DR & BDR communication
Dear all,
As DR & BDR listen on 224.0.0.6 & All other routers listen on 224.0.0.5.
If this is correct , That means DR send hellos on 224.0.0.5 , and as BDR listen on 224.0.0.6 ,then how BDR knows DR is Down when Dr goes down.
Thanks in Advance.
6 Replies 6
lejoe.thomas
Level 3
Level 3
Hi suryakant ,
All OSPF routers continue to multicast HELLOS to 224.0.0.5, so they can keep track of their neighbors.
DROTHERs will send multicast updates to 224.0.0.6 (DR/BDR listen). DR will flood multicast updates to DROthers on 224.0.0.5.
Please note multicast hellos are always send to 224.0.0.5 and all OSPF routers [DR/BDR/DRother] listen to this address for hellos. So since everybody's listening it is easy to detect failure of any router, including your question, failure of DR by BDR.
Lejoe
Hi Lejoe,
As any link on DROTHER goes down or comes up , DROTHER send multicast update to 224.0.0.6 , so DR & BDR gets update.
but if any links on DR (or BDR) goes down or comes up , it will send multicast update to 224.0.0.5, but BDR (or DR )listen for multicast update on 224.0.0.6 ,then how they get update
Thanks & Regards,
suryakant
Hello Suryakant,
if you do
sh ip interface type x/y on DR and BDR
at the line Multicast reserved groups joined: you will see
224.0.0.5, 224.0.0.6 (and others)
DR and BDR can listen 224.0.0.5 not only to 244.0.0.6.
if you do it on a DRother you will see
224.0.0.5 (and others) but not 224.0.0.6
these are multicast addresses so BDR can listen to DR update sent with destination 224.0.0.5
Hope to help
Giuseppe
Hi suryakant,
As I pointed out previously every ospf router listens on 224.0.0.5, regardless of whether is DR/BDR/DRother. So when DR floods an update to 224.0.0.5, even the BDR listens to that one.
Lejoe
Mohamed Sobair
Level 7
Level 7
Suryakant,
In OSPF, all routers when initially build the link states database they exchanged full routing updates and all routers have all information about OSPF topology based on the SPF tree algorithm.
Partial updates are sent when there is achange of the Network like a router failure,adding new router .. etc.
Full updates are also send every 30 minutes if no changes occured in the Network.
Mohamed
Good post here.
Summary:
* All OSPF enabled routers listen to/send LSA's on multicast address 224.0.0.5
* DR/BDR listens on multicast-address 224.0.0.6 in addition to 224.0.0.5. This allows DR/BDR in a particular segment to figure out status updates.
