EHWIC 4ESG
Senbonzakura
Quick question,
how do I configure this 4-port gig expansion card on my Cisco ISR 1921 for vlan traffic?
Compared to the two normal interfaces where I can just do g0/1.1 or g0/1.2 etc... then bam you got it going.
there is no route required if you have NAT outside to inside.
example :
209.165.100.5  - outside
192.168.1.1 - inside
Static NAT or port forward required.
the provider gave you some public IP range to use - then you can assign inside hosts
BB
6 Replies 6
balaji.bandi
That is just an extension of the interface, depends on the module installed on the slow, just like any other interface configuration :
here is a reference guide :
https://www.cisco.com/c/en/us/td/docs/routers/access/interfaces/software/feature/guide/geshwic_cfg.html
BB
Alright thank you,
one more question, completely different but routing related.
I can get routing to each interface easy with NAT but how do I do it without NAT?
For example, below. How do I route traffic between the outside interface and the inside without using NAT? I have a default route out and the outside interface is being assigned an IP address from the modem. I want to get internet going through it?
Interface G0/0
ip address dhcp
description outside-to-modem
Interface G0/1
ip address 192.168.100.1/24
description inside-to-computer
ip route 0.0.0.0 0.0.0.0 10.0.01
if your internal IP address space, not a Public routable IP it is not possible, the only option is NAT.
BB
This makes a lot more since why it won't work lol. So lets say my public IP on the outside interface was 209.165.100.5 what would be the routes needed to make this work? Just the default?
example :
BB
keep in mind that in order to have hosts connected to the EHWIC-4ESG to be able to talk to other (inside/outside) hosts, you need to create an SVI. Also, since you are getting a DHCP IP address from the modem, the static route should reflect that.
What you are doing is called double NAT. The 1941 does NAT, and the modem does, too. This can sometimes cause problems with things like playing online games, opening a specific service port, connecting to a VPN tunnel, or visiting secure sites with SSL. If you are experiencing any of these problems, you need to configure your modem to NAT the additional networks (whether your modem lets you do that depends on the type of modem you use).
Either way, below is what the entire configuration could look like. The host connected to the EHWIC-4ESG is member of Vlan 20 (important parts marked in bold
Current configuration : 1320 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname 1941
ip dhcp excluded-address 192.168.10.1
ip dhcp excluded-address 192.168.20.1
ip dhcp excluded-address 192.168.100.1
ip dhcp pool VLAN10
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
dns-server 8.8.8.8 4.2.2.2
ip dhcp pool VLAN20
network 192.168.20.0 255.255.255.0
default-router 192.168.20.1
ip dhcp pool LAN
network 192.168.100.0 255.255.255.0
default-router 192.168.100.1
ip cef
no ipv6 cef
license udi pid CISCO1941/K9 sn FTX1524J802-
spanning-tree mode pvst
interface GigabitEthernet0/0
ip address dhcp
interface GigabitEthernet0/1
ip address 192.168.100.1 255.255.255.0
interface GigabitEthernet0/1.10
encapsulation dot1Q 10
ip address 192.168.10.1 255.255.255.0
interface FastEthernet0/1/0
description EHWIC-4ESG Port
switchport access vlan 20
switchport mode access
switchport nonegotiate
spanning-tree portfast
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface Vlan1
no ip address
shutdown
interface Vlan20
ip address 192.168.20.1 255.255.255.0
ip classless
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 dhcp
access-list 1 permit 192.168.0.0 0.0.255.255
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
