EEM Script on Uplink Port
abc1235
Hallo,
Running the EEM script below, to overwrite the VLANs on the uplink port does not work remotely. Is the any error that someone can point to? Thanks
event manager applet VLAN_ALLOWED authorization bypass
event none
 action 3.0 cli command "enable"
 action 4.0 cli command "conf t"
 action 5.0 cli command "interface  gi1/1/1"
 action 6.0 cli command "switchport trunk allowed vlan 200-203"
 action 6.1 cli command "exit"
debug event manager action cli
event manager run VLAN_ALLOWED
This is the uplink's current config:
interface GigabitEthernet1/1/1
description UPLINK
switchport trunk allowed vlan 110,120,130,140-143,200-203
switchport mode trunk
snmp trap mac-notification change added
service-policy output WAN-EDGE
ip dhcp snooping trust
16 Replies 16
Of this SW is l2 then it send traffic to edge router for intervlan and to access it.
And as @balaji.bandi we  need topolgy need config otherwise we will continue to assumption.
MHM
abc1235
@balaji.bandi and @MHM Cisco World Here is the running config:
version 16.3
no service pad
service timestamps debug datetime msec localtime show-timezone year
service timestamps log datetime msec localtime show-timezone year
service password-encryption
service unsupported-transceiver
no platform punt-keepalive disable-kernel-core
hostname SW1
vrf definition Mgmt-vrf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
logging buffered 50000
enable secret 5 xxx
aaa new-model
aaa session-id common
clock timezone CET 1 0
clock summer-time CEST recurring last Sun Mar 2:00 last Sun Oct 3:00
switch 1 provision ws-c3850-48p
ip routing
ip vrf AAA
rd 804:804
route-target export 804:804
route-target import 804:804
ip vrf BBB
rd 100:100
route-target export 100:100
route-target import 100:100
ip vrf CCC
rd 805:805
route-target export 805:805
route-target import 805:805
no ip domain lookup
ip dhcp snooping vlan 100,251,300
no ip dhcp snooping information option
ip dhcp snooping
login on-failure log
login on-success log
vtp mode transparent
udld aggressive
authentication mac-move permit
flow record NETFLOW-IN
match flow direction
match interface input
match ipv4 destination address
match ipv4 protocol
match ipv4 source address
match ipv4 tos
match transport destination-port
match transport source-port
collect counter bytes long
collect counter packets long
collect interface output
flow record NETFLOW-OUT
match interface output
match ipv4 protocol
match ipv4 tos
collect interface input
table-map AutoQos-4.0-Trust-Dscp-Table
default copy
dot1x system-auth-control
errdisable recovery cause udld
errdisable recovery cause bpduguard
errdisable recovery cause security-violation
errdisable recovery cause channel-misconfig
errdisable recovery cause pagp-flap
errdisable recovery cause dtp-flap
errdisable recovery cause link-flap
errdisable recovery cause sfp-config-mismatch
errdisable recovery cause gbic-invalid
errdisable recovery cause l2ptguard
errdisable recovery cause psecure-violation
errdisable recovery cause port-mode-failure
errdisable recovery cause dhcp-rate-limit
errdisable recovery cause pppoe-ia-rate-limit
errdisable recovery cause mac-limit
errdisable recovery cause vmps
errdisable recovery cause storm-control
errdisable recovery cause inline-power
errdisable recovery cause arp-inspection
errdisable recovery cause link-monitor-failure
errdisable recovery cause oam-remote-failure
errdisable recovery cause loopback
errdisable recovery cause psp
errdisable recovery interval 360
license boot level ipservicesk9
diagnostic bootup level minimal
spanning-tree mode rapid-pvst
spanning-tree loopguard default
spanning-tree logging
spanning-tree pathcost method long
spanning-tree vlan 1-4094 priority 4096
archive
log config
logging enable
notify syslog contenttype plaintext
hidekeys
redundancy
mode sso
vlan configuration 899
ip flow monitor NETFLOW-MONITOR-IN input
ip flow monitor NETFLOW-MONITOR-OUT output
vlan 100
name INTRANET
vlan 251
name VOICE
vlan 300
name WLAN
vlan 804
name GLT
vlan 805
name MGMT
vlan 806
name AP-MGMT
vlan 897
name TRANSFER-GLT
vlan 898
name TRANSFER-MGMT
vlan 899
name TRANSFER-INTRANET
lldp run
interface Port-channel11
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
no ip address
negotiation auto
interface range GigabitEthernet1/0/1-48
description XXX
switchport access vlan 100
switchport mode access
switchport voice vlan 251
description UPLINK-MPLS
switchport trunk allowed vlan 100,251,300,804-806,897-899
service-policy output WAN-EDGE-4-CLASS
interface Vlan1
no ip address
shutdown
interface Vlan100
ip vrf forwarding xxx
ip address xxx
ip helper-address xxx
no ip redirects
no ip proxy-arp
interface Vlan251
ip address xxx
no ip redirects
no ip proxy-arp
interface Vlan300
ip address xxx
no ip redirects
no ip proxy-arp
interface Vlan804
ip address xxx
no ip redirects
no ip proxy-arp
interface Vlan805
ip address xxx
no ip redirects
no ip proxy-arp
interface Vlan806
ip address xxx
no ip redirects
no ip proxy-arp
interface Vlan897
ip address xxx
no ip redirects
no ip proxy-arp
interface Vlan898
ip address xxx
no ip redirects
no ip proxy-arp
interface Vlan899
ip address xxx
no ip redirects
no ip proxy-arp
ip ftp source-interface Vlan805
ip ftp username ULM-FTP
ip ftp password 7 xxx
ip route vrf xxx 0.0.0.0 0.0.0.0 XXXX name DEFAULT-ROUTE-GLT-NETZ
ip route vrf xxx0.0.0.0 0.0.0.0 XXXX name DEFAULT-ROUTE-INTRANET
ip route vrf xxx 172.25.0.0 255.255.0.0 XXXX name MGMT-NETZ-TELENET
ip route vrf xxx 172.30.0.0 255.255.0.0 XXXX name MGMT-NETZ-ZNP
ip tacacs source-interface Vlan805
ip ssh source-interface Vlan805
ip ssh version 2
radius-server attribute 6 on-for-login-auth
radius-server attribute 8 include-in-access-req
radius-server attribute 25 access-request include
radius-server dead-criteria time 10 tries 3
radius-server deadtime 15
control-plane
service-policy input system-cpp-policy
line con 0
login authentication CONSOLE
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login authentication VTY
transport input ssh
line vty 5 15
access-class SSH-MGMT in vrf-also
exec-timeout 30 0
transport input ssh
ntp source Vlan805
ntp server vrf xxx
mac address-table notification change
mac address-table notification mac-move
wsma agent exec
wsma agent config
wsma agent filesys
wsma agent notify
event none
action 1.0 cli command "enable"
action 2.0 cli command "conf t"
action 3.0 cli command "interface gi1/1/1"
action 4.0 cli command "switchport trunk allowed vlan 897-899"
action 5.0 cli command "exit"
end
