we learn that a 2851 is rated for 220 Kpps, while a 3660 only 120. Still, in the NM-T3/E3 datasheet, the T3 module is "full rate" for the 3660 while only "sub-rate" for the 2800 series that is strangely grouped together, while we know that each model has different performances.
And yes, I've been buying and selling Cisco router for a looong time :)
