返信
EHWIC-3G-HSPA+7 in Cisco 2901
paul_au1234
Hi all,
I tried to configure HSPA+7 module in Cisco 2901. After configure profile and setting, it prompted the following console message and no further debug message for chat nor modem.
Can anyone advise it?
Thansk!
Paul Au
Nov 17 04:54:36.243: %LINK-3-BADENCAP: Interface Cellular0/0/0, Bad encapsulation code (30) -Process= "Exec", ipl= 0, pid= 3
-Traceback= 22B7F5E8z 225F6398z 22B5DE9Cz 22B5F028z 22B5F338z 22B5F3A4z 22EC67F4
z 22BA1EB8z 22BA29A4z 22BA36C0z 22BA3B00z 22BA7420z 2248D858z 2248D9FCz 22B332D8
z 2248C668z
Running configuration:
chat-script gsm "" "AT!SCACT=1,1" TIMEOUT 60 "OK"
license udi pid CISCO2901/K9 sn FGL162521NK
controller Cellular 0/0
interface Embedded-Service-Engine0/0
no ip address
no ip route-cache
shutdown
interface GigabitEthernet0/0
ip address 10.0.1.5 255.0.0.0
no ip route-cache
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
no ip address
no ip route-cache
shutdown
duplex auto
speed auto
interface Cellular0/0/0
ip address negotiated
encapsulation slip
no ip route-cache
dialer in-band
dialer string gsm
dialer-group 1
async mode interactive
interface Cellular0/0/1
no ip address
encapsulation slip
no ip route-cache
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 Cellular0/0/0
access-list 1 permit any
dialer-list 1 protocol ip list 1
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 0/0/0
exec-timeout 0 0
script dialer gsm
modem InOut
no exec
line 0/0/1
no exec
4件の返信4
Hi Paul,
Please find some explanation reg the bug
Link
http://www.cisco.com/en/US/docs/ios/11_2/system/message/esgrip.html
LINK Error Messages
Data link error messages
Error Message
%LINK-3-BADENCAP: Interface [chars] Bad encapsulation
code [dec]
Explanation    The lower level software was unable to write a MAC header for a datagram. A probable cause is configuration error.
Recommended Action    Copy the error message exactly as it appears, and report it to your technical support representative.
Link:
http://www.cisco.com/en/US/docs/ios/system/messages/guide/sm_cn06.htmlhttp://www.cisco.com/en/US/docs/ios/11_2/system/message/esgrip.html
Error Message
%LINK-3-BADENCAP : Interface %s, Bad encapsulation code (%d)
Recommended Action    Copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/cisco/web/support/index.html. With some messages, these tools and utilities will supply clarifying information. Also perform a search of the Bug Toolkit http://www.cisco.com/pcgi-bin/Support/Bugtool/home.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet http://tools.cisco.com/ServiceRequestTool/create/, or contact your Cisco technical support representative and provide the representative with the gathered information.
Please rate the helpful posts
Thanveer
"Everybody is genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is a stupid."
Hi Thanveer ,
Thanks very much for your reply.
From below explanation, it seems it was cause by configuration error. As I am new to Cisco router, do u think something wrong in the configuration?
Thanks!
Paul Au
Hi Paul,
Please follow the following steps
Configuring the Cellular Interface (HSPA+7)
To configure the cellular interface, enter the following commands in the cellular interface mode.
SUMMARY STEPS
1. configure terminal
2. interface cellular unit
3. encapsulation slip
4. asynchronous mode interactive
5. ip address negotiated
DETAILED STEPS
Command or Action
Purpose
Step 1
router# configure terminal
Example:
Enters global configuration mode from the terminal.
Step 2
router(config)# interface cellular unit
Example:
router(config)# interface cellular 0/0/0
Specifies the cellular interface.
Note Interface cellular 0/0/0 is for PDP 1
Interface cellular 0/0/1 is for PDP 2
Multiple PDP contexts are applicable only to HSPA HWICs.
Step 3
router(config-if)# encapsulation slip
Example:
Specifies slip encapsulation for an interface configured for dedicated asynchronous mode or dial-on-demand routing (DDR).
Step 4
router(config-if)# async mode interactive
Example:
Returns a line that has been placed into dedicated asynchronous network mode to interactive mode, thereby enabling the SLIP and PPP commands in the privileged EXEC mode.
Step 5
router(config-if)# ip address negotiated
Example:
Specifies that the IP address for a particular interface is obtained via PPP/IPCP address negotiation.
Note When a static IP address is required for the cellular interface, the address may be configured as ip address negotiated. During IPCP, the network ensures that the correct static IP address is allocated to the device. If a tunnel interface is configured with ip address unnumbered , it is necessary to configure the actual static IP address under the cellular interface, in place of ip address negotiated. For a sample cellular interface configuration, see the "Basic Cellular Interface Configuration (HSPA+7)" section.
Configuring DDR
To configure DDR for the cellular interface, follow these steps.
SUMMARY STEPS
3. dialer in-band
4. dialer idle-timeout
5. dialer string
6. dialer group
7. exit
8. dialer-list protocol {permit | deny | list | access-group}>
9. ip access-listpermit
10. line unit
11. script dialer
12. exit
13. chat-script
Hey Paul,
Wise suggession is to raise a TAC with Cisco.
Thanveer
