E1 Module
justanas1
dear Sir
i want to know what is the difference in the functionalty in the following type of E1 mofules:
VWIC-1MFT-E1 and NM-1CE1T1-PRI
Thanks alot
vijayasankar
Level 4
Level 4
The module VWIC-1MFT-E1, is specific for terminating only a E1 link.
This module is limited in its capability to use every single DS0( 64 kbps) channels available in a E1.
The module NM-1CE1T1-PRI is a very flexible module in which you can either terminate a PRI line or a Channelized E1 line or a Channelized T1 line. Software configuration option will be available to select in which mode you want to use this module.
Also in this module, when using in channelized E1/T1 module, you can have more granular control on using any specific Ds0(64kbps) channel.
For details on NM-1CE1T1-PRI module visit this URL
http://www.cisco.com/warp/public/cc/pd/rt/2600/prodlit/ce1t1_ds.pdf
For details on VWIC-1MFT-E1 module visit this URL. Check out the VWIC Feature Comparison table in that page.
http://www.cisco.com/en/US/products/hw/routers/ps259/products_data_sheet09186a0080091b9c.html
Hope this helps. Revert back if you need further clarifications. Kindly Rate the post if it was helpful
-VJ
Thak you sir,
i want to know if the VWIC-1MFT-E1 support multi channel configuration to connect more sites
thanks
No. I dont think so.
In VWIC-1MFT-E1 you can have a max of two channel groups.
Have a look at this URL.
http://www.cisco.com/en/US/products/hw/routers/ps221/products_data_sheet09186a0080088715.html
-VJ
albert.remo
Hi!
Good day! Generally, VWIC supports voice while the other does not directly support voice. Versatility is another factor, VWIC is more versatile than the other. Please see links for a more in depth description:
VWIC-1MFT-E1
NM-1CE1T1-PRI
http://www.cisco.com/en/US/products/hw/modules/ps2797/products_data_sheet09186a0080189f95.html
Hope this helps,
Albert
